M.J.Lampert Posted May 20, 2021 Share Posted May 20, 2021 not sure bout the rest of you but i cant see the original post photos others show up but not the first M.J.Lampert Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 20, 2021 Share Posted May 20, 2021 These were probably among the thousands of photos that were lost or buried or something when the OS was changed Admin and crew have been working the problem it involves some major coding so it's a career job for the boys. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
M.J.Lampert Posted May 21, 2021 Share Posted May 21, 2021 ok the evil updates Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 21, 2021 Share Posted May 21, 2021 Yes I think it's possible to use the terms "unwanted forced updates" in place of cussing here.... Quote Link to comment Share on other sites More sharing options...
SinDoc Posted May 21, 2021 Share Posted May 21, 2021 While I have built a database from the ground up for my work place, I am not a coder but fully understand the pains caused by forced updates. Nothing like trying to find the newly broken reference in your 20+ pages of code. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 21, 2021 Share Posted May 21, 2021 When I was getting my CIS degree, they told us that the average number of new bugs caused by fixing one bug in the system was 6. Hence my preference for NOT being an early adopter and my dislike of systems that force updates for things you don't use, breaking stuff you do use. Quote Link to comment Share on other sites More sharing options...
SinDoc Posted May 21, 2021 Share Posted May 21, 2021 Yup. When I was writing all my code for the database and doing updates, bugs would pop up that weren't even directly related to what I was updating! Almost makes you go cross eyed. 99 little bugs in the code, 99 little bugs. Take one down and patch it around. 107 little bugs in the code! Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 22, 2021 Share Posted May 22, 2021 If it ain't broke, we will fix it until it is. Quote Link to comment Share on other sites More sharing options...
Everything Mac Posted December 8, 2022 Author Share Posted December 8, 2022 So I figured I'd update this. First of all I want to make it very clear that if you’re just starting out in blacksmithing you DO NOT NEED a “London Pattern anvil” to start hitting hot metal on. London pattern anvils are usually very expensive (your location in the world makes a big difference) not to mention relatively rare and hard to find. All too often I see posts on forums or Facebook where a new smith has spent all of their spare cash because they “HAD” to have an anvil. A large sledge hammer head, a section of rail track mounted vertically (more mass under the hammer) or any large chunk of scrap steel will make a perfectly serviceable anvil. Some are even better than a “real” anvil for one reason or another. Also I’d like to make it very clear that this guide is aimed at newcomers to the craft and not seasoned smiths. Also I’d like to note I’ve copied these images from the internet. All rights go to their respective owners. If you have an anvil that looks similar to the ones I’ve shown then please post them here so that we can use images from forum members. If anyone has issue with me using their image please let me know so I can take it down. So this is the anatomy of an anvil: Firstly lets look at a “Perfect” Anvil. This is a brand new Refflinghaus anvil - The face is perfectly flat. The edges are straight and crisp. There’s nothing broken or missing. A wonderful tool. Chances are that the anvil you are going to look at is very unlikely to look like the above. If it does you are either a) incredibly lucky or spending a great deal of money. Which is absolutely fine either way. So you’ve saved up a wad of cash and have found an anvil within reasonable collecting distance. What do you need to know and what should you be looking for? When going to view an anvil you need to bring a testing kit with you. You will need: A hammer A 1” ball bearing A ruler. (preferably metal) A scraper if the anvil is covered in paint. More on all that later. RULE NUMBER ONE: ALWAYS TAKE CASH WITH YOU AND BRING MORE THAN THE COST OF THE ANVIL!!!! The seller might have something else tucked away and be willing to do a deal. Step 1: Figure out what it’s made of. The first thing for me would be to work out what it is made from. Generally speaking it really doesn’t matter at all. The only real thing you need to discern is whether or not it is made of cast iron. (the bad kind) Just for your knowledge though: There are several materials anvils can be made from - in no particular order. Wrought iron body with welded steel face. The oldest construction method of the bunch. These anvils have a forged wrought iron body with a steel face welded to the top. There are numerous British and American makers that used this method and it makes a superb anvil. The fact that