Posted
Made up some tooling today, right angle and straight up fine mandrels, a small 3 pin bender that will fit in the hardy hole, and scroll starter for very fine scroll work and making snub and penny end scrolls.
Posted
BEAUTIFUL work Sam! How does that three pin bender work? I have not seen one and it looks versatile and useful. I am amazed at the fine finish and perfect tapers on your tooling! That looks like machinist's work.
Posted
Thanks guys!
finish technique is easy, 24 grit, 120 grit, 220 then wire wheel. Any hot bending after polishing and you just wire wheel again.
Nampa, the longer arm pivots on the center pin, like a diacro or a hossfeld.
Posted
Excellent form and craftsmanship Sam. Your attention to detail is exceptional.
Thanks for sharing these and inspiring the rest of us to make our shop tooling as pleasing to the eye as the work is that goes out the door.
Posted
thanks very much everyone! Tooling for the Hoffman is SO nice and easy to make, with the 7/8" hardy hole there's not much time to source large material that you have to step down to get a shoulder, or upset smaller stock trying to get a shoulder.
good looking work. are they made out of pavement breakers?
Yes they are, old bits.
  • 2 weeks later...
Posted
Larry of Monster Metal does bit sharpening as part of his shop jobs. He always has lots of old bits for sale VERY cheap if any of you want to contact him. They are great for all sorts of tools.....
  • 1 month later...
Posted
Sam, your skills get better and better with every project you do. I was sorry to hear you moved to Maryland, NY will miss your nuttyness,  ha ha ha ha
Posted
NEWBIE question:  What is the use/purpose of the tiil that is situated in the hardy hole of the first 2 photos?
Also -- Very nice tooling, by freehand do you no power tools?  Wither way, very nice,  my forging is coming along, but finnish work is a whole other skill to be appreciated and learned
Jon
  • 2 weeks later...
