GrayCat Posted March 6, 2021 Share Posted March 6, 2021 Hey everyone, so far I’ve been using pretty decent sized chunks of leaf spring, or pre bought and rolled knife steel (1095, 1.5x12”, 1/4” thick). I am starting to forge weld and get into Damascus. First couple billets will be a combo mild steel and spring steel, all 1/8-1/4” and all about 2.5” long. My question is roughly, how big of a billet would I need to make a 8” full tang drop point? That’s total length btw not an 8” blade. just trying to wrap my head around how many layers I would need to do once I get the confidence to step up to 1095 and 15n20 billets Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 6, 2021 Share Posted March 6, 2021 Weigh the knife you want to make and add 50% minimum. You might consider making some small billets until you master forge welding. Heating and soaking are touchier the larger the billet unless you're going to encase it in mild steel. Even then. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
GrayCat Posted March 6, 2021 Author Share Posted March 6, 2021 Good tip Frosty, I’ve already made a similar one so I can weigh it easy. Def starting with smaller ones and using some mild and scrap I have laying around until I get the hang of it. Save the good stuff Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 7, 2021 Share Posted March 7, 2021 If you do a fancy pattern you may lose a lot of weight to scale. Some patterns only appear when they are heavily ground and so are more like stock removal knives and the starting point to grinding may be double the end knife. If you are good forging then a knife forged to shape may have little grinding. I'd suggest starting with a billet twice the weight of a finished blade and not being surprised if you end up with a smaller blade than expected. Quote Link to comment Share on other sites More sharing options...
JPH Posted March 13, 2021 Share Posted March 13, 2021 I know this may not be the answer you are looking for but I have found that I get better results in welding larger sized bundles..I start with 1 1/4" x 1 1/4" by 12" to 18"..(plus I use sheet/shim stock and weld anywhere from 30 to 70 or so pieces the first weld.)...this is a decent amount of material..at least for me and it allows for enough laminate for me to make just about any pattern I wish..plus if I have any excess I simply set it aside for another project..Last time I checked steel usually doesn't go stale.. JPH Quote Link to comment Share on other sites More sharing options...
George N. M. Posted March 13, 2021 Share Posted March 13, 2021 JPH, I'm guessing that you do not weld a billet of that size with a hand hammer. Do you use a power hammer, hydraulic press, fly press, or what? From the very clean and even finished billet I am going to guess a hydraulic press. Also, do you have any comments on tying the billet together with wire vs. tack welding it? "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted March 13, 2021 Share Posted March 13, 2021 why do you think he doesnt use a hand hammer? I do and my billets are 1 x 1 and 12 to 16 inch long Quote Link to comment Share on other sites More sharing options...
JPH Posted March 13, 2021 Share Posted March 13, 2021 Geo.. Did you see that 8 pound hammer next to that welded billet?? That is the hammer I use and have used for the last 35 years or so since I worked up to that weight from my 6# one.. As far as wire and tongs vs welding and welding on a "handle"..I use wire as the way I work a handle would only get in the way. By not having a thingy sticking out off of one end I can simply reverse the piece in my forge as continue working section by section.. I am a wee bit old fashioned in a lot of ways... JPH Quote Link to comment Share on other sites More sharing options...
George N. M. Posted March 14, 2021 Share Posted March 14, 2021 J, thanks. It just goes to prove that you are a better welder and knife maker than I ever will be. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
JPH Posted March 14, 2021 Share Posted March 14, 2021 GNM: You have got to remember that I have been doing this stuff for 50 years..experience means a lot in this line of work..and believe me..I have made more than my share of mistakes and had a lot of things that didn't work out right.. JPH Quote Link to comment Share on other sites More sharing options...
