January 8, 20206 yr I'm looking into sending out a few pieces of steel to get tested and would like to know what the best method to ask for. I know that LECO only tests for carbon, sulfur, nitrogen, oxygen and hydrogen so that's out. ICP testing wont show carbon so thats out. So far OES testing seems to be on track. What else is there?
January 8, 20206 yr What do you want to test for? I generally like OES if you have access to someplace that can do it for you reasonably.
January 8, 20206 yr Gas chromatography is the only way to test for everything, as you advocated in this thread
January 8, 20206 yr Well wet bench analysis will still test for a lot of stuff---if you are willing to pay! (Presence is cheaper than amount though.)
January 9, 20206 yr Good Morning, No, you didn't advocate any testing methods. Nor did you be specific about what kind of testing you wished to achieve. just $0.02 worth Neil
January 9, 20206 yr How far out do you want to go? Are elements that are just a couple of atoms per sample important? Typically samples get tested for several large components and a lot of the little stuff is considered "trash". However the modern research on Wootz has shown that some of those "trash" elements actually played a major part in making it wootz.
January 9, 20206 yr Author I just want to get my heat treatment right when I'm making hammers. Forklift fork, some 3 inch round I have and some 2 inch x 9 foot rods with threaded ends.
January 9, 20206 yr OES, portable system should work. You probably only need the "common" elements tested for unless you get weird alloys to play with. Some scrapyards use them.
January 10, 20206 yr That's Optical Emission Spectroscopy, for the uninitiated. Another testing method is XRF (X-Ray Florescence), which is also used by scrapyards. The yard I occasionally take scrap to has an XRF gun which not only gives elemental measurements, but also the appropriate SAE alloy number.
January 11, 20206 yr Author So I was quoted $600 for 4 samples. A bit more than I was hoping to pay but would be worth it in the end. I also found a place that will use there XRF gun for 49.99 per sample. I will probably go that route. I'm not messing with any crazy alloys so that should serve me OK.
January 12, 20206 yr the free method is to ask River Gazer to touch or taste it for you, He used to visit here often
January 12, 20206 yr You are guessing that testing one fork is the same for all forks, it is not. Each can be different according to what mix the manufacture wanted when the fork was make.
January 12, 20206 yr Author I have 2 sets of forks and 1200 lbs of the 2 inch round. And about 300 lbs of the 3 inch round. I understand not all forks are created equal and that's why I'm getting both sets tested!