so many survive today is a testament to the quality of their construction methods. - Older anvils had the face plate made up of several different pieces of steel, as steel was harder to make in large sections. Notable makers include Mousehole Forge, Peter Wright, Hill, Isaac Nash, Henry Wright, Wilkinsons and many others. All forged anvils have identifying features that give away their construction. The most obvious is the presence of handling holes at the waste of the anvil and often a handling hole under the base of the anvil. This is where large tongs gripped the body while it was forged. Another indication of forged construction is having a stamped makers mark, depressed into the steel rather than raised out of it. I’ve inserted an image of a forged anvil. This is a Peter Wright. Notice the handling holes at the waste and under the base. Also note the extra handling hole in the feet, this is characteristic of Peter and Henry Wright anvils. You can also make out the stamp in the picture. Note the slight different colour along the edge of the anvil in the second picture. To me this suggests the edges have chipped and have been welded. This seems to be particularly common for Peter Wright anvils that were shipped aboard for some reason. Forged wrought iron anvils have two very common “faults” - “delamination” and “sway”. More on these later. Another thing to note here is that I often see beginners try to identify anvils for one another on Facebook with some very strong opinions on what the anvil “DEFINITELY” is. If you are trying to identify an anvil with no clear markings I would suggest asking the forum. There are too many armchair experts out there who quite frankly have absolutely no clue what they are talking about. Without clear markings or certain identifying features it is very difficult to say an anvil is 100% one brand or other. Don't forget there were hundreds of forges making anvils at one point. Even now 6 years after writing this original post I still see new brands I have never even heard of. Case and point is that there were literally HUNDREDS of forges making anvils in Britain. Below is a forged English anvil. NOT ALL ENGLISH ANVILS ARE THE “MOUSEHOLE” BRAND. - A great many makers made anvils with the same features as Mousehole Forge. The above anvil shares all the features of a Mousehole but I don’t see a makers name. As such it is likely not made by Mousehole. You can actually clearly see the queens Dudley marking indicating this particular anvil is a Wilkinson. Note the distinct similarities with the shape of Mousehole anvils. Cast Steel - with technological advances and cheaper steel makers were able to cast entire anvils. Depending on the maker these can be hard to identify but will typically lack handling holes of any kind. - The biggest giveaway to a cast anvil is raised lettering on the body. Below is an image of a Brooks anvil. Note the parting line running centrally up the anvil and the raised lettering on the side. Cast anvils are generally less prone to sway, but it can happen. The issue many cast steel anvils have is chipped edges. More on this later. In the image below you can clearly see the parting line has been ground clean. Cast iron with welded steel face: (Henceforth called CISF) - There are several makers that constructed anvils in this way. Fisher, Badger, Star and Vulcan are the ones I know of though there may be a few more. These have a cast iron body with a steel face welded to it. Don’t ask me how they did it, as far as I know no one knows exactly how they did it. Either way it produces a perfectly good anvil. Though beware, Vulcan anvils are generally considered poorer quality as they had very thin face plates that were very likely to chip in use. Fisher face plates were quite hard I believe and are also prone to chipping. - It is worth noting that this method of construction produced an anvil which doesn’t “ring” and as such are relatively quiet. If the smith has concerns with noise, an anvil made this way would be a good investment. Below is an image of a Fisher anvil. Notice the raised numbers and makers mark indicating a cast anvil. If you are faced with an obviously cast anvil but do not recognise the makers mark, posting it to a Facebook group via your phone (assuming you have a smartphone) will often lead to a quick identification. HOWEVER google that maker yourself just to clarify it. You can clearly see the Fisher Eagle on this anvil along with the characteristic mounting points in the feet. Here is a Vulcan. Again clear indication of being a cast anvil with the raised lettering and rather helpful Vulcan logo. Cast ductile iron - the last of the decent anvil construction materials. Ductile iron is similar to cast iron but much much stronger. It makes for a relatively soft anvil but is vastly superior to cast iron. I believe only a few modern makers use ductile iron - they are made specifically for farriers. Below is an O’Dwyer farriers