FlatLiner Posted March 15, 2021 Share Posted March 15, 2021 JHP, Is there any particular place you like to buy your steel from? Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 15, 2021 Share Posted March 15, 2021 That one I have to question Jim. I find it hard to believe you've made MORE than your share of mistakes, plenty to be sure but I doubt more than your share. I don't think we're counting experiments that didn't work, those aren't mistakes, knowing what doesn't work is valuable information. I see native talent for bladesmithing in you, what I like to call a knack that lends you an above average feel or sense or whatever for making blades. I'm betting YOUR share of mistakes is considerably smaller than the average share. Give it 50+ years to mature and I'll bet a mistake is a real head slapper. Not arguing, just pointing out there are natural talents at work in everybody but not matter how strong your knack you have to exercise it for it to grow into something good. I do have a 8lb. single jack hammer but the one I use is a double jack. The single jack came as a take it or leave it all deal at a yard sale. I tried it out on time and it hurt me, almost a weak before my wrist stopped hurting. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted March 15, 2021 Share Posted March 15, 2021 On 3/6/2021 at 4:32 PM, GrayCat said: First couple billets will be a combo mild steel and spring steel, This may not give you good steel for a knife. If the spring steel is 5160, or has close to the same carbon content, and you combine that with mild steel which may have around 20 points of carbon, with evenly distributed carbon migration you'd end up with something around 40 points of carbon - assuming you are using equal amounts of each starting material. You'll probably also lose a little carbon in the process of forge welding. The end result could be squarely in the medium carbon range, which will harden but is typically not considered good for edge retention. Since creating pattern welded billets is so labor and time intensive I assume you'd prefer to end up with something that will make a decent knife when you get done. Quote Link to comment Share on other sites More sharing options...
Frazer Posted March 16, 2021 Share Posted March 16, 2021 (edited) Not to mention the contrast between spring steel and mild is not very eye catching at all. It's primarily the difference in carbon content that you see in the etch. The more heats you take, the more carbon migration you get so the lines between the two steels get all washed out. If you're doing to try it, I would definitely make a small billet and get it up to the layer count you are going for. Then see if you're comfortable with the pattern you get. Or just swap out the mild for something with some Ni content (15N20 is the most common example). I'm with Buzzkill on this one, it might make a cool letter opener or decorative piece for another project, but I'm not convinced you'll end up with a knife that was worth all that effort. Edit: That is unless you juice up the billet with some high carbon steel (I have some old files that are 1+% carbon that I keep around for stuff like that). You can weld a thinner piece into the center to make a monosteel cutting edge. Just a thought. Edited March 16, 2021 by Frazer Added afterthought. Quote Link to comment Share on other sites More sharing options...
LeeJustice Posted March 18, 2021 Share Posted March 18, 2021 What I understood from the OP's posts is that they are not expecting to get a functional knife...yet. They want to practice the technique on some inexpensive steel , so as not to drop a lot of coin in refining that technique. I can totally see doing so, I am not wealthy either. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 18, 2021 Share Posted March 18, 2021 However if they do get an example of "Beginner's Luck" it would be nice to be able to end up with a knife and not a letter opener. As the time in knifemaking is generally heavily slanted in the grinding/finishing/hilting end; working with appropriate materials is really pretty cheap. Quote Link to comment Share on other sites More sharing options...
JPH Posted March 22, 2021 Share Posted March 22, 2021 (edited) FL: I get my steel from two places mostly.. Pacific Machine and tool Steel in Oregon xxxxxxxxx or Security Steel in MI xxxxxxxxxx Telephone numbers are not allowed Hope this helps. jph Edited March 22, 2021 by Mod30 Remove phone numbers. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted March 23, 2021 Share Posted March 23, 2021 On 3/18/2021 at 3:23 PM, LeeJustice said: What I understood from the OP's posts is that they are not expecting to get a functional knife...yet. They want to practice the technique on some inexpensive steel , so as not to drop a lot of coin in refining that technique. I can totally see doing so, I am not wealthy either. I suspect most of us on here have had the same thoughts. It's a bit of a trap though. After a while I think most of us have concluded that it's actually cheaper in the long run to purchase known new steel for things like blades. A lot of times steel we get for free ends up costing us more in the long run, especially in the time and fuel areas. For knives I've found that the cost of the steel is insignificant compared to the fuel, abrasives, pins, glues, etc. There is something to be said for practicing techniques to improve them of course, but practice is usually best done with the materials that the finished product will be made from. For instance if you wanted to enter an archery competition and you decided to practice with a 45 pound draw bow although your intention was to use a 60 pound draw weight in competition, you would get some benefit - but you'd get more benefit by practicing with the one you'd use in the end. In this case a successful pattern welded billet is a source of joy when starting out, no doubt about it. However, that joy is even greater if you can turn that billet into something you can sell or use and be proud of. All that to say I recommend practicing with materials you intend to use in finished products. It seems a little daunting at first, but forge welding short, straight, flat pieces of high carbon steel really isn't that difficult to accomplish. If all mating surfaces are clean and shiny, the right temperature is attained, oxidizing flames are avoided, and firm "dead blow" strikes are used, the success rate should be very high. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 23, 2021 Share Posted March 23, 2021 BK, my analogy is that you don't learn much about baking an apple pie making mud pies! Quote Link to comment Share on other sites More sharing options...
