Latticino
2023 Donor
  1. Not too hot, just enough to drive off any surface moisture. Furnace cement is "stickier" than satanite and should adhere better. May get better definition with enhanced thickness of cement, but that will need experimentation. What I've done is a thin coat with watered down over whole surface, then thicker additions over that for detailing (sorry, don't know the official Japanese terminology). I've never used it with 1095 though, so not sure about that.
  2. Blanket is only rated to 2,246 deg. F and the tip of your flame will exceed 3,000 deg. F if running properly. You need enough length in your chamber for the flame to develop without impinging on a fame face that can't take the heat. You need better liner material, supports for your burners so they don't just rest on the furnace roof. Some "dragon's breath" is actually preferable, particularly if you are forging high carbon blades or forge welding. One way of dealing with a long forge like this one is to use a multi-port burner (ribbon burner). These can be run off NA burners like yours, but tuning correctly takes some experimentation.
  3. Try lightly pre-warming the blade with a propane torch prior to painting on the Satinite (better choice for clay is either Imperial Furnace Cement (black) or Rutlands Black Furnace Cement). Works for application of ATP anti-scale. You also may have better success using either W-1 or W-2.
  4. I'm not sure how things work in the UK, but what you are proposing would be problematic here in terms of building code compliance. As usual these codes have been put together to help with health and safety, not just for you, but for your neighbors as well. While your venturi idea has merit and may function well for fume extraction, the issue is the penetration of the exterior wall and the location of the termination. I understand your situation, but feel I must advise of the potential insurance impact if there is an incident.
  5. Forge lining sounds good, but how hot things will get all depends on a lot of variables that you don't give us: Blower size and configuration (ideally you want a blower that is pressure dominant rather than volume flow - radial fins, not squirrel cage). You need to know the fan curve (flow and associated pressure for a couple of points) to properly evaluate. If you figure out the planned BTUH per burner head connected, you can calculate the gas and associated air needed. For a forge like you describe I would expect you to need at least 150 MBH., but hard to tell. Burner piping configuration, in particular the specific location of the planned reducers and the location and orientation of the elbows. Personally I would not reduce the mixing chamber until after the manifold (where you connect the burner outlets) unless you have a particularly high pressure blower. Type and pressure for your fuel gas (some like myself, admittedly very few, run residential pressure natural gas - very big difference from commercial pressure or propane). Regulation methods for both the air and gas Doors!!! Is 20 in x 9 in x 8 inch the inside dimension or the shell? Kind of a large forge, why do you need one that big? Planning on architectural work? Do you already have a power hammer and/or striker?
  6. Wasn't sure the right place to post this, so hope this is acceptable. My wife and I will be traveling to Vietnam this November for an art tour that is primarily focused on her interests. I was hoping to sneak in some traditional blacksmithing/tool making at one end or another of the trip, and am looking for something a little more advanced than the typical tourist "knifemaking experience". While I'm no master smith, I am fairly experienced at this point and wish to do a bit more than tap on the steel a few times and sharpen the edges. Anyone have a connection or recommendation? I have researched a bit and know there are dedicated villages in Da Sy and Phuc Sen, but haven't been able to find anything more advanced than the basic tourist class.
  7. The real question then is, do you have an analogue castable forge liner to Kastolite (high alumina for flux resistance, but still light enough to provide more insulation value than hard refractories like Greencast 97).
  8. JHCC. What a lovely compliment. You really made my day today, and I had fun working with you in the forge as well. Of course you "nocked it out of the park" with your first forge welded hawk build, but that was only to be expected. I'm a bit afraid to show my son you railings. He is sure to want me to make something similar, and I've never worked nearly that large or precisely. Beautiful work
  9. As far as I am aware, the springs used for these vises can be just mild steel. If that is the case, just remove it, cold bend to shape and reinstall. I assume you are aware that you do need a lower pivot bolt for proper function as well. If spring is actually high carbon, I would heat it, bend it, then reheat treat (tempering to a peacock blue in the end).
