pkrankow
5,314 -
Everything posted by pkrankow
ITC100 is an IR reflector and stablizer. Refractory coatings suitable to apply to kaowool are stabilizers, but not necessarily an IR reflector. Coating and stabilizing the surface of the wool will prevent erosion and airborn particles. An air gate will let you turn the forge down (throttle) instead of just having one, maximum temperature. You still need a fuel regulator. The fuel inlet can be flush in the elbow instead of portruding any and it will work fine. Some forges of this nature use a Tee in place of your elbow so assembly is simplified. If you are happy the price is good, I don't think my scrounging skills would have done better. (I am not good at scrounging and easy pickings are not known around me, scrap yards are closed, etc.) If it isn't obvious, weat long rubber gloves, sleeves, and a mask working with this, especially already fired ceramic wool. Fired ceramic wool is some of the worst stuff I have dealt with. Phil
My 2nd Anvil. Deal or Bust?
pkrankow replied to DanielC's topic in Anvils, Swage Blocks, and Mandrels
Ball bearing test on the welds will be indicative of the weld hardness, though you still need to grind a flat to test on. Over 50% and it is good! (well, it could be better...) Phil -
You really want 2 inches of ceramic wool That looks like 1 inch. Galvanized cold air pipe is fine. The elbow with the fuel feed is the closest place that should see "hot" If the pipe welded to the forge is pickled then don't worry about the rest of the pipe. I do not see an air control valve in the setup. Is there one on the intake side of the blower or on the output under the table? A ridgidizer/stabilizer is a good idea, better if it is an IR reflector too. A sacrificial floor is also a good idea so use of flux doesn't destroy the forge lining too quickly. Looks like a nice score overall, just needs some TLC. I hope the price was right. Phil
Some places sell left only welding gloves you know. Phil
Gonna go through $50 in abrasives cleaning it up. I would have spent the $50 on it. http://www.fastenal.com/web/search/product/abrasives/bonded-abrasives/cup-stones-wheels/_/Navigation?searchterm=&sortby=webrank&sortdir=descending&searchmode=&refine=~|categoryl1:%22600948%20Abrasives%22|~%20~|categoryl2:%22600949%20Bonded%20Abrasives%22|~%20~|categoryl3:%22604156%20Cup%20Stones%209and%20Wheels%22|~ you are gonna want one or two of these in a very low grit. Phil -
can you identify this anvil
pkrankow replied to metalanton's topic in Anvils, Swage Blocks, and Mandrels
Worthless as a Peter Wright? no. Less sought after, possibly because it is an English anvil, maybe. Valued less, it is an auction it is valued what people pay. I would be thrilled to have a 200# Peter Wright in that condition. Good point about welded. It looks like they tagged the tips of the feet good, so it is only cosmetic and easily cut with a grinder. Makes me wonder how the weight was determined. Write down Hundredweight conversion in case it is stamped. Did they weigh it stand and all or is the weight listed on the anvil, or did someone guess? There is nothing definative for size in the picture. Trenton and Hay Budden are marked in pounds on the front of the feet under the horn, and Peter Wright is marked in hundredweight on the side...the OTHER side than pictured. Phil -
Looks like a Trenton or Hay Budden. I would lean towards Hay Budden because the seam between the plate and body is well cleaned up. It is also a nice clean anvil. That anvil is going to go for a high price. Be prepared to bid $600 ($3/lb) if you have any expectations of getting it, and that might be too low. I can see a couple excited bidders running it up to $5/lb easily. ($1000 will get you a pretty sweet NEW anvil) OTOH it might go cheap, but there is a lot of equipment and such listed at that auction. Phil -
Hey, from virtually the center of the US in Omaha Ne
pkrankow replied to Justin Marquez's topic in Introduce Yourself
I think you are in a show up and see type of situation. Show for an open forge night, and see what the facilities are and if they and you can make reasonable accomodations. I doubt it will be a wasted evening. Phil -
Try this The "neutral" or slightly "rich" is where you should be for general work. Remember when you stick it in a forge cavity the setting in open air may not be correct anymore. The dragon's breath from the forge door should look similar to your blown forge when running at a similar setting. Phil
Reconditioning a Face
pkrankow replied to PaulKrzysz's topic in Repairing and Modification to Anvils
