March 5, 201313 yr Greetings all, Tired of looking for that just right spacer for your post vice . I thought i would pass this on for the newbies and the pros . I made these from some scrap I had from a parking meter.. You can make them easy from some 1/8 x 1 flat stock.. drill some 3/8 holes Put a a 5/16 by 6in round bar through with key chain earrings... It works slick ... I put some of these in IRON IN THE HAT and the pros were fighting over them... go figure they are easy to make.... MOST OF THE TIME THE SIMPLE THINGS IN LIFE IS THE BEST ( comments welcome ) Jim
March 5, 201313 yr just have some free time and made one of these not as spiffy as yours but man is it handy thanks for putting this up
March 5, 201313 yr Pretty slick! Beats all the pieces I have laying around and you can never find the one you need.
March 15, 201313 yr I like it ! ! , maybe a few different sizes..like a feeler gauge,.....attached with a chain.... push the pin through......... Viola! ! , I like the way you think
March 16, 201313 yr Author Larry, 1/8 spacers is all you need... If your post vise is super tight you can put 1 1/16 spacer in the end... Thin spacers go crunch.... Have fun and get busy making one.... Jim
March 18, 201313 yr looks like your idea has already been copied and is being sold on ebay. I think its a handy thing, I hope you at least received a thanks for the idea before some one started profiting off your idea
March 18, 201313 yr Author Greetings ML, Nope no thanx yet... I made that mistake years ago when I made a slick welders positioning jig.. Invested alot only to find all welders wanted to buy was the basic component.... True smiths make there own... Go figure Jim
March 20, 201313 yr I am totally new to smithing, so this is a stupid question. Why do you need a spacer? Only guess I can make ( and it's a guess) is it is to not put as much stress on one end of your vice. Thanks Randy
March 20, 201313 yr 4dead: You guessed it. Too much off center tightening can tweak your vise off to one side....
March 21, 201313 yr Not only to prevent tweaking the vise, but it grips better if the jaws stay close to parallel.
May 15, 201313 yr thanks for this idea have been thinking about a usable and fast spacer set for some time but this is just perfect have to make a load of nips for these next time I got a laser cutter handy, need at least one for every vise
May 28, 201313 yr Jim, Here is a take off from your idea. When you first posted I saw the light. I rarely put anything bigger than one inch in my vise. I have 1-1/8" with this one.
May 30, 201313 yr Author Greetings Yves, Fun to make... With your design you could not space for a 3/8 bar.. That's why I used all 1/8 spacers .. I'm glad you could use my idea.. I will post more in the future.. Forge on Jim Woops I looked again and you can.. sorry duuuuhhh 1/4 = 1/8 make 3/8 He being in Metric land, is not likely to get 3/8 inch stock anyway :)
June 30, 201313 yr Author Greetings Doug, I have had a lot of fun with this tool... I am so glad so many have been able to use my design.. Look up leg vise tool and see what my friend did with it.. Forge on and make beautiful things.. Jim
July 22, 201411 yr What a great idea, so simple, but it is one of those " until someone shows it to you ,it's a hard thing to fix. " Thanks for that.