  10. Not sure where in the Adirondacks you are located, but you might consider getting some direct instruction and recommendations from the Adirondack branch of the New York Designers Blacksmith group. Typically there are monthly meeting where you can interact in person with other smiths and even use tools and equipment that have already been proven.
  11. Of course John. Wishing for the best future for you and yours.
  12. I use forced air and residential pressure natural gas in my forge. I currently have a single port burner, but have run multi-port inthe past. It gets up to welding temperatures. However, I have commercial grade regulators and a 1.5" gas line feeding the forge. Propane is certainly different, but the lower the pressure the larger the line required to get the same BTUH output. Codes are pretty easy to check to determine allowable indoor pressures and connection types (available online at this site: https://codes.iccsafe.org/codes/united-states )
  13. Key problem I see with your design is the shear plane. I have certainly punched square and rectangular holes in the past, but for ease of successful shearing you need a relatively flat, "sharp" plane to cut the plug free. The irregular tip on yours will just get frustrating, particularly in the middle of a large hammer billet. You can have a tip, it just has to emanate from a flat, regular crossection with an abrupt change (to either a flat or a short beveled tip). Yours also has a lot of taper in the longitudinal direction which will make it more difficult to shear effectively. There are a number of timing and process details that help a lot with hot punching. You can learn a bunch more about punching by starting with 1/4" thickness and working your way up to hammer sized billets. Here are some to consider: Punch one side until you feel the tool "bottom out" on the anvil. Then flip it over, flat quickly, counter punch and shear the plug. Shearing works best, in my experience, when done on steel that is dull red at most. While punching take your tool out at least every 3 hits and cool down to avoid having it overheat. Rotate either your stock 180 every 3 hits or yourself around the anvil. This will help keep you straight. Hit hard with as heavy a hammer that you can handle (and that the tool can take) Treadle hammers, hydraulic presses, or strikers are great for this activity Put a deep center punch on one side of your billet as a guide (some drill up to three holes through the billet, but after time you will find you don't need to). Tap your first try and make sure the tool is correctly placed, then hit harder once you are sure it is in the right spot. Don't just put the tool on the stock and start bashing away, it will bounce and come down away from the target. Resett he tool every hit until you get a good size divot started as a guide. John's point about the ease of punching a round hole and turning it oval is also well noted. A round punch can certainly do the job.
  14. Looks like a nice, solid piece of kit. With the controller properly tuned (and if the coils are still good) it should easily be able to accomplish what you need. Note that it does appear to have some significant thermal mass, which is a double edged sword. As noted, it should keep temperatures more stable, but it will also take more time and energy to get up to heat. This will also impact you being able to easily double purpose it as an austentizing oven and a tempering one. A cheap toaster oven can also be used for this (they can also be fairly easily modified to perform really well at this).
  15. Well, I haven't used cones in close to 50 years, so take this for what it is worth: Ceramic cones are a temperature over time system. My feeling is that it will likely be helpful to get a better picture of the variation of temperatures in your kiln in different locations, but not necessarily a good indication of the actual temperature within a couple of degrees that you would get with use of a proper thermocouple. By all means put a bunch of cones of different ratings on shelves in different locations in your kiln, but I would take that as a relative test rather than an exact indication of what temperature each location is holding. If you are using the kiln for heat treatment, the controller and associated sensor are really the critical piece of kit you need to setup. The cones may tell you what peak temperature the kiln gets to, but a calibrated thermocouple and readout will give you an instantaneous reading. Control systems are prone to drift, overshoot and hysteresis. Any of these can mess with your planned heat treatment cycle. Fortunately most simple carbon steel heat treatment doesn't need +/- 10 degree accuracy to give an acceptable outcome. Still, proper selection and setup of a correct controller/sensor system will lead to success more often than not. Your high power (coil supply) switch is also critical to good heat treat oven performance. Old school standard contactors will eventually arc, oxidize and fuse. SCR are great, but can be expensive and hard to tune. I used to use mercury relays in my builds. They are a good compromise between contactors and SCR, particularly if you can source them cheaply from a liquidator like I did. All things being equal, the more thermal mass in the system the slower, but more stable the heating.