delete -
Is the stripped section engaged with the threads in the box? If the stripped section is engaged with the screw box then you may have some future issue, but if it is not in far enough to engage, and does not interfere then it won't. The future issue would be related to very few turns being engaged together. I find it interesting that the thread that was peeled out snapped. Was heat used when reshaping? Phil
You need to resize your images. 800x600 is a good size. Under "More reply options" next to the "post" button is the stuff for attaching images. I use GIMP for resizing. There are more lightweight programs out there though. Phil -
The wood is likely white oak. Very handsome knife. Phil
suggestions on how to make this
pkrankow replied to midgaoutdoor's topic in Blacksmithing, General Discussion
While Tim has a point (the price is pretty good for the time+materials) If I was to do this I would use a piece of black pipe the correct od as the ID of the bend and wrap it, hot or cold, using my post vise. With a cold wrap I would clamp some angle stock or a 2x4 to the free end for added leverage and isolation of the bend. Phil -
Show me your anvil stands
pkrankow replied to pkrankow's topic in Stands for Anvils, Swage Blocks, etc
Handsome and stout looking. Since it is solid putting locating pins in, if needed, will be easy. Great idea! Phil -
I built my 1 burner forge around a 4x9 firebrick. It is about 150 cubc inches, and may be at or near the lower limit for a 3/4 inch burner to perform properly. 2 inches of wool on sides and top, one inch under the firebrick floor. The burner digs a hole in the common stove firebrick, and with flux this is quite quick. I can melt steel fairly easily too, fagot welds are no problem, but I haven't been able to do other weld types, (probably a practice issue.) Things I wish I did was make either a slot up one side that I could close off, or hinged the top to the bottom so I could get wider and odd shaped items into the forge. Small dimensions means that once the part has changed shape it might not fit very well, and convinience bends are only convinient when taken at the proper times. Phil
Does your tracer make bigger and smaller? Pretty cool stuff. Phil
Flame holders, while helpful, are not necessary because the forge cavity is a flame holder...you just won't be able to light in open air. The Reil burner is good, but requires relatively still air to function, so it is a poor choice when used out doors with wind. I am using Frosty's T-burner, which is a little difficult to tune but very easy to build. It tolerates wind better than the Reil burner. Phil http://anvilsandinkstudios.com/burner.html
begginer trying to buy coal.
pkrankow replied to santisfurnace's topic in Blacksmithing, General Discussion
There is a location field in your profile settings. If you look under my image is says "location Ohio" you can put something similar in for your own. Phil- 22 replies
- coal
- carbon content
(and 4 more)
In the Mediterranian? Can you get lump charcoal such as used by restaurants for cooking? If lump charcoal is easier to get, it was the preferred fuel until a couple hundred years ago. Pound for pound it has the same energy content as coal. Generally bituminous coal of low sulfur content is used, although other low sulfur fuels are suitable such as anthracite, coke, metalurigical coke...but these more dense fuels bring minor problems over lump charcoal or bituminous coal (electric blower requirements, heavier firepot concerns.) Charcoal, bituminous coal, and breeze coke (lightweight, soft coke) can operate without constant air blast. Phil- 22 replies
- coal
- carbon content
(and 4 more)
That little piece looks like a ready made double horn striking anvil, just add legs. Phil
Coal and corn
pkrankow replied to sanddraggin's topic in Solid Fuels: Coal, Coke, Charcoal, Wood, etc
I have found corn burns almost exactly like coal, except for 2 things, it is less dense, and it is reported to have 1/2 the energy content by weight...together mean feeding the fire very frequently. (and it smells like popcorn instead of coal, no green smoke!) Good stuff. Phil -
Pneumatic Assisted Hydraulic Cylinder Help.....
pkrankow replied to Hillbillysmith's topic in Presses
I like that you thought about how to best move it around with the big handles and lifting eye. Phil -
Fair point. I have had the tue backfire on me before. Sorta exciting. I have only messed with fireplace type no valve bellows personally. They work fine, but valves are nice and make them work better. Phil
