March 17, 201511 yr Hey guys,I've got a new style 100lb. LG hammer. I am trying to build a guard for the spring and wanted to attach the guard to the 3 long bolts going through the ram guide. Unfortunately, there is not enough bolt there to get the guard piece on it. Is there any reason not to replace them with threaded rod? I have a metal lathe and the capability to turn my own bolts but it seems like all thread would be an easier solution. Thanks,Cody
March 17, 201511 yr What grade are the guid bolts? Be aware that "studs" will exhibit higher clamping forces than bolts for the same torc. Being that a nut produces less friction than a bolt, and you experience less stretch. Secondly be aware that not all " all tread" is the same, grade 0, 3, 5 and 8 being common bolt specks, wile comely one only finds grade 0&3 rod, one might look at graded studs, they typically have corse threads on one end and fine on the other, but are available in grade 5&8.
March 18, 201511 yr Greetings CK,A simple answer seeing that you have a metal lathe .. Drill and tap the bolts on the head end for say a 3/8 stud.. That should work just fine...Forge on and make beautiful thingsJim
March 18, 201511 yr Charles - no need to over think - the guide bolts do not get torked to a spec, they just get tightened enough to hold the guides in place with some clearance for the ram to move.
March 18, 201511 yr Sorry, automotive mechanic, lol. "Third rock from the sun" mind set "when everything is spinning round, things tend to come undone" ;-)
March 19, 201511 yr Author Thanks for the advice guys. I think I am going to go ahead and order some all-thread. If it doesn't work out for whatever reason, I may try Jim's idea!Cody
March 19, 201511 yr I'm no expert on LGs, but yesterday I was working on a friends 50LB LG and we replaced the guide bolts with 5/8X3 1/2" grade 8 bolts to accept her guard and hold the guide in place with nylon nuts just holding the guide, then the gaurd frame, then another nylon nut to hold that in place. I ran the hammer all day today and it didn't seem to be a problem. I wasn't the one who [paid for the nuts and bolts, but probably around $10 at a local big box store.(using the term "nylon nut" meaning whatever those nuts are called with the nylon thing on the inside of the thread to prevent it from backing out inadvertantly)
March 20, 201511 yr Hey Crazy Ivan: I have a 50 lb LG also and would like to see the guard setup. Some pictures would be great, if possible. Thanks,
March 31, 201511 yr Buy some B-7 allthread. McMaster, MSC and such carry it. B-7 is the ISO equivalent to grd-8 .
April 11, 201511 yr This is how I did mine on my 100# ...I took cold rolled and cut just enough thread for the nuts and left the center section unthreaded so the adjuster bolts make contact with the unthreaded section.Dan Lehman Edited April 12, 201511 yr by Suboc add photo
April 12, 201511 yr Subok that is a pretty hammer! ChrisThanks Chris. Those photos were taken several years ago just after I had rebuilt it. Believe me, it's not that clean anymore but has proven to be a great hammer. Edited April 12, 201511 yr by Suboc
April 13, 201511 yr Hey Crazy Ivan: I have a 50 lb LG also and would like to see the guard setup. Some pictures would be great, if possible. Thanks, Hey Dave, My apologies for not posting those pics. I just saw this now. I'll keep you in mind next time at the shop and try to get some pics up for you asap.
