What's a fair price for this anvil?
What does the bottom look like?  Have you done the ball bearing test?  Any discernable writing on the sides?
I haven't seen it in person, and the ad doesn't mention any writing. I definitely plan to do the bearing test before handing over any money.
The anvil looks to be in decent shape.  And forged anvils under 100 lbs command a premium.  If it has a hard top with good rebound, and is a name brand, $300 is not out of line.  But, we always try to save what we can.   Cash is king.  I like to show up with what I want to offer in twenties in one pocket, and a few more hidden away, for "negotiations".
Ask them what the bottom looks like would probably be the fastest way to narrow it down as to which brand; but the ball bearing test is the key; far better a no name with good bounce than top brand with no bounce (usually due to surviving a fire or welding or machining by a previous owner)
I also think it is high , and also light in weight.
With any purchase it will come down to what you can afford, not us. If you can afford a particular anvil, and it suits your needs, buy it.
I may be the exception with all of my 6 anvils running around $1 a pound. They run 50#-306#. If you think this anvil is overpriced, keep looking for a less expensive one. They are out there, but how long do you want to wait? Mine were purchased over a span of 35 years. The first 3 came out of your area when I lived in Fairfield, the last three came out of the Las Vegas valley in the last 3 years. Craigslist accounted for the LV trio, a machine shop auction, high school sell off, and a friend's newspaper prowess found the other 3.
Again, only you can set what is affordable to you.
Thanks for the ID guys and thanks for looking up the serial # clinton. This is my first real anvil so I'm pretty happy. Here are the ASOs it'll be replacing.
I have a nice 5 ft stump that I'm going to sink into the ground and then bolt the anvil to. Is there anything good to coat it with beforehand to minimize rot?
Coating the "stump" depends on the ground conditions and the type of wood you are using.  Creosote was the old reliable, but it is extremely hard to obtain today.  Linseed oil is available and should do a decent job.  Thinning it with turpentine for the first few coats will allow for more penetration into the wood.  Finish with some full strength coats.  And remember, after 10 - 20 years, if it rots, it is easily replaced.
Easiest way to soak the stump.... stick it in a large trash can and fill said can with a can of boiled linseed oil that's been thinned with mineral spirits, acetone or the like.  The wood will suck the oil up through the end grain and you can use the extra to paint the sides.  As NJA pointed out, it will only last for a decade or so, but it's easy enough to replace when the time comes.
