philip in china Posted December 12, 2010 Share Posted December 12, 2010 A sort of philosophical question. So you are forging something big and it goes into the forge. What do you do whilst it is heating up? A genuine question. You are all sworn to secrecy on this one. As I can 100% rely on my wife not being in the smithy I tend to grab my stash of smokes and have a quick one. Also as my shop is nowhere near finished I go round and tweak stuff So come on, own up, what do you do? Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted December 12, 2010 Share Posted December 12, 2010 "As The Iron Heats", sounds like a soap opera! Well, don't wander away too far or that big piece might become a small piece!:lol: Link to comment Share on other sites More sharing options...
Glenn Posted December 12, 2010 Share Posted December 12, 2010 What do you call something big and what type fuel are you using? Link to comment Share on other sites More sharing options...
jeremy k Posted December 12, 2010 Share Posted December 12, 2010 Usually, I gather all the tools needed for the job while the forge is first getting going, and then while the iron is heating I try to make sure I have everything needed for the job at hand. Also, I go through the motions in my head as far as the steps involved in doing what I'm triing to accomplish, so that the forging itself goes as planned/needed. - JK Link to comment Share on other sites More sharing options...
Naz Posted December 12, 2010 Share Posted December 12, 2010 What Jeremy said, and if the iron is still not ready I'll do some sketching,measuring, cutting on the band saw, grinding,put away tools I don't need for the job, etc... I do this when I'm working with the gas forge. With the coal forge, I have a hand cranked blower so it basically comes down to me cranking the blower between heats. Link to comment Share on other sites More sharing options...
Ramsberg Posted December 12, 2010 Share Posted December 12, 2010 PANIC! Link to comment Share on other sites More sharing options...
bruce wilcock Posted December 12, 2010 Share Posted December 12, 2010 we usually set biggish jobs in the hearth to soak around midday then whilst we ate our lunch someone was sent out to turn it over two if it was heavy ,after lunch we started to bring it to heat ,as we cleared the decks ,then set about the job ,no standing time . Link to comment Share on other sites More sharing options...
Larry H Posted December 12, 2010 Share Posted December 12, 2010 I don't do anything, that's the only time I get to rest. Link to comment Share on other sites More sharing options...
Dillon Sculpture Posted December 12, 2010 Share Posted December 12, 2010 Work the previous piece that was in the forge, my mind tend to wander all the time :P Link to comment Share on other sites More sharing options...
Mainely,Bob Posted December 12, 2010 Share Posted December 12, 2010 Commune with the element of Fire,which is a fancy way of saying I zone out.I have been known to let steel burn while staring at it. Who knows where my mind goes sometimes,I know I sure don`t.Time to get a shorter leash as the training collar just ain`t cuttin` it apparently. :D Link to comment Share on other sites More sharing options...
Frank Turley Posted December 12, 2010 Share Posted December 12, 2010 What Jeremy said. There has got to be some attention and focus. I tell my students, a little tong in cheek, that 90% of your work is done while you're taking a heat, because you're trying to figure out what the hell you're going to do when the piece comes out." http://www.turleyforge.com Granddaddy of Blacksmith Schools Link to comment Share on other sites More sharing options...
chyancarrek Posted December 12, 2010 Share Posted December 12, 2010 you're trying to figure out what the hell you're going to do when the piece comes out." Yep - what Frank said . . . Link to comment Share on other sites More sharing options...
Alec.S Posted December 12, 2010 Share Posted December 12, 2010 "position the tools needed for the next heat (lay hammer on anvil, take tongs from rack etc.)" alec Link to comment Share on other sites More sharing options...
nonjic Posted December 12, 2010 Share Posted December 12, 2010 With the induction forge I use the 20 seconds waving my arm around to stop it aching :) Link to comment Share on other sites More sharing options...
Rob Browne Posted December 12, 2010 Share Posted December 12, 2010 When you think 1" is heavy you don't get much time to worry. Just get everything at hand you need and finish off a job you have underway. As you can see I don't take on the big stuff :) Link to comment Share on other sites More sharing options...
bsiler Posted December 12, 2010 Share Posted December 12, 2010 Crank the Blower !! Link to comment Share on other sites More sharing options...
infinityblacksmithing Posted December 13, 2010 Share Posted December 13, 2010 Usually when I work larger bars, I organize smaller bars that need to be worked as well. That way I'm not wasting time waiting for the big bar to heat while I do nothing. Usually one large bar and two or three smaller bars at a time. Only works since I use a gasser. Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted December 13, 2010 Share Posted December 13, 2010 I have to keep cranking the blower like the other guys. That, and I don't do large sections. Link to comment Share on other sites More sharing options...
Timothy Miller Posted December 14, 2010 Share Posted December 14, 2010 I text my sweet heart or put my tongs, hammers and or top tools back on the rack. Link to comment Share on other sites More sharing options...
Dave Leppo Posted December 14, 2010 Share Posted December 14, 2010 I crank the blower, too. But that only takes one hand. I usually play with the coal fire with the other, with the poker. incidentally, I have a technique that's half superstition when welding: I count blower cranks, usually 20, then turn the piece in the fire, 20 more, etc. Helps get an even heat, of course. Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 14, 2010 Share Posted December 14, 2010 Dave; I chant the monk's chant from Monty Python's Holy Grail as a "timer". Link to comment Share on other sites More sharing options...
Please sign in to comment
