December 11, 20214 yr Here's the trench from my first JABOD and I used it until the box fell apart from being outside. It lasted well over a year. Pnut 2 hours ago, Frosty said: If you're using charcoal you can BBQ over a JABOD. Frosty The Lucky I have a grate that I throw on my JABOD to cook a couple cheesy mets as I pack everything up and the charcoal is burning out. It's become a tradition I suppose. Pnut How's everyone been by the way? I haven't had a consistent device to use to log on to the internet lately.
December 11, 20214 yr Author I am using charcoal, I know it burns up quicker but it should still work fine, it was used for centuries before coal became commonplace after all
December 11, 20214 yr I use charcoal more than any other fuel. It's what I prefer for my location. Charcoal is a great fuel especially if you have a source of free scrap wood to make your own. Pnut
December 11, 20214 yr 3 hours ago, Iron Fangs said: going to try to make a set of Tongs STRONGLY recommend starting off with something less complicated.
December 11, 20214 yr Letter openers, hooks, nails, bottle openers. Punches, chisels, drifts. Investing in a couple of good pairs of tongs is money very spent. If you want a less expensive alternative, look at the precut tong blanks from Ken's on line. Remember: if you can’t hold it, you can’t hit it.
December 12, 20214 yr Author Here are some of the longer stock pieces I have, I'm thinking I can use the thinner round piece to make a punch and chisel, I think I'll save the flat piece for a set of Tongs later, it's similar to what I saw used in a black bear forge video (thank you to Daswulf for the round stock pieces)
December 12, 20214 yr If we hadn't run out of time I'd have sent you home with more. time flies when you're having fun. Stop out again and we can raid my outside scrap. Or just go right to tag teaming some tongs. Sorry we didn't but I don't jump into that at first and start off with some basics. Plus I needed some refreshers on making tongs. It won't hurt to attempt some tongs. Worst case is failure, and you can try again later. But it will be a learning curve with a first firing of a jabod, trying to see how it goes and works out. And first use of your setup. Do you have a punch to punch the hole for the rivet? Could start straightening some of that coil spring to forge a punch. Its all tough starting out. You build your knowledge and skill as you go. No problem really jumping in. Just be safe about it and its all good.
December 12, 20214 yr I agree. You dont have anything to lose and a lot of experience to gain. Worst case scenario is you will have a nice first addition to your scrap pile.
December 12, 20214 yr Author Test run on my forge I have come to 2 conclusions: 1) my jobd is fully functional 2) my anvil needs work, the stand is off balance and falls over after 2 hits of the hammer Solution: balance with legs made of 2x4
December 12, 20214 yr Author Also, I have a question about grill forges, and this might be a ridiculous question. But is it easier to use a charcoal grill rather thsn converting a propane one into a solid fuel forge? They're made of the same material right?
December 12, 20214 yr The grill is just a stand/platform for a forge. It is only mentioned as they can usually be found for free discarded in the trash and already have legs, sometimes some wheels and some tin. Think of it as a premade forge table. The tin on them is on the thinner side. They could be turned into a bottom blast with a heavier thicker forge pot or filled with dirt, sand/clay mix to make a side blast. No grill is really better or worse its just a matter of how you want to utilize it to make a forge. Neither would hold up to the forging heat without a fire pot of some kind. So its all about how you can utilize one to suit your needs.
December 13, 20214 yr Clay can shrink and crack if it has too much water when you put it in. A mixture of clay and sand with as little water as possible is better: less shrinkage. Stainless steel is overkill for a forge, but a stainless steel beer keg makes a great slack tub.
December 13, 20214 yr Author I was thinking already kiln dried ceramic clay as a pot, I was also thinking a stainless steel cookie sheet my wife hates as a shelf for converting a propane grill, thoughts?
December 13, 20214 yr A scrounged or salvaged BBQ grill is a box on a stand you use for a JABOD. You don't actually use the grill from one unless you're grilling steaks after the session or burgers for lunch. I don't know of a pottery type ceramic that won't melt in a blown charcoal fire. Bentonite is a very high fire clay, it's the mud used to close the tap hole in iron melters. A mixture of 3pts sand, grog, etc. to 1 pt. bentonite with just enough moisture to ram hard. will produce a mixture that can be rammed hard and withstand solid fuel forge temps. Frosty The Lucky
December 13, 20214 yr Author Bentonite is the clay cat litter is made of right? Cause I have cats and that is on my shopping list about twice a month anyway
December 13, 20214 yr Author So if I went with that recepie if I used a can to measure. That would be one can of the litter and three cans of sand? And would paving sand work? I have a surplus but it's kinda course
December 13, 20214 yr You'll want to powder kitty litter so it mixes evenly with the sand or grog and don't use a lot of water. JUST enough you can squeeze a lump in your fist without it leaving it dirty. Bentonite takes time to temper, add moisture, mix, cover and let sit overnight at least and test. (squeeze) if it crumbles it wants a LITTLE more water, just a sprinkle, mix and temper over night. If it leaves streaks on your palms it's a little too wet, add a LITTLE more (sand/grog, bentonite), mix and temper. That's the basic game but you aren't mixing and tempering "molding" green sand so close is good enough. Just remember, if you make mud it WILL shrink check as it dries and form cracks. Frosty The Lucky
December 13, 20214 yr Id think play sand might be better but it wouldnt be hard to screen out any overly large chunks. I do not know if that sand has any chunks that could spall with enough heat. If it wouldn't spall with heat it is a "try it and let us know how it worked" kind of thing.
