It followed me home
  • Replies 16.3k
  • JHCC
    1836
  • ThomasPowers
    1600
  • Frosty
    1204
  • Daswulf
    716
Brought home a new forge from the guild meeting last week. Got it for $40.00. It needed a new bottom plate. I put a 1/4" plate in it had it punched on a CNC machine at work. Got it in and welded and going to try it out this weekend.
You gave $40 for it?!
You must be quite the horse trader to work a deal like that. $30.00 is plainly written on the side! :o
Buy something from me?
Please? :P
Frosty Edited by Frosty
Back from Quad-State with: an early medieval stump anvil (modern repro, hardened and tempered!), a nose cone cone mandrel, a 5" post vise, die springs, zero carbon sheet steel, some thin SS strip, a twisting wrench, couple of socket chisels, high tech punch lube, memories and probably an extra couple of pounds.
These followed me home, They will be looking for new homes shortly, will post details in Blacksmiths Guild UK section, there are still more items to sort yet, including leg (post) vices, bench and floor drill, gas hearth, chain block, punches and stakes, cast iron firepot with clinker breaker, and other items
8660.attach
8661.attach
8662.attach
8663.attach
8664.attach
8665.attach
8666.attach
8667.attach
8668.attach
8669.attach
8670.attach
8671.attach
8672.attach
8673.attach
8674.attach
8675.attach
My wife and I got an invitation from friends who purchased the property next to them to pick up some concrete culverts that turned into another invitation to look thru some scrap metal. I got about a wheel barrow full and really didn't hit it all. There was a post vise buried in concrete that I was told wasn't up for grabs. Oh well.
I did get a nice bit that's almost 2ft long. A lot of the metal looks like it's galvanized so I didn't take it. Do you guys know if they galvanized plow parts. There are a couple in the attached pics.
Russell
8760.attach
8761.attach
8762.attach
8763.attach
Russel, I grew up in Goldthwaite, TX and have seen literally tons of old plow points and parts that did appeared to be galvanized. This appearance comes from the lime and alkalines in the ground. You can take a new plow disc and leave it on the ground for a couple of years and it will have this same look to it. You would think it was much older also. Everything in your photos are safe, no galvanize. Good score and very wise of you to leave the galv. stuff. If there was any pipe in the material you left it was most likely galv. also alot of old farms had windmills that the tower was made from galv. angle iron. But if it was old farm equipment you should be safe from the galv. Sorry for the length of this post.
