Before you build your first forge.
Well, I think the forge is hardly what I would call miniature, just about 2/3 the size of my current forge. The new interior is right around 340 cubic inches, configured as a half cylinder (hemi-cylinder?); a "D" shape with the flat side down. Saw that configuration in other's forges and when our local group had a workshop making same I had to sign up. Most folks used a pair of full hard bricks for the floor (backed by 1" of kaowool) I used a high alumina split brick floor backed with a bit more thickness (as far as I'm concerned you can't have too much insulation). The design standard was for a single 3/4" NA propane burner, and reportedly others have achieved welding temperatures with same. I use low pressure natural gas in my shop, so I decided to try a ribbon burner instead. My logic, and it may be totally off kilter, is that the ribbon burner will permit me to add the same amount of heat (combusting air/gas mixture) to the forge interior at lower flame velocities and greater spread to initiate the radiative heating process used to actually heat the metal. Hopefully this will give me a couple of positive outcomes: Not overtaxing my smaller blower (would rather keep with the Kane Bros 140 CFM blower than go up to my Dayton 1/2 HP high pressure blower, which is rather oversized) Reducing the noise level from the gas forge Reducing the effective forge heat lost via the combustion products venting The last one is a bit questionable I agree, but my theory is that my door openings typically are not optimized during forge use (larger than needed) due to my negligence in closing the doors and/or stock considerations. With a door that is too open, high velocity flame fronts (from conventional stable burner outlets) could lead to high velocity flue gas exit, or even portions of the flame existing the door itself. The higher velocity at the same door opening size would result in a higher heat loss. Basically the slower the flame moves inside the forge the more time it has to heat the forge interior and the stock. Now I'm not a combustion engineer, and have been quite impressed with the design information for forges and burners you have shared with us on the site. The natural gas/forced air ribbon burner I have is 9" x 2" Mizzou with 15 crayon sized holes. What do you think?
Small smithy ventilation
Actually I checked his profile, and while I would also attempt to help the young folks who are trying to build a safe, successful smithy the OP is apparently in his 60's. I think this is just a matter of miscommunication.
I would add that it is not just the interior volume, but also the type and thickness of the forge insulation as well as the door construction/configuration, but I see where you are coming from Frosty (for sufficient insulation that the side walls are not bleeding out all your heat and reasonable door openings the critical parameter is the forge volume). I have also made the mistake of having my first two gas forge bodies a little too large. Now on my third, which will have a ribbon burner, and hope to correct this. Forge design is a bit more critical when you are heating with residential pressure natural gas.
Unfortunately there are a lot of variables that you haven't defined carefully enough to allow reasonable suggestions. Glen, Thomas and Frosty were clearly trying to be helpful by indicating where we need additional information and/or how they solved these issue themselves. If you would prefer to do the code required ventilation study and get a professional engineer onboard (at an average of $120/hr.) I'm sure you could hire a consultant locally. That being said I'll try to give you some feedback based on assumptions I'm making about your shop (I will be getting a little technical, so bear with me): You don't run the coal forge and the gas forge simultaneously You have at least a 3' x 7' door that you can leave open You are burning propane in your gas forge, not natural gas (like I do) Your 12" chimney draws well and removes all visible smoke when coal forging My recommendations would be as follows: Get a $35 Fire/CO monitor from your local big box hardware store. There is no substitute for monitoring For coal forging you're probably fine for ventilation with the door left wide open during forging and the chimney exhausting the fumes, forcing the replacement of air at that point. You may want to add an exhaust fan (see below) to draw some heat out of the facility as well, but be careful to not overcome the chimney effect and draw your fumes back down the chimney (best to keep the door open most of the time you are forging and start the exhaust fan only after the chimney is drawing well). Gas forging is another problem, as you likely don't have a hood to capture the heat and drive the exhaust up a chimney. My recommendation is to install a propeller style exhaust fan at the high point in your building. A good rule of thumb is to design for a minimum of 10 air changes per hour (10 ACH) for ventilation. That is 10 full room volumes per hour (i.e. if you have 10' ceiling height in a 8' x 12' shop you need at least 160 CFM of ventilation air, not a whole lot. For my 20 x 20 shop with a peaked roof above 