9,163 -
Everything posted by Steve Sells
now its 1.25 x 16 x .2 inches at 120 layers, of wrought iron and Meteorite mix. So it looks like I got it. Even if I make the blade billet only 200 layers, this one' layering will be too fine to see any separate layers (equivalent of a 24,000 layer billet at this level because 200 billet layers x 120 meteorite)
Try here KNIFE LAWS of the 50 STATES I check here to see if an order complies before I make them to ship, the client may still want the blade, but I know that, they know the legal issues with it. In general most places accept a credit card as proof of age. But I am not a lawyer, that's my sisters job.
for everyone that is thinking of making a sword
Steve Sells replied to Aaron Gann's topic in Swordsmithing
It depends on your definition of Easy. I heat some steel, then I hammer it, then I grind it, its a sword. The details are in HOW. How to selet the steel, how to apply the hammer, how to use the grinder. That knowing how, comes from experience, the hammering itself does not change, nor does holding a piece of steel against the grinder. -
Click on the links we provided, if you can't do that how did you even get online to get registered here?
or rather than a copy, buy the real Hofi hammer. Here at IFI
4? Not sure that will last long for a real shop. I did 6.5, with 4500 mix. Also used 5/8 rebar on 3 ft centers... welcome to the heart ache of a new shop Dont ask us smiths about what is best in YOUR area, as soil varies. Ask construction people about what lasts, there WILL be major vibrations form power hammer, so a separate slab has advantages, and not much more $$ to get it right, also electrically bond the floor to the grounds.
maybe your idea of orange might have been my idea of red, because many tool steels don't like to get hit too cold, or they crack to let you know not to do that, Keep it hot, and dont try to get too many hits in it per heat, if it gets red, stop hammering.
need to remove spot rust, like on car bumper or wheel fender? Aluminum Foil, wet with tap water and rub it away. Works on the bike :)
Ao will never last long being used on steel.
Marble/Granite for handles
Steve Sells replied to coastalscouter's topic in Finish and Polish for Knives
yup, You drill it out, and then pin and epoxy same as with any other stone, but you gotta post pics:D -
Noobie:Pattern welding horseshoes
Steve Sells replied to Talon Tex Overland's topic in Problem Solving
hard to get enough heat with a torch. Grind the steel clean before placing the sections together Flux helps keep out air. Get it welded before twisting. -
so many in fact I merged them into one thread.
the blade is not a good idea. a credit card or other to scrape it off, NOT squish it, is the proffered way we are taught at EMT school
how about the yahoo group for home casting? HomeFoundry_and_Casting : Tools +Techniques for the Home Foundry
could we get Spielberg to direct?
This happens so much on topics that are already answered in reply's covered heavily in this forum as well as other places, its not like searching for the Grail , But I do have my Shrubberies just in case. :D
you have already been pointed to the sticky's so you must not have looked very hard, nor listen to the answers for the 167 other questions you have posted in the past 2 months. Start reading for your information, its all here, we are not your personal servants. hint: there is a sticky about choosing steels, we have a found steel chart http://www.iforgeiron.com/Blueprints-000-100/bp0002.html Or from a members web site http://atar.com/old/index.php?module=pagemaster&PAGE_user_op=view_page&PAGE_id=16&MMN_position=26:21
these Meteorites have no silicon. they are about 7% nickel, and about 1% total of Gallium, Iridium and Cobalt, the balance is Pure iron. By combining this with old wrought iron I added more iron to reduce the effects of the trace elements and bring back the nickel to a more manageable amount, it also added Silicon, from the wrought into the mix, making it stronger than the brittle meteorite was at the start. when buying one to use check its composition, you want solid block of iron (to the eye) not a rocky Iron Ore type. A magnet for a fast check cant hurt. but a lab analysis is not too much to ask for the prices they are getting. this is not a production run type thing LOL
[steve sells] whats up tonight? [MRobb]There we go [markb]You da boss [garey] sewing up sheaths. [MRobb] I'm just here to listen [markb] and learn [steve sells] me too funny aint it? I didnt get any shop work done today too much going on. [MRobb] 1 Um..............knives? [markb] Balance point? [sfDuck] I'm tinkin..........I'm tinkin [Nate.v] order of operations? [m_brothers] what are we talking about tonight? [steve sells] ok starting with balance, what bring that ip?" [sfDuck] Counter balance [steve sells] 1if a blade has good balance is feels lightin inthe hand ans it easer to use/control, if the balance is bad, its a blocky shuck of steel [markb] So is there a formula [steve sells] no clue I go my feel RICH HALE help ! [sfDuck] What about putting a counter balance on the end [garey] the shape of the handle and what handle is made of and how it fits YOUR hand makes a lot of the difference in balance [steve sells] one thing is called