Taking off a LOT of metal
Indeed, when you say "a LOT of metal",  that means something different to each observer.
A picture is worth a thousand words :rolleyes:
In my case, "a LOT of metal" used to be .002".  I think that's why I like Smithing. I'm still trying to loosen up, but maybe I shouldn't?....
Are we to assume that you are finishing a BLIND Hole?
Will the Hardy have a Taper?
So yes, seeing what you are up against would tell me, at least, whether it is file time.
It appears that Mr. Swedefiddle has done this kind of thing a time or two before.....
Has anyone ever had problem with sharp corners in their Hardy Profiles leading to cracks?
Robert Taylor
You have already put more time in this than it should take you to find someone to weld it for you in exchange for a bit of light labour.  The town you have listed has 9 times the population of the closest one to me yet I know dozens of places to ask about a bit of welding---not even mentioning the old shotgun approach of mentioning it at church.  (Last time I did that I was given an anvil, 40 pounds of welding rod and a set of mule deer and elk racks.)
I think it would help if you got off the keyboard and started finding your local resources.  Taking a cold sixpack of something to drink to a small welding company around quitting time on a hot friday afternoon has gotten a LOT of welding done for me over the years; weldors often are interested in smithing and spending a bit of time talking can have very positive results.
Alexander Weygers book on blacksmithing shows how to drill a square hole with either a drill press or a lathe.  I've never seen it done but the principle of it is sound.
I agree with Thomas about local resources. Unless you're striving for aboriginal blacksmithing - you're likely going to benefit from knowing where you can get some things done close to home.
Going in a completely different direction it's worth mentioning that tree stumps are pretty easy to find.  It may be a lot less work to convert a stump into a hardy stake plate.  Seems like you could auger out the majority then use the forge to heat a section of square tubing to slowly burn your hole square.  I'm imagining a metal lined square hole that's flush to the stumps face.  If you've got a leg vice- using it to hold anvil tooling is a decent compromise.
This link to a Mark Aspery vid will show you how to make a square hole. The suggestions you have been given here should have been enough, but here you can see it done. You should have no excuses about making chisels or the filing that will need to be done as both would take less time than the forging, filing and tempering of a broach.
Because I have neuther the time, resources, money, or equipment to weld/find someone to weld for me
Thomas Powers had some very good advice....
You might just be surprised...if you took your work as mentioned, with a peace offering of some kind, to a small welding shop near quitting time before they put their tools away and explained that you are an aspiring blacksmith with very limited resources, they most likely would accommodate you at no cost or very little cost.
I for one, if I had a shop near you, would do it for no charge to give you a start with your setup and encourage you go further.
