Everything posted by patrick
Extruding
We use the ring method too, but that is a heavier tool to handle so they only do it when the tonnage needed to get the extrusion they want is so much that it would squash the flat bars.
- leaf bracelet
Extruding
Thanks for all you input guys. I don't think we have a formula at work for this either. We do much like what forgemaster does only with larger parts. We will often use two ring tools to make pinion type forgings. The first has a hole the diameter of the shank and the second is taller than the first with an ID that will just fit over the OD of the short tool. We forge a round bar and drop in in the short tool. We upset one end to fill the larger tool and then flip the whole thing over and put 1/2" flat bar between the smaller tool (now bottom up) and the top die. The bars are on either side of the hole in the tool and with this arrangement we can get just enough extrusion to fill in the corners of the hole. Too much extrusion and you will rivet the two tools together. For purposes of this particular tool the shank length was not critical, I just didn't expect to get that result and if I did need to control the shank length I'd use a bolster block sitting on the anvil. Here are some pictures of the hammer I want make. The plan is to start with 3" round. I'll forge the middle section down to about 2.25" square, then punch and drift the eye. It is at this point that the fullers would be used to refine the profile of the hammer.
Extruding
Frosty- I think maybe you mis understood what I did. I drew out a shank with a length of 2 5/8" inches leaving a 1/4" shoulder all the way around . This shank went in the hardy hole leaving a block of metal 2x2x4.5 above this anvil face. This was upset, but during the upsetting process, the shank grew an additional 1.375" in length. I never hammered on the shank during any of the work after initially drawing out the 2.625" length noted earlier. The question I have is how to predict how much to allow for extrusion of the shank if I do something similar again. I'm sure I lost some metal to scale but not 10%. At work we us a factor of 3% and since this forging is relatively small compared to that and the heat up time relatively short I think it was probably less than 3%, but scale losses are not related to the extrusion issue I'm describing
Hammer size??
My favorite hammer right now is about 4.5 lbs, but I do most of my work with a power hammer and use this hand hammer for straightening and touch up. I can swing it all day, but the need for that in my shop is quite rare and I don't hesitate to change hammers as needed to suit the work. I did have occasion last night to upset some 2" square to make a hardy fuller and for that I used a 14# sledge. It was the first time I'd done any sledge work of that weight and I will say it really took a lot out of me. I did get the job done and I could really see the difference between using a big hammer like that and my regular sledge which is about half that weight. What I realized is that if you were doing sledge work full time as we see in some of the old videos you really could make some pretty big things by hand and you'd be in incredibly good shape to boot.
Extruding
Thomas- There is a very slight bevel on the hardy hole. I think the reason I got the result I did was because the hammer I was using for the upset was a 14# sledge and the anvil was the one a made a couple of years ago that weighs a bit over 1000#. I'm sure this let me transfer the vast majority of the hammer's energy to the work piece, I just didn't anticipate that happening because my past experience with upsetting has tended to only affect the metal very near the struck surface.
Extruding
I am in the process of making the tools to forge a large, French pattern sledge hammer. One of those tools is a pair of 2.25" fullers. I have the bottom one already, but need to make its mate so tonight after work I started on that. Since I'll be hand forging the hammer, I wanted to get a feel for doing work of similar size so in this case, I chose to use a 2x2x6 inch piece of alloy steel. I sectioned off 1.5" of that to make the striking end and then upset the balance (2x2x4.5) to a block 2.25 x about 2.5 x 3. When I was done it was T shaped with a rough radius forged in. I did this in the anvil as if I were going to make a hardy tool. At 1.5" square the shank will be plenty big enough for the striking end of the tool. What I found surprising was that the shank grew in length from 2.625" to 4" during the upsetting process. Has anyone else observed this and do you have any rules of thumb for how to estimate the amount of extrusion you'll get on a job? I've seen this extrusion effect many times at work where we are press forging, but I didn't think that I would have sufficient power to do that by hand. I expected all the metal that started above the anvil surface to flare out. That did happen, but apparently not as much as I'd anticipated.
