Well I finally got a chance to do some work on my forge.I put a slight curve on the bracket for the blower(sorry no pic),so it would sit flush against the fire pot hoop.
Next I started on the legs.The upper portion of the legs will be 3/4" square bar and riveted to the hoop.The lower 1/3 of the legs(where it will flare outwards) will be made from pipe.I am still working out the transition from bar to pipe,but at this point my idea is to split the bar,inset into pipe,and weld into place.The pipe will hopefully look like the legs of a cloven hoof animal(goat/deer).I have never formed pipe before,so this was a new experience for me.
I started with some thick walled pipe pieces 1 5/8"(?) in diameter about 12" long.Though the outside was rusted the inside still had plenty of galvinized coating which I had to burn off...yuck.Then I heated a couple of inches of the ends and flared them over the horn of the anvil.Next I made a couple of tools to work the pipe with.Each is made with angle iron.One I made the angle wider(I read 117 degrees was ideal for supporting pipe,but didn't have a way to check it) and made it to fit in the hardy hole.The other I made the angle smaller than 90 degrees and with a tab to hold it in the vise.This one has got to be the ugliest tool I have ever made.It worked though and is what I used to put the notch in the hooves(I slid the pipe over it and used a brick chisel).
I actually haven't needed the wider angle tool much so far as I have mostly been working over the anvil.Here are the hooves started:
Hopefully I can work more on the legs today, to finish the next joint and flatten the upper portion of the leg.This pipe work really is fun!!