10', I have a 24" exhaust fan that pushes over 3,000 CFM with a 1/2 HP motor, but I like lots of air exchanges for both safety and cooling). However you also need combustion air entry added to the mix for consideration. Typically code states that this air must enter the room at two points, one high and one low. In this case you can get the high entry via a roof vent (I use a turbine style in my shop) and the low via the open door. The national gas code requires that these openings be at least 1 sq inch in size for each 4,000 BTUH of heating capacity of your fuel burning appliances. If you know the ratings on your burners you can size this accurately, but likely an open door will do for the lower one and a 12" turbine vent for the upper. Anything more and I'm sending you a bill Turbine vent:
My side blast forge design
A typical bathroom exhaust fan has, at most, around 0.5" of external static pressure capacity at the lower of the airflow rates it is designed for. A fan curve or chart will tell you more. Your diverter appears to be designed backwards. You can definitely use a Wye fitting, like you have, but the variable damper should be on the outlet side of the of the bypass (or release as you call it) side, not on the main inlet. In this I assume the flex duct connects to your forge. If it actually connects to your fan, and you don't have enough airflow, I suggest that you damper the bypass side and close up the slot you made. As I said, exhaust fans don't develop much static, but you shouldn't need too much provided you keep your duct lengths short, avoid elbows and offsets, use smooth wall ducts and avoid rapid transitions in diameter (30 degree transition angle is a good rule of thumb). A photo of the entire system, setup with the fan in place, would make it easier to diagnose. Others might be able to comment on the size of your coal. The last workshop I went to we made an effort to screen out all the "fines" leaving us with only the larger size pieces (these were still in the 3/4" -2" minor diameter size though, not huge fist sized chunks. This worked extremely well for the upblast style forges we used, but I'm not that familiar with a side blast, so don't know what kind of pressure and airflow are needed. All I can say is that the conventional hand cranked or electric forge blowers I've seen all are more of the low airflow/high pressure style (radial paddles) instead of the high airflow/low pressure style (squirrel cage centrifugal) like your bathroom exhaust fan. The former most likely develop 4 times the pressure yours does, for the same airflow. If nothing else see if your exhaust fan has a backdraft damper built in. Remove that.
The easiest way to update your setting for variable air volume would be to use the Dirt Devil vacuum and modulate the output in one of three fashions: Put an outlet TEE, or cut a hole in the connecting pipe, that can dump out some of the air before it gets to the tuyere. Use a movable cover on that outlet (dump gate) to increase the bypass air or the air fed to the tuyere as required. Add a butterfly damper to the supply side of the dirt devil vacuum (may be a problem with the fan motor as the extra resistance that cuts the air supply will force it to work harder) Put an adjustable shroud over the air inlet for the vacuum and open and close as required (mock this up in cardboard to see if it works. some constant speed fan motors don't like getting starved).
Aquiring tools
Also a big fan of the ubiquitous 2# drill hammer. It was my first "real" smithing hammer and I still like to use it. I ground one side to a bit of a rounded profile and use it for my "light" rounding hammer. If pressed I could easily do any forging necessary for basic bladesmithing with it, and have in the past. Last time I was over, Harbor Freight did have a cheap one, though the handle is a bit long and the faces soft. I keep it for beginners to use so I don't give out the nice old one I found hanging in a corner of my father's basement.
Aquiring tools
Good tools can be found in many places: online blacksmith supply, antique shops, e-bay, yard sales, your relative's basement, flea markets... As far as what you might need: A lighter hammer. For a beginning bladesmith 3# is a bit heavy to learn the required hammer control. I would suggest 2#. Something to use as an anvil. Lots of possibilities here, don't get fixated on a London pattern, you hardly need it for bladesmithing. Something to heat your metal up with. Sounds like you want to do some forging, so you need to get up to orange heat at least. Gas or solid fuel forge is what most of us use. High carbon, tool or spring steel: railroad spikes are not appropriate for making knives with in general More sets of tongs to fit the steel and size of knife you want to make, flat nib are barely adequate and the stock will shift as you learn forging making control more difficult. A tank and appropriate fluid to quench in for the critical heat treatment part of the process Something to do final shaping on the steel after forging. Good files and wet/dry sand paper at least. A book or two on bladesmithing, or some in-person training from a smith who knows the craft
Type of bolts, break drum forge???
