New and looking for advice
Reusing scrapped hammers is not an unknown method of making your own stake anvils. I've done a few that way my self and have a dozen more to do once the power hammer is working.  The spike drivers on the right are the types that were used for the stake anvils on the left
351686215_stake_anvils(2).jpg.b78faea9c233a771762e2ec8718351a8.jpg72312221_spikeboiler1.jpg.88abf25669692715b19783e67d279bd2.jpg
and the spike on my "traditional anvil"
  • Replies 458
They are reworked sledgehammer/ railroad hammers with heavy torsion bar for the shafts. The tortion bar was forged down to fit the eye of the hammer then peined down on the top. Then pointed on the bottom for the stake part
I have another where i just upset the hexagon end of a truck torsion bar and pointed the other end. It works but just for small stuff. The sledgehammer head has more area than it.
Just went scavenging in my grandfather's barn, tons of old broken farm tools he has no use for, got a head from a pickaxe, sledge hammer (I think a 15 pound?), and a rail hammer, a vice Clamp (this also has a flat striking surface), and some steel gears from some sort of vehicle, not sure if it's from a tractor or a car though, time to assemble me am anvil! I'll provide pictures of my haul so I can get some advice on what to include in the anvil and what to leave for stock material
The flat surface on the vise is NOT an anvil, it only looks like one and is NOT suitable for work much heavier than straightening nails. They're a legacy from a time when you could buy "complete" blacksmith shops in one thing, vise anvil, forge, grinder, etc. in the Sears and other catalogues.
We'd like to see some pics of the haul. We might have trouble believing it otherwise.:rolleyes: We're like that, yeah we are.
Drill and chisel out a depression in a stump to fit that sledgehammer head and you have an anvil.
That pickaxe, depending could be mounted as a bickern. I have also cut one half off and forged it into a hammer/top tool eye drift. it all depends on the size and shape and what tool you need/want more. I have a bunch of pick axes as possible stock.
Here is my first Scavanging Haul from my grand dad's out of commission farm, I dont actually know what some of it is, and I'd love to know what to use for anvil and what to use for stock.
BTW, what the heck is the thing on the far left of the bottom shelf
The big sledgehammer head on the lower right should make a good anvil. The RR hammer could make a good stake anvil at some point; definitely worth hang onto. The spikes on the pickaxe head make hammer eye drifts. You don't want to go hammering on that vise, but you can either use it for filing, drilling, and such like, or you could clean it up, sell it, and use the proceeds for tools, steel, and fuel. The angle grinder should come in useful, but PUT THE GUARD BACK ON!!!!
Looks like there a couple of useful pieces of stock, but don't put anything galvanized in the fire.
That "bacon press" looks interesting, but if it's cast, it might not stand up to hammering.
The angle Grinder actually did not have a guard. So I will probably have to find one for it, the bacon press, all I really know about it is that it's really heavy, I'm comparing it to a 30 lb bag of dog food I bought today and it is certainly heftier, it's not perfectly flat on the bottom, in fact it seems to have legs, I'm going to test the pipe in vinegar to check for Zinc, the gears I thought would be useful, I have my eye on that squar bar of metal, and any suggestions for the pickaxe if not for anvils part? It's most likely tool steel right? MC?
No it wouldn't work as an anvil because of the lack of mass under the flat of it. As it sits, (If it is steel but may be cast and at risk to break,)  it Might make a usable fuller. Don't know what it was but might be useful.
The sledgehammer head is the best anvil in the lot.
I've made a fun spider using a spider gear like in front of the grinder.
Yes you could. It might be useful for other things as well. You haven't visited me yet so who knows. It goes in the possibilities pile till you are ready and committed to the project. Just don't jump the gun cutting things up because you can before you are committed to a project trying to use it. You may find a better use for the piece as is and better stock for the project you had initially planned.
Remember "tool steel" is a large group of alloys with quite a range in content. One type is not necessarily good for universal use.
I like punches and drifts from pickaxe ends.  I have seen some miners' picks that sparked as HC; but don't have the heart to mess up the "local history".  If I find one like that with a busted eye I might use the HC for a blade or 6...
It is also easy to confuse mold lines with drop forging lines although they are very different processes.
On the subject of alloys, I have submerged half of the short pipe in the picture in white Vinegar and there has been no change on the surface appearance and there is no evidence of anything coming off in the container, I also tried to stick a magnet to it and the magnet did not seem interested, do I assume stainless steel and the Shiney silver color is from Chromium, or do I assume the pipe is Aluminum?
Also, any additional insight on that mystery object? At this point I just want to know what the heck it is even if it isn't forgable lol
Weight plays a factor in determining. Also spark test.
If it is heavy like steel then may be stainless. If it is lighter then steel may be aluminum.
Aluminum will not spark, stainless will. You could actually scrape aluminum on concrete and see if it grinds away. If it is light like aluminum but looks chrome sometimes it is brass. Scraping on concrete/rough rock will show a yellow color for coated brass.
Honestly in the picture if it is the ovaled piece of pipe it "looks" like stainless.
And vinegar will have little to no effect on chrome. Usually pipe may just be chromed on the outside, but if in doubt, don't bother and throw it in the scrap pile.
Update on mystery object, I had my brother-in-law post a picture of it in an antique forum and if he is correct it is basically an anchor, but for horses, a portable hitching post to deter your caravan or carriage horse from wandering off
Unfortunately this would most likely be a cast iron piece if that is true, still very interesting
