what makes a Hofi Hammer so great
EWCTool
Hey John,
The amount of balance obtained is going to be a big question. Do you know off hand how much of the blades weight is balanced by the pommel nut?
For a hammer, if there is a distance of 9" between the center of the hand on the handle and the center of the hammer head and the head weighs 2 lbs then the head would produce a torque of 18 inch pounds. If the counterweights center was 4 1/2" behind the center of the hand then to produce 18 inch pounds of torque it would need to be 4 lbs. That would completely balance the hammer head, not the handle but they are light. . .
The dilema is how far back to extend the counterweight, if it were back as far as the hammer head is forward then it could be of the same weight and one could use it as a true two headed hammer, but the further back it is the more likely it will be to bang into you when it is used.
I think that the latter will depend greatly on the individuals hammering technique, such as swing with the hammer to ones side or in front of the body.
Caleb Ramsby
Hey John,
Caleb Ramsby
Now I think that you might be over-thinking it. I think it's more like trying to make a 4 pound hammer feel like a three pound hammer.
Hey Grant,
There may be a point of diminishing returns with the amount of balancing produced via the counterweight. A bolt holding babbit "washers" threaded into the end of a hammer would give on the ability to change the amoung of balance achieved, from none to 100%. Lead would also work, it weight .41 lbs per ci, a 3" disk of lead would weigh 2.9 lbs per inch.
I like the leaf spring idea, I can imagine the spasmadic dance routine that using it might produce. It would sure be interesting to find out what that would do!
Caleb Ramsby
Is it balance? Is it weight/ or is it velocity? Quustion asked by a 12yr old neighbor. Her answer
Energy is 1/2 X mass X velocity squared
2 lb hammer= .5 X 2 X 20 X20=400
4lb hammer= .5 X 4 X20 X20=800
2lb hammer= .5 X 2 X40 X40=i600
Double the weight double the energy
Double the speed quadruple the energy
Her thought is speed is the answer
Mine is I don't have enough fingers to keek up
Ken.
You know a Maydole the guy who invented the adz eye claw hammer made a lot of blacksmith hammers. David Maydole - Founder of the Maydole Hammer Factory He made a compact cross peen that was called a plow makers hammer I have one. It was a bit longer than a Hofi hammer but not much. Maydole did a lot of work on hammer design as well as metallurgy. I think he was awarded a medal by the president for his discoveries and inventions. Also what about a cats head hammer it is similar in concept to a Hofi hammer but a bit different looks wise. If you want to take this to an extreem there are tribes in arfica that use iron clubs instead of hammers no wood at all for a handle. No chance for that to want to twist in your hand.
I'm with Sask Mark, a 2 lb hammer moving at greater speed will do more than a slower 3 lb hammer. I have proven it to myself, now if you can get a 15 lber moving like the guys in the chain making movies, well well well
Some folks think the same about bullets. I like my hammers and bullets the same way, SHORT-FAT-and HARD HITTIN.
weight, speed, mass, velocity, this , that and the other.....just use a power hammer and get to work. ;)
Good thought Rich. But then what weight,BPM,anvil weight,Tup speed,air, steam, electric or water powered.
Don't really matter to me cause nobody wants to take 3 hammers 2 anvils and a post vise in trade for even a POC
PH. One day before I die or maybe after I'll have one.LOL
Ken.
Well, I know I can swing a smaller hammer faster, so maybe I'm only able apply a certain force regardless of the hammer weight (within a certain range). Then it just comes down to the effect I want. I probably can't swing enough faster though, because I can get more work done with a bigger hammer (for a short time anyway). Don't need no stinking stop-watch!
Ramsberg's idea may not be too far off. A pommel nut on a sword is only a few ounces, but changes the point of balance significantly.
I have tried using a ball peen hammer that came with a severely shortened handle, and just found it clunky.
Blacksmiths swing their hammers a LOT more than a warrior swings a sword, I wonder if anyone ever tried pommel nuts on hammers in antiquity, and was just told "We don't do that here."
Peer pressure is a real force. An Americanized carpenter went back to his old home town in Europe, and his cousins laughed and threw nails at him until he put away his black Titanium hammer and nylon toolbelt, and used the old style.
Found these two hammers on Ebay, they both have some form of metal added to the handle end. The shorter hammer seems to be a user added end piece, while the hammer with the other tools seems to have been made that way.
http://cgi.ebay.com/cast-iron-farrier-cobbler-lazy-susan-blacksmith-tools-/290505443004?pt=LH_DefaultDomain_0&hash=item43a37946bc#ht_506wt_973
http://cgi.ebay.com/Vintage-Blacksmith-hammer-Steel-Ferrule-end-/360248387852?pt=LH_DefaultDomain_0&hash=item53e07a290c#ht_600wt_739
Hi All,
147 replies about a hammer? wow. For my .02, I don't like the Hofi style hammer. That is NOT a shot at Hofi. The thing about other hammers "tipping" upon impact is not noticable to me. I've taken classes from him, great guy, good friend,very skilled,done loads for the iron world. Whe I am forging lots of big stock my hand gets too hot with the short stumpy hammer. A good friend of mine (great blacksmith-very talented) calls it a rock on a stick. I am a professional smith. A lot of times that I am doing production work that has to be done on the anvil, a heavy hammer is not good for me. For instance, if I am doing lets say 500 snub end scrolls. It takes 2 heats to do each one-lets say 10 blows each heat. That works out to 10,000 blows. Rebound or no, a 2-3 pound hammer is a LOT more work than a 1 to 1-1/2 pounder. At the end of the day you see the difference big time. That is not to say that I don't use a larger hammer when necessary. Let's see who , after a long week in the shop can pick up their arm , much less anything else after using a big hammer. But then again, for the testosterone thing, a big hammer is fun.
Mark Emig