Distal Taper, the counter weight is after we do everything else to get it balanced. taper is the slimming of the steel, Distal means away, that translates to thinner at tip than at ghhe guard [m_brothers] You don't want to have a huge blade and tiny handle or small blade and huge handle. [steve sells] on a small knife its not to bad, but as a blade gets longer, onto sword, this can add up to over a pound of weight ( or not) moving the center of gravity of the blade [m_brothers] you know as you're forging. it kind of comes to you like steve said [steve sells] I had to work at it, lighter blades are faster to respond to the hand than heaver ones but knife size blades its not noticed as much, one reason I advise a potential sword maker to strt smal and do knives first [MRobb] Does the style of the blade influence this at all? [steve sells] Yes it does. In the forum a member mentioned a Machette [m_brothers] Like I just forged a small utility the other day, the blade is a bit beefier, 3/16" thick at the top of the spine, 3" blade, but then 5" handle, with distial taper, this really makes the blade balanced, and I can blanace it at the ricasso its a cross between axe, and large knife in structor and function [MRobb] Very stout [m_brothers] it's in rough ground, it'll be 1/8" thick when done, but it's an example. [steve sells] the ONLY reason I did the 3/16 fo rth eporject knife is the choipping function but its 1/8 only 2 inches from the guard anyway a smooth taper is prefered, as any drastic reduction is noticed as lumps in feel and the reflection in the shine [m_brothers] for knives, a great counter balance can be a butt-cap [markb] So balance is a product of feel and experience? [steve sells] I still use fine point magic marker. to tag teh blade so I have reference points, and yes mark [markb] there must be a balance point that can be calculated? [steve sells] I am sure there I, but I don't have it [sfDuck] Why just feel for it [steve sells] its probably covered in a thread over at Sword Forum [m_brothers] by balance point, do you mean perfect balance where the handle starts and the blade ends? [steve sells] how it feels in the hand is only part of it Also it effect how the blade vibrates when in contact with "Things" a small pocket knife its not noticable, but in a sword, its can shake [markb] No , where the blade moves in hand without heavy blade or handle [sfDuck] Where the whole knife will balence on a finger and not sway [steve sells] to the point of hurting the hand in a poor designed blade, to like cutting air, ins awell desiogned blade Most blades have the center of gravity a short t way in front of the guard... but its more than that [markb] Thats step one [steve sells] harmonic nodes, are a complex field of physics. and I don't feel qualified to attempt to explain as I dont know much about all te science behind it. most good blades are made to have the Neutral point of the vibration waves, In the place where the hand grips the handle of the blade, and another one is where the most contact occurs in cutting [sfDuck] How are your Nodes Steve [steve sells] mine are fine YOU guys asked, and as I said I dont know a lot so its harder to explain than a subject I am more experienced with [m_brothers] steve, how thick do leave the edge of the blade in rough grind before H/T, and do you quench vertical, horizontal, and what kind of quench? [steve sells] I hate to admit my weaknesses, but its the truth I aint the best person to cover harmonic balance, even tho I know what to look for I am sure I miss a lot in trying to explain it. [Rich Hale]: The eye and the feel tell a buyer all they want to know about a hunting knifes balance..if they do not like that way it looks feels or is finished it is automatically discounted for balance as well [steve sells] the most common term is to leave the edge the thickness of a DIME then after HT you can get a good edge, as you remove any area that may have lost carbon to migration in the HT [sfDuck] When you design a hilt for a sword, and you know the type of blade your making [steve sells] of course its all planned before I fire up the forge [sfDuck] Where do you start to design the hilt [steve sells] it has to be,, we covered that , and it became the project knife... Hilt for a sword it part of the sword sytle itself a Japanese sword, with a iron gross bar? LOL a roman gladius with the wide spanning claymore bars, with eyes? [sfDuck] So there is no wiggle room for hilt designs just look the type up and copy it [steve sells] most are part the the blade style. Ibut there is a lot of variation, that the cliwents call usually [sfDuck] Bear with me as I try to describe this [steve sells] but there is a recognisable style if you leave that, it wont be that style any longer, Thats ok if you want to have fun, but doing Historical repro's I try to stay close to style. [sfDuck] Where the blade goes through the hilt on the blade side [steve sells] I think that called a Hole [sfDuck] 10:35 pm: I've seen a kind of spear point or slot that almost images the blade [sfDuck] Then theres the hole How do you make this from one piece of steel [steve sells] IF you are talking about what I think the guard has a element that extends down the blade a bit [sfDuck] Yes [steve sells] the