History of the Forging Industry
Take a look at the Scot Forge website to see what is currently going on in the open die forging world.
custom made anvil help
This grade is not a tool steel. It is a carburizing grade designed for bearings. In its current condition it will be quite soft. To heat treat it effectively you need to have professional heat treat shop carburize and quench it. I'd think tempering at 450-475F would be about right to get typical anvil hardness.
- custom made anvil help
Anvil welding
I suggest working over with a coarse grinding wheel or sanding disk. I think most of those dings will polish out without welding. You'd have to do that anyway to dress the welds so skip the welding and use if for a while. Even if it is soft, you likely will not put that much wear on it for a long, long time.
Bradley Guided Helve
Here are the pictures I meant to have in the last post of the hammer my team and I will be making for the Friday night demo. Patrick
I aspire to be an old codger someday and with a lot of hard work and perseverance maybe I'll get there. Die changes are pretty quick. Most of my work only requires the lower die to be changed and that takes about a minute. If I have to do both dies it's about 5 minutes. Getting the top die in is a little awkward because the ram never stops at just the right height. Since my dies are pretty big (my flat dies weigh about 40#) and the Bradley uses a two key system, you really can't hold that die up by hand. I usually just stack wood shims on the bottom die until I can just slide the top one in place. I drive the keys. After a few blows you sometimes have to tighten the keys but once they are set the top die doesn't usually come loose. Because I do a lot of off-center work as shown in the video, my bottom dies will often work loose and have to be tightened up between heats, but that is about a 30 second job. Thomas- Yes Melody and I will be at Quad State. In fact, I've been asked to lead the team doing the Friday night demo. I'm really excited. We'll be doing a double face sledge of French style based on the one in the pictures. It's a bit tricky since the faces are larger in diameter than the body of the hammer. I'll be making some specialty tools to assist with this. Mike Roberts and one or two of the other local Quad State members will be helping me.
In one of the recent threads there has been some discussion of forging thin plates with a controlled thickness. This video shows me forging rain drop mokume 0.220" x 2.625 using a specialty die I made that has integral stop blocks for both the width and thickness. As you can see, I could forge several different widths depending on which slot I use. I have quite a few dies of the same style for forging a range of widths and thicknesses. Patrick
Hammer Recommendation
There are no mechanical hammers currently in production in the US. Both utility style and self contained hammers can be purchased new. There are several makers of utility (those requiring an external air compressor) in the US: Big Blue, Iron Kiss and Ken Zitur. The self contained machines are made in Germany (Kuhn), Turkey (Say-Mak/Sinhalier) and China (Anyang and Striker). All have their good and bad points. The challenge you are going to be faced with, no matter what hammer style, maker or vintage you get is keeping uniform thickness to your plates. For that you'll either have to learn how to do that by feel or set up some kind of a stop to keep the dies a fixed distance apart. From a controlability standpoint, you can't beat a Bradley mechanical running on a big slack belt. There are some limitations with this and other mechanical hammers which you don't have with a self contained machine, but for repetitive flat die work they are fantastic.The biggest limitation I see that you'll face with a self contained is the size of the dies. If you are doing large disk type forgings that completely cover the lower die, you will have no way to stop the upper die to produce a uniform thickness. Because of the die orientation used by Bradley, you can make very long dies which means you can still set up stop blocks and have room for your work piece. The challenge you'll have with most mechanical hammers, regardless of make, is that they often need rebuilding (if they're cheap). If that rebuild is done well then they usually very good hammers within their design limits. I'd encourage you to work with other smiths in you area who have various hammer. Get a feel for what you like and don't like about them before committing. By the way, I am running a 300 lb Bradley guided helve, which is actually set up with 460# ram, on a 10 horse, single phase 220 motor. The hammer runs at about 220 bpm when fully engaged. If I want, I can feather that ram back so it just floats. I did this once to forge dragon fly wings from 3/16" square and it worked beautifully. Patrick
The future of blacksmithing
I think you may be approaching the 3d printing issue from the wrong perspective. While the technology will no doubt advance to the point where metal parts will be able to be printed, as was already noted, those parts will not likely take the place of forged components for engineering applications and they likely would be too expensive to be competitive with hand forged custom decorative ironwork. I think the more likely situation is that plastic parts printed by this technology will be able to be produced on demand and then assembled in "kit" form to look like ironwork. Recall that this exact approach was something that Yelling and his contemporaries faced with cast iron. Though cast iron rarely if ever looks like forged iron work to the the trained craftsman, it is good enough for the average consumer. With 3d printing you'd be able to make a better replica of true forged work than you could from a casting. Even though cast iron did take over a large part of the wrought iron market, it never totally eliminated wrought iron. I would expect the same with 3d printing. For those who want the look of wrought iron and don't mind that what they have is a "cookie cutter" copy that could show up in the house across the street, 3d printed components will be an attractive option. For those clients who want truly custom work, they will still come to the blacksmith.
