Everything posted by Ranchmanben
Sometimes simple is best.
Lucky find now what are these made of
I think that wrench it cool too. I hang that on the wall. If anything, maybe forge a bottle opener on the end so there’s a reason to take it down for people to use.
My imagination is a whirl with what vulgarity you let fly. The card holder looks sweet. Jennifer, those hooks and chain look killer. I’d have a hard time doing good work like that infront of onlookers, too many distractions.
Definitely not a leaf spring but great metal for tools. Probably not enough carbon for a knife though, if that’s what you’re into. Don’t take this as gospel but a lot of that medium carbon steel used for farm implements is 1045ish steel and is some of the easiest and most forgiving to heat treat. Quench in water and draw color to suit.
ID vise and is it bent?
Das, I’ve currently got two Indian chief vises and have had three others that I’ve released back into the world. All but one have had the same style hex nut as that one. A couple were we’re very very lightly used and so most likely all original. That leads me to believe Indian Chief vises often had hex nuts instead of square nuts. All of them have had a screw box like the one pictured but I know that’s not a definitive indicator. J, you have to keep in mind that all the parts might not be original to that vise. I tend to agree that is sure looks like a Colombia/Indian Chief but it’s quite possible that mount or screw box could have been a replacement for a lost or broken part at any time during it’s long life. Oddly, not one of the IC vises I’ve owned have had the octagonal sections on the legs which makes me think they were made later on. I wish they did, I like the way it looks.
Where to get coal?
As Thomas said, call all the farrier supply stores. Lots farriers, especially the competitive farriers, burn coal or coke. Odds are high that if there’s a large farriers supply house around there they will have coal/coke or be able to get you some.
The bar with the green paint is potentially some decent medium carbon steel. Looks to me like some metal pieces I’ve forged that we’re from farming equipment. Some has spark tested the same as known 1045 while other pieces have spark tested better than mild steel but not 1045 and was somewhat hardenable. Great for punches.
Those are most definitely metal. Most likely some sort steel.
Peter wright anvil should I buy?
Peter Wright’s are good anvils but not necessarily the best. All the old name brand anvils are good. Some Peter Wright’s are better than some Hay-buddens. Some H-Bs are better than some Trentons and some Trenton’s are better than some PWs. For the most part it comes down to the specific anvil. If you go check it out and it’s got good rebound all over the face, you like it and are comfortable with the price then jump on it. As long as it’s a responsive anvil, there’s a whole lot of work that can be done on it just as it is. Later on it, after significant use, you can dress the edges to what you’ve decided you need.
That anvils is post 1910 and originally weighed 152lbs. It’s not in the best shape but far from the worst and it looks like it’s got something wedged in the pritchel hole. I don’t know the market in your neck of the woods and how often anvils come available. It all comes down to how bad you want a “real” anvil. I’d start the haggling fairly low.
It followed me home
Paid a little more than I generally like to but I really liked this one. The maker stamps is deep and crisp. Serial number 14196 puts between 1901 and 1912. The chunks missing on the edge are very shallow and will all but disappear once the edges are properly radiused. I didn’t get a picture but on the side below the shelf are some initials, presumably from a former owner. I also snagged a little post vise that’s in need of some love. The screw is in good shape so it’s got that going for it.
80lb anvil ID?
With that lip around the face it very well could be a cast iron boat anchor made to look like an anvil with a steel face but it might be something as good as a Vanadium steel anvil. It looks rusty or painted, just because you can’t see the markings doesn’t mean they aren’t there.
80lb anvil ID?
Those are terrible pictures but it looks clean from what you can see. I guess it all depends on how bad you want an anvil and if it’s in your price range. I’d drive two hours for that one without hesitation. I’d rather drive and check it out myself than miss out on a good anvil.
New Swage Block Pattern
I like it pretty good but it looks a little busy for a 1 foot square. I think if you upped the size a couple inches it would give you the room to better arrange the holes into a more user friendly pattern.
Getiing rid of the Dragons Breath
I figured it had to be something along the lines of doubling CO/CO2 but wasn’t sure. Better safe than sorry.
Al, I only burn coke in that forge and there’s no chimney of any sort. One of these days I’ll talk the boss into letting me cut a hole in the barn for a chimney. Until then I use a combination of very big fans and large doors open to have enough air flow to not die.
Howdy from Oklahoma
Charles, if I’d have had someone like you that close when I started out I’d have basically taken residence with them.
Howdy from Oklahoma
I know how it goes. There days in the winter I chop ice, cake cows, feed horses then send the rest of the day at the forge. I like those days. Then there are the days when all your water is frozen and there’s no electricity for a week. Those days are less fun.
Thanks Mark. I’ve been building up that shop the way I want for eight years now and in another eighty I’ll be half way finished. Those tongs are mighty nice! I’m going to have to steal your set down stop idea. I’ve still been marking my anvil with a sharpie which works pretty good until you see such a superior method.
Howdy from Oklahoma
Some of those tools look pretty handy. Some of the others look extremely handy and they all look well made. I’m not all that far from you, Clarendon, Tx. If you ever make over this direction shoot me a message and we’ll link up. Until then, take a look at the Saltfork Craftsmen. It’s the Oklahoma chapter of abana and I’m pretty sure they have meetings in Sulfer every so often.
July 2017 Something for hanging on the wall
Haven’t had a chance to get to that yet but you can be certain I’ll put up pictures when I do.
Howdy from Oklahoma
Howdy and welcome. Where abouts in Oklahoma are you. Ben
It followed me home
Fear not Thomas. When I’m using the coke forge I have two 16’ Big Xxx Fans running and at least one of the two 14’ tall barn doors open or both of them open a couple feet open in the winter. I’m in the Texas panhandle, there’s never a shortage of wind to carry away the fumes. The barn is 50x100’ so it’s a decent sized space to begin with. I’ve actually burned coal a few times in there and it’s amazing how fast the yellow smoke upon start up will clear out. I’d just rather not deal with it at all. Mod note: the brand name of the fan Ranchmanben uses has been redacted, as it does not meet IFI's community standard for language.
I can run my hand within 5 or 6 inches of the port in the door with the fan going. With the door open it’s not quite as good but I no longer have to wear a glove on my tong hand to get material out. Thomas, my forge has very little risk of that but but I’m curious of why that would be so detrimental.
Trenton 165# German forged....but weird shape!!!!
That’s a farrier pattern anvil. The little nub is used for drawing clips on a horse shoe. Pretty neat find.