side profile is like a flattened W ? [markb] separate? [steve sells] the center peak is not as pronounced. I made the cross for the leaf blade, and I do have a pic, by hammering the wrought iron into a 3 inch block then thinning the outer sides I left it 3 inches in center, only narrowed and drew out the sides [sfDuck] Geez it would be nice to have a draw button on the chat so you could draw a pic [steve sells] then Punch and Slit toeh hole/slot for the tang, too bad no pics posted here IN this chat, I left it thick in the center after punching abd drifting to size, the ground away excess [sfDuck] Thats purty close [steve sells] k welding on after could work also, I wanted one piece because the pattern when I etch would show weld lines [sfDuck] The center point that the blade fits into could that be heated the blade set in and then hammered to get the egg act shape and fit [steve sells] so its a matter of what this client wanted, and I had to figure a way to for it the only problem with this one is Wrought iron for all fittings that does fit tight, it not exactly in place yet, as I will heat and hammer into final set after its all done a hot fit, no solder showing its great when we can get it. we should all aim for quality in our projects. but not all are perfect, Some we have to redo, others we may be able to uswe with adjustments [sfDuck] It just seems to catch my eye on a lot of knives or swords I've seen [steve sells] hammering wrought iron into the tip and collar and banding for the wood scabbard is a pain, I had to make forms and sweges that are not needed for cold working bronze start with a larger mass hammer close as you can, grind /cut away the excess part of it is knowing WHEN to remove too soon and we loose the holding points, or may loose mass needed for a forge weld. a guard also effects vibrations, and balance too. as with any good job, it all starts in the planning stage, before we light our fire [markb] The most important stage, learned the hard way [MRobb] Go through the whole project from start to finish in your head and work out the kinks. [steve sells] yup I have a old clip board in the shop pencil for drawings even partials for little ideas so I dont forget them I repeat nothing wrong with hammering to have fun but to have a usable blade takes a but more than just hammering I mentioned earlier I mark off the steel after forging, before I grind, so I have reference points How else can I keep the cutting edge centered or a choil balanced nothing wrong with "cheaters" or Helper marks" wee should use what we can to make our product the best, work smarter, use our best tool, our minds
How do you set a price on your work
Steve Sells replied to billp's topic in Blacksmithing, General Discussion
having been making blades fora while now, I have a sq in price for each pattern I do. plus the mountings etc, I built a database, so I am fairly consistent on final price, even tho one blade may occasional take longer or shorter. For non blade work I have a standard hourly shop rate plus materials. A reminder: when pricing your material remember your TIME to get and stock those as well as the delivery costs its easy to not remember until after the project is finished that you had an hour at the scrap yard for collecting those materials and putting them away, or the half hour in line at the supply house to get the welding rods and flux. That is all billable time when they are used. -
Most people think I am trying to talk them out of making a sword, when I tell them start small first. They see $1,000's for a pattern welded blade, they think "I can get rich doing this", It is too bad when people won't listen, it takes a lot of work to learn how to make a good sword. Even tho we try to provide a place to point out these and other issues, many won't bother to read here, or anywhere, because so many prefer their delusions to the reality that learning to do some things take a lot of hard work, unlike the Movies or video games like to show being done by hand in an afternoon. So they try anyway, then they soon surrender never to try again after failing so much. I hope you are not one of these as you appear to be reading this, and truly seem to want advise. If you keep trying, you will make a good one some day. -
The mother of all gorilla welds.
Steve Sells replied to Torin's topic in Welding/Fab General Discussion
I am not a welder, But I have welded, and I never allow Anything that looks like that out my door! Very sad, that a person that could tolerate that type of end product. -
just a passing comment as you probably just made a typo but Melting is what most of us do. Smelting is collecting/extracting the desired metals form the ore's, Not the same process or tools.
Welcome to I Forge Iron. Have a look around, read the beginning information listed to the right in the Home page, and join the chat to talk to other smiths live. Glad to have you here.
brass and bronze are easy Copper is NOT, it tends to clump in pure/near-pure form, even 10% additions of zink or tin makes a lot of difference in pouring. Also forget ever selling those ingots, as being transformed, there is NO easy way for buyers/recyclers to know what is in it. so offer a very low price, IF they will accept it at all and most won't.