- Sawmaker's anvils
Nazel 4N Build
Since the budget is a concern and you have a penchant for larger machines, which makes sense if your long term plan is to run a shop as a business, may I suggest you consider a larger mechanical hammer? They are not as complex but still have significant machining needs when rebuilding and the cost is usually much less than that of a Nazel, Massey or C-burg. This option may get you started with lower investment and allow you then sell the rebuilt hammer at a profit help fund the machine you'd like to end up with.
Raskin Press
Punch presses absolutely can be used for hot forging but unlike a hammer, they have a fixed stroke length with no flexibilty in the mechanical linkage so they will not perform drawing, tapering and forging operations of that type. They will work very well for specialty die and impression forging, but you must have your starting material and your tooling matched up so that the press can complete it's stroke as Thomas mentioned.
Forging stainless steel under the power hammer ?
One thing to keep in mind when working exotic materials is how much deformation you do per blow. Some of them require a gentler approach than you use with carbon steels. Also, in some case you need to forge square, octagon square, not just square all the way down. The only way to know is to experiment, but we utilize these techniques on large forgings from time to time and they can work. Also, with some stainless grades you actually need to forge COOLER that you would for plain carbon materials.
1,000 weight niles bement pond hammer
Need is just a matter of perspective. I do like the idea of the long stroke that comes with a steam hammer, but I have a 500 lb Bradley to install before I invest in any more equipment. I really want to weigh the ram in that machine because, based on comparison with the 300lb Bradley, this one is probably pushing 600# or more. That's a lot of machine and I will probably be able run it faster than Ric's Niles. I expect to set it up to run in the 200-220 bpm range for fast drawing. Unless my work changes drastically I don't think I'll need more hammer capacity after that one's running.
What's with the 2nd step?
These are not that uncommon in England, but you don't see them that often here. I made one just like this but bigger a few years back. It was based off of one (739#) that had been imported from England for resale. That particular one was thought to have been a Mousehole and Mousehole certainly did make this style as did Peter Wright and Kirkstall. If you look through the adds various companies ran (see Anvils in America) you will see that they weren't that uncommon, they just weren't imported into the US. The step from face to square horn can be used just like the step in the face of a London pattern anvil.
Nice looking machine Ric. How long until you have it running?
Double horned anvil, and stake anvil
Quite a few years back there was a guy at Quad State with a whole trailer full of big french anvils, some upwards of 600#. I don't recall his name but he was a veterinarian who'd put himself through college working as a farrier. He had that trailer load of anvils for 2 or 3 years before he finally sold them all. That's really the only time I recall seeing french pattern anvils here in the states. It seems the tide has turned to the German and English styles, thought that may be more a matter of the contacts the importers have in those countries than a reflection of the actual interest in the US for French pattern anvils.
Set Stroke Depth?
Presses are not ideal for production of thin sections because the metal cools too quickly and the tonnage requirements rapidly increase. They are also slow if you don't invest significantly in the valving and controls. I tried doing some 0.220" x 2.625" wide flat bar on a press once and it was extremely inefficient. The best way to do the job in question is with a combination of hammers and a rolling mill to finish, but a rolling mill with rolls wide enough is a huge machine. You could look at roughing out your jobs and then contracting the rolling to an outfit like Braburn.