anvil. Identification of these should be rather easy. I believe newer Odwyer anvils are actually cast from 4140 steel. Cast iron: - Finally the worst of all the materials. Cast iron is brittle, weak and frankly an awful material to make an anvil from. These will dent and chip in use and should really only be considered if you honestly have no access to a large sledge hammer head or chunk of scrap steel. The money spent on a new cast iron anvil should easily cover the cost of a cheap hardware store sledge hammer which will serve you far better in the long run. Cast iron anvils come in several shapes and forms. They are very easy to spot once you know what you're looking at. The proportions of the anvil will be wrong. The horn will likely be either very short and stubby or flat. Or both. The overall shape often looks wrong and they will typically be very small in size. Less than 20lbs in most cases. Pictured are all cast iron junk anvils. Note that some cast iron anvils are marked USA. Which does not mean it is good quality. These anvils are all cast iron ASO's. Best to be avoided. Step 2. Start checking the anvil over. Visual inspection. Now assuming you’ve given the anvil a once over you’ve probably figured out what it is made from and you may have seen a makers mark. But try not to get too excited and hand over the cash. Now is the time to really check the anvil over. This is where you need to start your visual inspection of the anvil. How does it look? Does it look in good overall condition or is it chipped or swayed? Are there parts broken off? Ideally the anvil should be in as good condition as possible. But it is still a perfectly serviceable tool even with some significant damage. Sway: This is the name given to an anvil face that has become concave through use. This could be a combination of poor quality materials used to make the anvil. (wrought iron is rather soft) Or simply the scars left from years of heavy use. *It is interesting to note that Peter Wright anvils were made from high quality wrought iron, compared to other companies that used “Best Scrap” which inevitably had bits of steel in there too. As such the “Best Scrap” anvils were often a little tougher than the Peter Wright anvils. As such the early PW anvils would sway relatively easily; PW started making their faces very slightly concave to combat this. Sway in an anvil is not a problem, indeed some smiths prefer it. Excessive sway however should really be avoided if at all possible. Ideally is there is any sway it should be less than 1/8” over the length of the anvil face. Use your ruler to check for this. This anvil has some sway, Personally this is the most I could work with but some folks are perfectly happy with more sway. The anvil is in otherwise perfectly good condition and well worth having. This anvil however has excessive sway. The face has dipped significantly and even the heel has been bent. (I should really point out that I am spoiled for choice for anvils in the UK and there are enough available within driving distance that I can afford to be fussy. - personally I would pass on this anvil and keep looking. BUT if you’ve spent several years looking and this is all you’ve found then it is still a workable tool. Nothing has been broken off and the central part of the face appears to be relatively flat. The face plate also appears to be intact. Buy it if it’s cheap. Pass if not.) These days I personally do not tolerate any sway in my anvils and would not buy an anvil with any away for anything other than something to leave on the floor and upset bars on. Chipping and edges: All anvils can chip, cast steel and CISF anvils are particularly prone to it. As such there is a good chance the anvil you go to see will be at least slightly chipped somewhere. Whether or not this is an issue on the anvil varies dramatically. In short the less chips out of the edges of the anvil the better. BUT a chipped anvil face does not make it a bad anvil at all. Quite the contrary. Chips should be ground smooth and radiused with a flap disc on an angle grinder. This gives the smith some very useful surfaces to work on when forging. As with sway, a little chipping is not a problem at all. Almost all of the anvils I’ve owned have been at least a little chipped. Excessive chipping however should be avoided. This anvil below has chipped edges. In my opinion this is not excessive chipping and with some work with an angle grinder and a flap disc this is a perfectly usable anvil. Notice how the chips are limited to the outer edges of the face and do not extend into the face itself. Excess chipping would be where the chips extend deep into the face of the anvil itself or deep into the body of the anvil; so much so that grinding it back would require removing a significant amount of the anvil. Common sense should prevail here. Sharp edges: New smiths (Particularly American smiths) seem to be fascinated by the idea that anvils need to be