Rasper77 Posted September 8, 2009 Share Posted September 8, 2009 I was over at a friends house working on armor and he asked if I had any use for this.. Of course I said yeah! He said the guy who gave it to him said it was from a large drive shaft. Quote Link to comment Share on other sites More sharing options...
orgtwister Posted September 9, 2009 Share Posted September 9, 2009 picked up this forge with blower and anvil (170 pounds)for 250 bucks and about 10 buckets of coal not sure why the guy i got it from had a brakedrum in the forge the fire pot and clinker breaker are in perfect condition not sure of who made the anvil i have seen them before but can't remember so if anyone knows let me know i will get beter pics tomorrow these are the ones the guy selling them had the anvil has to mounting holes on the base and a tool steel plate Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 9, 2009 Share Posted September 9, 2009 (edited) The mounting holes and "clunky look" are indicative of a Fisher anvil, doe it have a loud ring or more of a thwap sound when you hammer on it? Fishers are a GREAT ANVIL and particularly good for working indoors or in thickly settled areas. Edited September 9, 2009 by ThomasPowers Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted September 9, 2009 Share Posted September 9, 2009 Nice looking Fisher you got there. Like Thomas says they are nice anvils to work on. I have a big one and it is a pleasue to use. Sounds like you got a good deal.:cool: Quote Link to comment Share on other sites More sharing options...
orgtwister Posted September 10, 2009 Share Posted September 10, 2009 thomas it does go kinda thud and heres beter pics of all the stuff we picked up me and my buddy split the buy he took the anvil as i have 2 anvils any way and he has none and i took the forge and coal some tongs a home made buffer and theres a pic of a big gate hook i forged out of stainless just cause i had to make it all work when we got itout of the truck at my buddys and for the stump it was just something we had its to small as you can see Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 10, 2009 Share Posted September 10, 2009 I've had these laying around for about 10 years, they are (were?) nuts from a pitman ram assembly on an Ajax 500C forging press. They were moving a frame at Ajax in Cleveland when I was on internship there, bumped another frame which fell off its blocking (about 6 inch fall) onto the nuts threaded onto their respective bolts. I got to cut these nuts off, and they let me keep them to present in class later that year. Let the jokes fly, I know you are thinking them. They are medium carbon, I think 1030, but might be wrong. I have no idea what to do with them since they are not clean paperweights. I'm open to suggestions. Phil Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted September 10, 2009 Share Posted September 10, 2009 ..... I have no idea what to do with them since they are not clean paperweights. I'm open to suggestions. Phil You could rub them with a 3M pad from the hardware or grocery store to remove the loose rust, then spray them with Clear Krylon Epoxy spray (or other brand) from your local MegaHugeMassiveMart. The spray will turn the rust black and allow you to use them as clean paperweights. Or you could weld/add pieces of metal and create a nut-cracking sculpture. :D Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 10, 2009 Share Posted September 10, 2009 One angle looks to still be intact, a 120 degree swage? Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 10, 2009 Share Posted September 10, 2009 120 degree outside swage crossed my mind, so was opening one up and having a texture swage. They are not fun to cut though, I only have abrasive cutoff wheels. I don't have a welder right now, and lack a large number of tools. They have been boxed up so long I begin to feel it is wasting the metal. I would rather not use them as sculpture, but later using them to _make_ sculpture might be a welcome possibility. I have so much to learn and reading is not enough anymore. Phil Quote Link to comment Share on other sites More sharing options...
orgtwister Posted September 24, 2009 Share Posted September 24, 2009 pickedup this vise today found on craigs list at first i thought it was repaired legvise with the leg missing but after seeing it it was made the way it is the plate that looks to be a repair is fited into the leg as it was made that way the guy i got it from said his dad got it from the brooklyn navy yard many years ago if anyone knows the make or what the proper name would be i would like to know anything about it Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted September 24, 2009 Share Posted September 24, 2009 pickedup this vise today found on craigs list ... make or what the proper name would be i would like to know anything about it It looks like a repaired leg vise to me too. The large side plate(s) look like a repair as that much metal for side plates is a bit excessive. Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted September 24, 2009 Share Posted September 24, 2009 Could be someone modified it for use in a hardy hole. Have thought of doing that with my spare(legless) vise. Ken Quote Link to comment Share on other sites More sharing options...
