Steve Sells
Administrators
    9,163
Everything posted by Steve Sells
  1. trade. scrap, salvage, or self smelted, rare but it happened.
  2. Frosty THAT is a GREAT idea for RR track !!
  3. as for salvaging this billet, Cut off the folded part and the remaining should be fine, assuming you don't have scale in the space between the layers...
  4. Borax is not a flux for copper or its alloys, wrong temps for one thing. Sal Ammoniac is a good choice for copper, but it is not needed for this application. Cut not fold, clean clean then clean again. For patterning, if our welds are good, any repose technique will work, hot or cold! but remember cold it will work harden,you WILL feel it start to get hard, STOP then, do not hammer even one blow more. We must occasionally heat to red, and quench to soften non ferrous metals. Also drilling for a birdseye, grinding slots for a ladder all work. Even twists if you are careful not to over work, remember the work hardening IS a metal stress.
  5. the problem is New guy, that red hot is not hot enough to weld,or even work some steels.
  6. There is much information in the Sticky about this at the top of this page. please read it all, as its no joke, it can kill you.
  7. if it isnt burnt, normalize many times should reduce the grain back to usable size. try it !
  8. There are sticky's on proper ways to heat treat in the knife section, with links to references, and so there are more links in those, over 200 links all totaled... Also by quenching such a very high temperature, you have created mostly Plate Martensite, rather than lathe, so it will be very brittle no matter how much tempering, compared to a proper temp. quench. Read and try again. Never give up, never surrender!
  9. flux?> why flux, and WHAT flux did you use? that could be part of your problem
  10. don't have to be a blade, just that Martensite colors more. If you are worried about it being too hard, then temper at higher temps. but Hardened will have more contrast
  11. MOD alert, we are happy to give Dad his own log in, actually we prefer to keep them separate, rather than continue the issue Frosty just mentioned. please set up separate accounts. If you have trouble Glenn who is the forum owner, will assist you.
  12. You call it crude, but I say its cool, I like the shapes/designs. :D
  13. I forge weld a lot of damascus billets. I buy my borax by the 3 pound box. It lasts me a few months. 25# will get wet(wetter?) before you use even a portion of it.
  14. Hair dryers work well. best if you don't waste energy using the heat settings, as it only overloads/heats up the dryer. Just use air setting.
  15. In post 1 you make an accusation of trying to run someone off, then in post 2 you deny that, and make a serious accusation of Abuse? What is the problem here? What cant you understand that is getting you so upset?
  16. I will stick with my 12 steps, Works for me, and Dr bob.
  17. please explain. do oy mean use the mig to hold the pc's in place for forge welding ?
  18. funny how someone would think that, when as staff we can just remove a problem person. Mods are servants to IFI not rulers, but we have a job to keep information flowing smoothly. When a person asks questions they have no idea if a responder is an experienced smith, or a person just posting to see their own names. So we try to explain to them how to post here, when they don't listen, or read anything for themselves, then we have have to use other methods to resolve problems. Not all members are privy to all the issues here, so its understandable when someone misunderstands.
  19. not to high-jack.... but when I tested my new shops ventilator, a 22" fan mounted in a copula in the roof, I smoke bombed the place, and got a reading of 84ppm. then turned on the exhaust fan, and hit stop watch. 20 seconds to clear air. I am sure that a zero reading was sooner but I was not watching that, I was looking at stop watch and smoke cloud. I was impressed it cleared out so fast, in normal use I have never triggered anything above 0 ppm CO. As Ptree said its prevention we should focus on. I just included a back up plan. Please stay safe
  20. now I know where to look that steel up thanks
  21. try reading through the forum posts. here are some threads about flux http://www.iforgeiron.com/forum/f21/borax-flux-10872/ http://www.iforgeiron.com/forum/f21/borax-boric-acid-sand-9868/
  22. all this is in the knife sticky's here. Read and be enlightened.
  23. lol stuffed animals are for where I don't have a ground fire LOL amusing mental imagery there Warren :)
  24. Damascus Mike, I see 2 posts stating spec's and you post a wild guess? how is that going to help? If you would spend as much time reading post here as you do making so many yourself, you might learn something. Please stop posting gibberish, and read a few of the existing posts, you will be surprised what is listed here.