perfectly flat and have perfect 90 degree edges. This is not the case. AT ALL. You really do not need sharp edges for 99% of forging processes. If a sharper edge is required then a hardy tool can be made for this job. Delaminating/ Delamination: This is only an issue for anvils where a separate face plate has been welded on. Nine times out of ten the weld was perfect, but you need to remember these were made by humans and some times mistakes did occur. Delamination is where the weld between the body and the face of the anvil has begun to fail. This can occur on just part of the face or across its entirety. Above is a perfect example of where a face plate has completely delaminated and broken off of the body of the anvil. Of course this does not always happen like this. Some times the delaminated area of the plate remains attached to the face plate but is detached from the anvil body. This is why it is important to check the entire face for ring and rebound. A delaminated plate will sound different; dead if you will, compared to the rest of the face. More on that below. Again common sense prevails. If 90% of the face plate is missing I would walk away. If a small portion at one corner has broken off and the rest appears to be ok, and the anvil is in otherwise good condition then you could still buy it. These days I am inclined to say that an anvil like the one pictured above is a perfect candidate for repair by welding. Welding an anvil: DO NOT EVEN CONSIDER THIS IF YOU ARE NOT A HIGHLY COMPETENT WELDER. If in doubt don’t buy the anvil and walk away. Anvils can be repaired by competent welders. It IS doable. BUT only if you do it properly. The vast majority of Facebook armchair smiths I’ve seen have offered WRONG advice on this matter. As a general rule I almost always suggest that people do not weld their anvils as 99% of cases do not really require it. However there are times when an anvil would benefit from a good quality repair. An anvil with a small piece of the plate missing is a good example. The anvil above has a significant amount of the face missing but it seems to be in good condition apart from that. Depending on the sale price it could be a good candidate for repair. Just do your research. The Robb Gunther method is generally regarded as a good way to repair an anvil. Step 3. Testing: Assuming your anvil passes a visual inspection and has no obvious flaws then it is time to test it. Ring and Rebound: These are the most well known tests for any prospective anvil buyer. Be aware that paint or rust on the face will dramatically effect the results so you should clean at least a portion of the face if you can. (with current owners permission obviously) Ring: Take your hammer and gently strike the face of the anvil. If the anvil is forged wrought iron or cast steel it will ring like a bell. The pitch of the ring can also help indicate what the anvil is made from. A wrought iron anvil in my experience usually has a high pitched ring like a bell, with almost a musical note to it. This is usually not a prolonged note. In my experience cast steel anvils have a very high pitched ring that can be very piercing and almost unpleasant to the ears. The ring can also be quite prolonged and drawn out. Cast iron anvils with a steel face will produce a note when struck but will not sound like a bell. The note shouldn’t reverberate or be prolonged at all. Cheap cast iron anvils should sound dead under the hammer. I can’t honestly say what they sound like as I have never been in the situation where I’m looking to buy one. Strike all over the face, horn, heel and body of the anvil. Even the feet. At this point it is worth noting that the horn and the heel of an anvil WILL sound different to the body. Higher pitched usually. This is because there is less metal in these areas so the note is different. When striking the face it should all sound the same. If you are striking and suddenly the face sounds wildly different in one area it could indicate a crack or delamination. Be sure to visually inspect this area closely and be sure to test it with the rebound test. Also check to see if your hammer blows have left dents. Dents left by light blows are a good indication that the face is soft. I’ve used an anvil with a soft face and it worked perfectly well, just keep it in mind and use it as a negotiation point if needs be. NB - ring is only an indication. It is not a rule set in stone. My first anvil barely had any ring to it at all but it was a perfectly good anvil. Rebound: To me this is the more important of the two tests. If you’re on the hunt for an anvil the I’d keep that 1” ball bearing in your car on the off chance you come across something. “Rebound” is the name given to the amount of energy an anvil reflects back at the user. But it can give a good indication of face plate problems. Take your 1” ball bearing (Larger or smaller it doesn’t really matter.) and your ruler. Now hold the ball at 10” above the anvil face and drop it. It’s best to do this so you can see how high it bounces. 