Suggest that before you spend a lot of money and time on putting together your kit for smithing that you investigate joining, or at least attending a meeting, of the local chapter of the New York State Designer Blacksmiths (NYSDB) group. I believe that the Adirondack region chapter in pretty close to you: http://www.nysdb.org/regions/adirondack/. You can attend your first two meetings for free and learn quite a bit from this knowledgeable and friendly group. Getting info online is great, but hands on experience can't be beat. If you are up for a road trip, we have our annual picnic with the Niagara group in Buffalo this Sunday.
Side draft hood not working properly
Forgot to add one of the key caveats from my missing post: makeup air. The fumes you want to vent need to be replaced by something, be sure to have a window or door open somewhere else in the room.
Drat, I had a good, what I thought would be helpful post, but it disappeared (moderators?). Don't have time now to recreate it with all the theoretical stuff, sorry. Bottom line is, my suggestion is: Cap the lower TEE and install P-trap for drainage (prime that trap with water so it doesn't leak air) Add stack height, that is what drives the flue exhaust (take Frosty's suggestion and move forge closer to wall and use interior duct in vertical) prime stack by burning paper in hood before use to start flue going get rid of the restriction before the TEE 8" diameter is rather small, flow resistance may impact the effectiveness.
Forge progress
I'm particularly sensitive regarding this topic as I worked at installations with no rigidizer and high heat/velocities for many years. Have consequent damage to my lungs and hope to have others avoid same. The rigidizer is a good first step, but as you can see from your photo it is a fragile layer, and being transparent difficult to tell when damaged. For what it is worth I'd put at least a skim coat of furnace cement over the exposed wool. Since you plan on building doors of some kind this will also protect this area when you operate the doors.
Best deal to buy
As Frosty says the Sodefors is most arguably the best material construction, and the Fisher has the reputation for being quieter for use in residential areas. However, all things being equal I would go for the Mousehole based on weight listed and apparent condition. I like the Mousehole configuration for bladesmithing as well, witht he wider face and the bulk of the anvil weight being under the sweet spot and not in the horn which gets limited use in knife making. Each to their own. As I said before an aspiring knife maker should be able to use any of the above profitably, and the prices on all of them look fair. In my neighborhood they would most likely already be sold.
Best deal to buy
Mousehole looks a lot like the one I recently got, but mine has a smaller horn and is lacking a Pritchet hole. I would expect that any of the above should be a fine anvil for a beginner blade smith with the more desirable ones meeting the rebound test, but even if one doesn't it will still work well enough for a beginner bladesmith.
Forge progress
For your own sake please cover the exposed ends of the Kaowool insulation. It is visibly still showing as loose and will degrade further in use leading to fibers in the air and eventually your lungs. If you coat it with a rigidizer solution (sodium silicate, colloidal silica...), first that will harden and allow better coating with the refractory cement. Otherwise just an initial light misting with water will help keep the wool in place while it is coated, but the silica rigidizer works much better.
Rich vs Lean vs Neutral
It has been a while since I've studied the dragon's breath coming out of my forge, so I could be off on color. Of course it may be different in mine as I burn Natural gas, not propane. What I really intended to say was just a small visible lick of flame, not specifically a certain color.
Black steel does not mean cold steel
I also like to wear a relatively thin Kevlar glove on my left hand (gas forge and tongs/stock heating issue, like Frosty). The only time I wear a glove on my right hand is when forging larger stock where the radiant heat coming from it starts to interfere with my appreciation for forging (I know, longer hammer handles, or less choking up is another solution, but then I find I sacrifice either hammer head mass or control). Each to his own.
Darn, I thought I was giving a simple answer... Oh well, I do get carried away sometimes I guess Thanks for clarifying.
Getting Started
Swords are larger and more prone to hitting vulnerable parts of the body when swung around or tested on random cutting objects (especially if they break during this testing). If you are just looking to make something that looks like a sword, but will never be used (wall-hanger), you might want to try working in aluminum with a hacksaw, files and sandpaper. That will be a lot easier and cheaper (though I would still avoid sharpening it as aluminum can cut very effectively, just won't hold an edge). For a sword, improperly designed and fabricated proportions, weight placement and associated resonance nodes can easily lead to breakage(there was even a forged in fire "expert" who had his sword catastrophically fail during testing and a section scythed off during use). Tang geometry and connections can be critical as are handle assembly, crossbars/guards... Heat treatment is critical, more difficult than with knives, and needs to result in a different outcome. As far as forging a sword dangers, the size of the billet and manipulating same in the forge, at the anvil and at the grinder (forging the billet is only a small part of overall sword making, wait till you try draw filing or grinding those long bevels) present additional challenges over smaller knife making. Respectfully, right now you don't know enough to be properly cautious or even ask the right questions. Start with Jim's first book and learn a bit about what is involved. If you can't imagine the difference between the danger of making and using a 2-4 lb. 36" long piece of sharpened metal instead of a couple ounces of 6-8" long knife then you are going to be asking for a Darwin award. There are some great "sickies" in this forum covering this issue. Please read them carefully.
