What size anvil do you use?
What size anvil do you use most often?
129 members have voted
  1. 1. What size anvil do you use most often?
    • 0 - 49 pounds
      5
    • 50 - 99 pounds
      17
    • 100 - 149 pounds
      81
    • 150 - 199 pounds
      39
    • 200 - 249 pounds
      20
    • 250 - 299 pounds
      26
    • 300 - 349 pounds
      11
    • 350 - 399 pounds
      3
    • 400 or more pounds
      20
  • Replies 52
Hello:
My lead anvil is a tad over 500# and my "tooling" anvil is just over 200# (I have my guillotine set up on this one..) plus I have a 100# "portable" anvil I use for "remote demo" work...
JPH
Shop anvil ( used most) is 148 lb Hay Budden. Trailer anvil is 115 lb Hay Budden. New anvil ( Fathers Day ) is stamped to weigh 203 lbs but I'm gonna put it on the trade scales up to the LP place to check it. i have a couple of small ones ( actually one good small Enderes about 5 lbs ) that the grandkids will get to start on.
I seem to use my 177 lb fisher most...I love the horn...but started with a 150 PW and still like it a lot.Sold a 80+ lb sweden to a fellow and kicked myself everysense...it was like new.But hey...he xxxx neared cryed when he got it and it was worth letting it go. Gotta spread the fun around...right? For horseshoeing I use a 75 lb wide face NC and really like it...perticularly when I have to pick it up...when I'm ready to move on. It's my only marked up anvil...learned to hit solid faced on it and too do a bit to much cold shoeing when in a hurry....them ol' cowboy ways are hard to shake.
lee
250 PWright for shop anvil and 100 lb Hay Budden for portable. Both are similarly tooled for various hardy tools and the bigger one has sleeves to allow using all the tools from the smaller anvil. I have owned several others including a 200 Fisher and a Mousehole that appeared to date from the late 1600's.
Our group has a number of Australian made O'Dwyer anvils. At 95 kg. I believe that converts to 209 lbs. They are made from SG iron and are not as hard as older anvils but they are a nicely finished anvil and work well for us. I read somewhere on the internet once that they are only hardend to 24 rockwell. I can't confirm this though. Might have something to do with being cast from SG iron??? Does anyone know anymore about this???
  • 3 weeks later...
I would say that 24 Rockwell would be way too soft to be of much use as anvil for very long. Are you sure that the O'Dwyer anvils are SG iron and not cast steel? I've not used one but I've seen plenty of farriers with them and we know how farriers like to shape shoes cold (or very near). If they are only 24 Rockwell they'd be damged in no time.
Cheers, Bruce.
No, the cost to do it right, (not to forget the learning curve and the heavy equipment), would make them too expensive---just look at sourcing a regular supply of decent wrought iron! If you have to pay a lot more for one than you can buy an old one in great shape why would you?
Thomas
My understanding is that modern anvils are being made with cast steel. So it's just being poured into an anvil shaped mold.
thats how my friend produces his, was a bit of work getting the heat treating shop to get them just right, once done, though they're an awesome anvil.
The cost of pouring steel is such you would be better off going with a totally cast steel anvil and not adding the extra cost of re-heating it and forge welding a face on it.
I have a friend who looked into getting a local foundry (did a lot of RR work so decent steel!) pour some anvils for him. It turned out to be cheaper to buy imported ones.
Forged anvils, which are back in production I hear, take a massive chunk of good steel and the skills to forge them neither is cheap.
If I was trying to go that route I would see about having anvil shaped burned from heavy plate and then apply a face. Wouldn't be very pretty but you're fighting costs!
Thomas
  • 2 weeks later...
