January 16, 20197 yr Rebar can be a pain, but it does make good snakes. I usually use threaded rod for these, as it is much easier to work and I hate drawing out tails in 1/2 inch rebar. But the rebar scales look good. Could we see some more snakes? Files? Stainless? Textured? Whatever?
January 16, 20197 yr Author Can't recall if I have posted this before, but these are the usual threaded rod cobras. Much easier to work than rebar.
January 17, 20197 yr Rasptle snakes---shake them right and they sound a lot like the "organic" ones; I can attest from experience!
January 17, 20197 yr Author Nice rasp snakes, IF and TP. I have only tried that once - very tricky to keep the fold in the rasp straight. Finished up in the scrap.
January 17, 20197 yr Naw you stick it in a vise and twist it in line with a pipe wrench...I also have several swages I use for doing the curve in, that seems to help me vs using the step on the anvil. I had some old worn light duty pipe wrenches show up in a box of stuff I bought at a garage sale. I had much better ones for plumbing use and when I was trying to line up the seam in the early days I thought of them...
January 17, 20197 yr didn't know this was a thing, ok definitely need a how to reference on this someone PM me
January 17, 20197 yr "Holding the live rattle snake in your left hand, compare it to the workpiece in your right hand; adjust till they resemble each other...) For a rasptle snake: See picture with the steps demonstrated above 1. source a cheap/free used farrier's rasp---I don't pay more than US$1 2. draw out the tang and un cut section just before the tang---the file's ricasso 3. shape the head; I don't do the punching till later 4. using a swage or the anvil step and a cross peen hammer star-t curving the body, coarse side out. 5. continue to work the body around using the swage to help the bottom curl while you are curling the top with a hammer. 6. work the edges in till the touch and the body is a cylinder 7. using the postvise and a small pipe wrench adjust the body till the seam is straight 8. Flatten the body a bit if you like. 9. open the post vise jaws several inches and slip the heated snake's head in under the back jaw and over the front jaw. Slip a large section of pipe over the tail and down to near the front vise jaw and use the pipe as a lever to bend the snake into a curve. Reheat the body as needed and flip the snake over and insert it till the previous bend locks under the back jaw and put the pipe on and bend the other way. Repeat as wanted. Flatten/adjust with a wooden or rawhide mallet. 10. punch the facial features. 11. bend tail up; let cool slowly and smooth the tail a bit if needed. I punch the bottle caps with a flat bottomed punch on end grain scrap wood, they should fit loosely on the tail. Leaving room for them to move when shaken bend over the tip of the tail to hold them in place. 12. finish the snake (wax, blo, paint, clear coat, etc leaving the bottle caps alone)
April 4, 20197 yr Author Found a couple of long 1/2 wrought iron bolts. I always have difficulty with wrought so thought it would be a challenge to forge a snake. Kept it really hot and managed OK with only a minimal amount of delaminating (Pic 1. I thought it may have been a fluke so forged a second one and it went well. So the real challenge was to forge a cobra without splitting open the hood. I wrecked one but the second go was OK. Wet season here so very few visitors to the forge - a chance to use demo time to try things that are not guaranteed to work! Here are the three:
April 4, 20197 yr Nice snakes Aus. I've only messed with WI a couple times and its a real challenge to remember how hot it has to be to successfully forge. The upside is when it starts to delam it welds back together fairly easily. My first go was a carving fork and one of the tine ends literally splintered at a medium orange heat. It welded back together easily enough but I had to work fork tines at sparking heat! They were smaller than wire, pitch fork times. They split out from the main body easily but HOLY MOLY it was A PITA! Fork turned out nice enough and served nicely to carve the roast pig, another attendee at the Shindig forged the carving knife from a spring. In less than half the time start to finish! Nice snakes Aus, I feel your PITAedness Brother. Frosty The Lucky.
April 4, 20197 yr I have no trouble with that: heat the entire snake to forging temp. Put it on my large anvil. Put a piece of 2"x6" over it and SMACK it with a sledge hammer---or else do the same with my screw press. Or heat it up and using a rawhide mallet go over it truing to the anvil face. Curled ones I can use a "bolster plate" and flatten to that with the head going through the hole.
April 4, 20197 yr Author Yes, they must sit level. My work anvil is not perfectly flat so I set the hot snake on a heavy flat length of timber and tap it level.
April 11, 20197 yr Author Well, you upset the end of the bar to give some mass, and then forge the head shape hammering back towards you. Using a ball pein hammer, widen out the bar just behind the head and then push the steel outwards on each side, trying to leave a ridge in the middle for the throat. I try not to overwork it, as I like the stretched scales across the back of the hood. (That's if you're using threaded rod, of course.) And I always punch the eyes before forming the hood. Much easier that way. Practise widening a piece of scrap bar before you forge a snake.
April 11, 20197 yr Thank you Ausfire. There is a busted cable spool at work that has four three foot long bolts on it that my boss said i can have. I have been trying to think of what I could do with that.... and those snakes look like they could definitely be the ticket!!
April 11, 20197 yr Author Yep, great snake material. Looking forward to the photos, Ben. PS. I like your dog. Is that a Sheltie??
April 21, 20197 yr A couple of snakes I made a while ago when I was given some 32mm rebar. both are about 1500mm long and I made the flat one first as a "what can I do with this exercise". The wearable one was made next because my son wanted something he could wander around with and scare people. He (the snake) has had his picture taken with lots of people since.
May 24, 20197 yr I like those big ones! I've got some 1" or 1 1/4" rebar. Might be fun to make a 3 ft snake
May 25, 20197 yr Author I have done a couple of 32mm rebar snakes too, but what a pain it is drawing out the tail. Definitely power hammer country. I keep one on display near my forge all the time and sometimes visitors take a backward step. The best one I made from 32mm was about 1200mm in length and it was stolen from an art exhibition.