10” is ideal as it’s very easy to do the math for it. A “good” anvil should have more than 70-75% rebound. So the ball should bounce a minimum of 7” high. Many anvils will produce rebound higher than this but anything drastically less should be approached with caution. This is where cleaning the anvil face makes a big difference. Paint and thick layers of rust WILL drastically reduce rebound, so clean the face if you can. Like the ring test, you should check rebound all over the face. The heel will have less rebound than the face, just like the ring there is less material there so it behaves differently. The rebound should be the same across the whole face. An areas where it suddenly rebounds a lot less may indicate a crack or delamination. If this occurs during the testing then have another good look at the anvil. (Common sense) It may be that there is a significant crack you missed initially so proceed accordingly. As frustrating and disappointing as it it. (Trust me, I know) You are better off in the long run to save your cash and walk away from an anvil that is too damaged to be usable. Step 4. HAGGLE!!!! So you’ve looked over the anvil and everything is in order. There’s a couple small flaws, a little sway or maybe a chipped edge. Use that to your advantage. Start to umm and ar about the price. Make a cheeky low ball offer. You never know you might get lucky. If for arguments sake your seller wants $400, why not offer $250 or less! They might know what they have is valuable but they might not. You might get laughed at but on the other hand they might either accept the offer or come back with a slightly reduced figure. Ultimately you’ve saved yourself some cash. Remember rule number one? Always bring cash and bring more than you need if you can afford to. Money talks. Your seller might start to budge on price if he sees some nice crisp notes being counted out infant of him. A trick I’ve heard of people use is to count out the sum they want to pay in front of the seller. Some guys crack at this. The other trick to try is to ask if they have any other blacksmithing stuff. You might stumble on a gold mine of equipment. If that is the case and you can afford it (and there are things you want) then you should try and get some other stuff as part of the deal. So I hope this has helped some of you out there. If you have any questions don’t hesitate to ask. PM me directly if needs be. All the best Andy Hopefully you should all be able to see the pictures again. Though most will not be the original pictures I used they will convey the information. Cheers Andy Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 9, 2022 Share Posted December 9, 2022 1 hour ago, Everything Mac said: Here is a Vulcan. Again clear indication of being a cast anvil with the raised lettering and rather helpful Vulcan logo. The picture is a Fisher. Here is a Vulcan. Quote Link to comment Share on other sites More sharing options...
Everything Mac Posted December 9, 2022 Author Share Posted December 9, 2022 (edited) Well spotted. I must have loaded in the wrong picture. Edited December 10, 2022 by Mod30 Remove excessive quote. Quote Link to comment Share on other sites More sharing options...
lary Posted December 9, 2022 Share Posted December 9, 2022 Everything Mac- Thank you for the write-up. Very informative. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 9, 2022 Share Posted December 9, 2022 Excellent article Andy, well done! I have a couple little things though. Why carry a 1" bearing ball for the rebound test. A ball that heavy can dent a soft anvil that otherwise looks good and lock you into buying something you'd rather walk away from. Depends on your skill haggling of course. Josh, logs in as njanvilman, owns the Fisher Norris Museum and can tell you exactly how the steel face was welded to the cast iron body. I can provide a quick run down though. The molds have a space for the faceplate and the "secret" was another mold on the side opposite the anvil body which was filled with molten iron to preheat the faceplate. This iron didn't weld because the faceplate was too cold and could be removed and cleaned up easily. Once the faceplate was preheated the body was poured and the faceplate and body welded in the mold. Ah HAH! I remembered my 3rd. point BEFORE I hit the submit button for a change. YAY! The handling holes in the feet and base of anvils is NOT an indication it's a forged anvil, my Soderfors has square handling holes. The manufacturer had to hold them to grind and handling holes meant they didn't have to have specialty tongs for every different size of shape. Again, it's a great article. Thank you. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Arkans Posted December 10, 2022 Share Posted December 10, 2022 I have a lot to learn here it is obvious... Quote Link to comment Share on other sites More sharing options...
