pkrankow
5,314 -
Everything posted by pkrankow
Embarrassing Question, fire not getting hot
pkrankow replied to plane_crazzy's topic in Solid Fuel Forges
So this is a new order of coal from the same supplier? It sounds like a different product, regardless of looks. Try getting some lump charcoal and see if starting with the charcoal you can light this coal. Phil -
A tip to make your thread "right" Put your thumb on your right hand up, or out in the direction on desired travel (towards the point) the direction your fingers curl as you make a fist is the direction your corkscrew should curl in. This makes "right hand threads." If you desire "left hand threads" then use your left hand. Of course, there is a market for left hand cork screws: south paws, practical jokers, and people who don't care as long as it works. Phil
How to NOT mount an anvil
pkrankow replied to Tubularfab's topic in Anvils, Swage Blocks, and Mandrels
I bet it is quieter on the stump too! Phil -
Removing paint from an old anvil
pkrankow replied to CaptainSpaulding's topic in Anvils, Swage Blocks, and Mandrels
Liquid laundry soap, straight up, applied thick. You can apply to paper towel then paper it on. Wrap well in paper like newspaper or paper towel. Wrap in plastic. Place in a WARM location for 2+ DAYS (the warmer the better, but at least room temperature). Glove up, unwrap on a sheet of plastic and attack with putty knives. Repeat if necessary. Many types of paint will soften considerably from this treatment. The soap will not etch the anvil since is is basic instead of acidic. If lead paint is involved then the materials are contaminated, but the lead is containable in the scraped off waste. If you read about using a crock pot to strip painted hardware, they use heat, time, and dillute laundry detergent. I am suggesting that you use straight laundry detergent and time without the added heat. Phil -
Good question Smoothbore. The outlets should be the same price, and likely the breakers too. The wire cost is driven mostly by the length of run. Phil
A candy bar and a bottle of gadoraide and I can have one of the boys at the scrapyard zap a couple pieces. Phil
My 100A 220V machine requires a 30A circuit. I pulled #6 wire for a 50A circuit since I plan to upgrade my welder at some point. Phil
A better and safer bench grinder wire brush
pkrankow replied to territorialmillworks's topic in Grinders, Sanders, etc
hillbilly rock tumbler http://www.youtube.com/watch?v=PvGYfmbBYyg neat centerless tumbler http://www.youtube.com/watch?v=gpxFDMcYiXA You can also tumble in a concrete mixer. http://www.youtube.com/watch?v=f32989UsCEs -
Grant's username was "Nakedanvil - Grant Sarver" here on IFI, and "Grant" on Blacksmith.org I believe Grant imported some hammers at one time. He imported a fair number of items that he was not able to manufacture himself for whatever reason. He was pretty up front when he was asked, so perusing his old posts might get you what you want to know...and then some. Phil
http://www.blksmth.com/mild_steel_firepot.htm I have one of these and I am building a 30x48 inch steel table to set it into. The table size is determined by the metal I have on hand. Phil
The sky is the limit so to speak. What do you want? Phil
Without knowing your ablities and capacities, no I don't have ideas. I would build a rivet type forge using a hoop of the pipe. I would get pipe for legs from the local garage door place, since almost every replacement overhead door generates a scrap pipe. Phil
A step to stand on while cranking away, and possibly to hook with a hand truck... Phil
Wrap the blade in a wet rag as added insurance against the heat. Phil
Need help laying out a truncated cone
pkrankow replied to territorialmillworks's topic in Problem Solving
You can "cheat" on the math by googling cone calculator Phil -
Hot or cold? Very nice. Lots of detail. Phil
Use glazing compound. Glazing points are just for assembly and maybe when the compound gets really old and starts falling out. Some basement windows I reglazed had some wire welded or brazed in that was bent over the glass to act as a glazing point. Silicone is just fine too, but you have to let it set up before putting it to service. There should be no metal-glass contact so lay a thin bead of the compound of your choice on the frame, then set the glass, then use more to seal it into the frame. Phil
Control line airplanes? Super Ringmaster I just repaired and re-covered, was a Craigslist deal. My daughter thinks it is hers though. I still need an engine for it. I fly 049's between my house and my neighbors house. I keep trying to get him to fly control line, and he is succeeding is getting me to fly RC. Phil
Those look great, no hammer marks! These would be a good exercise in heat treat. (If you need the exercise, even though heat treat is not necessary for hot work...) low material cost low time investment simple cross sections The first two mean a failure is not costly. The third means that an aggressive quench is not likely to crack the tool. Phil
Yet another ugly ducking anvil...
pkrankow replied to Revtor's topic in Anvils, Swage Blocks, and Mandrels
Very nice. It looks like there is only one bad chip in the edge, and it is fairly small. How is the other edge? The horn is necessary less than you might believe. This is not a comment on usefulness. Horns are useful. This is a CAST IRON body anvil so simply welding a piece of steel on is not really an option, you need to pad the cast iron side with a layer of nickle weld, so the procedure is expensive from the get go. It is quite do-able and ultimately may cost similar to a better anvil, but might still be worth it. I would recommend making or getting a small cone mandral and a bick for the hardy hole. Phil -
What could be done with 3 1/2" dia bar ends?
pkrankow replied to Ricko13's topic in Blacksmithing, General Discussion
4 inch diameter 16 inches long is just shy of 60#. You can cut one into 1.5 inch thick disks so you can weld them to hardy shanks and forge swage shapes into them. Phil -
Sadly the video is gone http://www.iforgeiron.com/topic/19207-forging-a-box-joint/ Phil
Definately paint a couple for the pantry! 16 pounds is quite funny! Give them as "bench anvils" to all your friends for Christmas. Phil -
I see where this is going. Cosmetics and yard clutter concern your mother. If you put a layer of sand in the bottom to take up space, then stack bricks on the sand to protect the vessel you can have the cosmetics your mother desires and the forge you desire. However using a $300 fire bowl is a little... See if you can find a less expensive decorative vessel. Going back to a ground forge, see if you can set up a low brick or wood framed "sandbox" forge, then cover it with pavers and a potted plant (or some other decorative element) when not in use and cooled down. Naturally maintaining a clean work space and cleaning up promptly will be paramount to maintaining this illusion. "If Mom ain't happy, ain't nobody happy" Phil