Thomas Dean Posted September 24, 2009 Share Posted September 24, 2009 Could be someone modified it for use in a hardy hole. Have thought of doing that with my spare(legless) vise. Ken If I did that I would have to have a step ladder to reach it! Or dig a hole to set it in.... Quote Link to comment Share on other sites More sharing options...
saddleboat Posted September 24, 2009 Share Posted September 24, 2009 A little mystery that followed me home. Quote Link to comment Share on other sites More sharing options...
MLMartin Posted September 24, 2009 Share Posted September 24, 2009 i bet that vice is made that way, ive seen a hand full of them come from over seas like that. seems to be a somewhat common thing lately Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 25, 2009 Share Posted September 25, 2009 Saddleboat, I may be quite wrong, but that looks quite a bit like the plug used for driving piping through earth and under structures. Often used for installing water line or gas line for the last few feet by the house to prevent digging up valuable landscaping. The one I used was a sharper point though, and a number of years ago. Phil Quote Link to comment Share on other sites More sharing options...
orgtwister Posted September 25, 2009 Share Posted September 25, 2009 on thing i forgot about the vise its huge its 25 inches high and weighs 80 pounds and i would love to see the anvil size that would have a 2 inch hardie to fit this if thats what the idea was and how tall you have to be to use it or like thomas said a step ladder saddleboat that looks like a old boring bit or boring mole like they use for big pipe or tunnels through dirt like going under roads i would bet that it is really hard Quote Link to comment Share on other sites More sharing options...
mite5255 Posted September 25, 2009 Share Posted September 25, 2009 local garage lets me scavenge through there scrap metal bin....this is what i brought home today .....the long shafts are 24 mm dia and 1.4 meters long.....the coils and leaf spring are off some sort of small truck same for the drum and disk Quote Link to comment Share on other sites More sharing options...
orgtwister Posted September 25, 2009 Share Posted September 25, 2009 (edited) looks like you got some good stuff there torsion bars are nice i don't find them here like i use to and as to your other post the torsion bars are spring steel from the front of old cars and 4x4 trucks Edited September 25, 2009 by orgtwister Quote Link to comment Share on other sites More sharing options...
Dale Russell Posted September 28, 2009 Share Posted September 28, 2009 (edited) G'Day all , just won this on ebay OZ Louie - the FLYpress 12 ton flypress Should come in handy too Dale Russell Edited September 28, 2009 by Dale Russell added stuff Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted September 28, 2009 Share Posted September 28, 2009 Bringin it to Moony's?? So we can play Quote Link to comment Share on other sites More sharing options...
Ratel10mm Posted September 28, 2009 Share Posted September 28, 2009 Yeah, yeah!! GREAT idea Rob! Congratulations Dale, it couldn't have gone to a better home - except mine of course! lol. I look forward to hearing exactly what tooling it's got - and how to make copies. Man, I'm really stoked for you!!! Quote Link to comment Share on other sites More sharing options...
gaylan veater Posted September 28, 2009 Share Posted September 28, 2009 Looks great Dale, I too would like to see the dies that it comes with or what you make for it. I too have a flypress but am just getting used to it and still making tools and dies.Nice find !!!! Gaylan Quote Link to comment Share on other sites More sharing options...
Mick Posted September 28, 2009 Share Posted September 28, 2009 G'Day all , just won this on ebay OZ Louie - the FLYpress 12 ton flypress Should come in handy too Dale Russell Hooley dooley, we get some big flies here in the Latrobe Valley, but they must be huuuuge over there in the Yarra Valley if'n ya need a 12 tonner to press em. Quote Link to comment Share on other sites More sharing options...
Ted T Posted September 28, 2009 Share Posted September 28, 2009 All Right Dale! All of us at T & L Forge are happy for ya! - - - - - - - - - - - - My Crew - - - - - - - - - - - - - - - - - - - - - - - - - :cool: Happy - - -George - - - - - -two Fingers - - - - and me We are all ImPRESSED with your new treasure!!!! Ted Throckmorton Quote Link to comment Share on other sites More sharing options...