Getting Started
Glenn gave you good advise for reading material in the above post: Buy Steve Sells book on Introduction to Knifemaking from the IFI store. Buy the books by Dr. Jim Hrisoulas, currently 3 and he is working on #4. Also I second the suggestions to take a class. I've been forging blades for several years now and still took a class in sword smithing before making one to avoid costly and dangerous mistakes. The latter is the real concern. Honestly I don't care if you go broke experimenting with making swords (it is possible to be successful without training or making knives first, just very unlikely), but you, or innocent bystanders, can get badly hurt by mistakes made in their manufacture. That is what I am concerned about.
Large Anvil Identification Help
You are going to make a lot of smiths here pretty jealous. Just starting out and you look like you have scored at least a 300 lb. anvil in great condition with additional hand tools. If you decide smithing isn't for you, you should have no problem selling this stuff off.
This refers to the proportion of air and gas in the burner firing. If I am remembering correctly, rich is typically a reducing mixture, neutral is a "perfect" stoichiometric mixture and lean is a gas-poor mixture. With a NA propane burner, setting these is a bit more challenging, IMHO, than with a blown (gun style) burner, particularly if you don't have some kind of shroud for the air inlet. Usually it is easiest to determine your mixture by looking at external cues. Once the forge is up to a stable temperature, if you have a couple inches of yellow flame shooting out of the exhaust port (or door) you are running slightly rich (which IMHO is a good setting for limiting scale formation inside the forge). If you have no dragon's breath you are probably either lean or neutral. A bit harder to determine which, but you can do it experimentally. As you turn up the gas pressure at the regulator for your NA burner, from a minimum setting where you are just maintaining a good stable flame at the burner tip (for each setting of the air inlet shroud), the forge should start to get hotter. Just before you start to get flame showing out of the exhaust port (check in a darkened room) you should be pretty close to neutral. This is most likely the ideal setting for maximum energy efficiency, but is tougher to maintain while limiting scale and avoiding inducing extra air which can cool the forge interior. Most burners are not ideally constructed and do not fully mix all the air and gas in their mixing chamber, so some extra induced air can be introduced into the forge chamber. With a borderline setting, like the neutral one, you are always in danger of straying over to lean when forge conditions change (i.e. opening or closing forge doors, introducing stock that obscures the burner outlet...). That is one of the reasons why I typically run slightly rich. Note that this is a pretty gross simplification, and you will need to be more creative if you have a shroud for the air inlet on your burner, but the general concept should be sound. In my experience it isn't all that critical, as I usually run slightly reducing most of the time, but YMMV.
My new gas forge
If you will reach any appreciable temperatures I would not hold out any great hopes for the scrap of SS. It will be better than nothing, but there is a reason you don't see the interior of forges lined with steel... A piece of high alumina kiln shelf will be much better, if you can get one from a ceramic supply house. If nothing else try to source some refractory furnace cement used for furnace repairs. This is a common hardware store item here in the states, is typically rated up to around 3,000 deg. F, and can be applied in multiple thin coats with a brush (thin with water). Another option for dealing with the chimney effect is to just remove your burner assembly each time you shut down the forge. Kind of a PIA, but could save the ventauri section from long term damage.
My new gas forge
Gosh that is a cute little forge. Very nice fabrication skills, I look forward to see what you will forge based on your attention to detail in the construction of your gasser. Having the brick slightly overlap the door openings and be replaceable is a sophisticated touch. In my experience soft brick doesn't respond all that well to forge temperatures and rapid thermal cycling (but I was using some 2300 deg. F brick, so YMMV). Hope you have better success there than I did. If anything you may want to put a skim coat of high temperature refractory coating on the brick before you put on the IR coating that Wayne recommends (at least on the brick directly opposite the flame).
My first attempt at multi-bar pattern welding
Well I'd sure be thrilled if I had made that one. May not have been exactly what you intended, but for a first multibar it looks great to me.