George N. M. Posted December 10, 2022 Share Posted December 10, 2022 This post should be pinned or in some other way made easily recoverable and available for both new and old smiths. It would eleiminate the need to repeat all the information everytime someone new asks about anvils. GNM Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 10, 2022 Share Posted December 10, 2022 Link with photos is now a part of the very first post. Quote Link to comment Share on other sites More sharing options...
Everything Mac Posted December 18, 2022 Author Share Posted December 18, 2022 On 12/10/2022 at 11:00 AM, Glenn said: Link with photos is now a part of the very first post. Thanks Glenn. Quote Link to comment Share on other sites More sharing options...
Everything Mac Posted December 18, 2022 Author Share Posted December 18, 2022 On 12/9/2022 at 5:40 PM, Frosty said: Excellent article Andy, well done! I have a couple little things though. Why carry a 1" bearing ball for the rebound test. A ball that heavy can dent a soft anvil that otherwise looks good and lock you into buying something you'd rather walk away from. Depends on your skill haggling of course. Josh, logs in as njanvilman, owns the Fisher Norris Museum and can tell you exactly how the steel face was welded to the cast iron body. I can provide a quick run down though. The molds have a space for the faceplate and the "secret" was another mold on the side opposite the anvil body which was filled with molten iron to preheat the faceplate. This iron didn't weld because the faceplate was too cold and could be removed and cleaned up easily. Once the faceplate was preheated the body was poured and the faceplate and body welded in the mold. Ah HAH! I remembered my 3rd. point BEFORE I hit the submit button for a change. YAY! The handling holes in the feet and base of anvils is NOT an indication it's a forged anvil, my Soderfors has square handling holes. The manufacturer had to hold them to grind and handling holes meant they didn't have to have specialty tongs for every different size of shape. Again, it's a great article. Thank you. Frosty The Lucky. Thanks Frosty. I find the larger ball bearings are a bit easier to find once they ping off across the workshop. Though I must say if a 1" ball bearing dropped from 10" height dents the anvil you're looking at I'd pass and walk away. It'd have to be made of butter to do that. And yes there are always anvils like that out there that disprove the rule. But how many Sodefors anvils are in general circulation outside of the Scandinavian countries? My bet would be not enough to really make a difference and those that I've seen are well marked or have other identifying features. Chances are the anvil most people will find with handling holes is forged. Then there's those weird American makes that have cast bases/ forged top halves and vice versa. I'm no expert on them but would happily invite anyone to do a proper write up on identifying them when markings aren't clear. Cheers Andy Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 18, 2022 Share Posted December 18, 2022 Agreed, a 1" ball is easier to find when they take a wild bounce but I can carry 4+ 1/2" balls in my pocket and hardly notice. That's two in each front pocket. Not too long ago Centaur Forge announced that doing a rebound test would void any warranty on anvils. Lots of anvil evidently depend on work hardening of the surface with use. I'll bet dropping a 1" bearing on my Solderfors would leave a flat spot on the ball. I know it rebounds as close to 95% as to be hard to gauge. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 19, 2022 Share Posted December 19, 2022 Got a ball bearing ball in the truck's glove box, one out in the shop and one by the back door of the house... Quote Link to comment Share on other sites More sharing options...
Rojo Pedro Posted December 24, 2022 Share Posted December 24, 2022 Very informative read, Thanks Mac. There is another type of anvil construction that I didnt see mentioned and that is the forged steel anvil such as the Peddinghaus / Rigid or Kanka anvils. From what I read years ago, these are solid tool steel anvils forged to shape and that the forging process arranges the molecular structure of the steel along the shape of the anvil thereby making it stronger than cast steel. Could be marketing hype but I thought I would mention it. I love my Kanka and a 1" ball bearing does nothing but laugh on the way up to 95% rebound. It will put little dents in my mild steel ASO but not the Kanka or Vulcan I have tried it on. Quote Link to comment Share on other sites More sharing options...
Avmech Posted June 13, 2023 Share Posted June 13, 2023 Great read, thank you Mac. Lot of good info, lot to learn Quote Link to comment Share on other sites More sharing options...
