Everything posted by thingmaker3
Citric Acid - Where to Buy Locally?
Why go to the expense & effort of passivation? Is there a lot of iron imbedded in your surface somehow? :huh:
Paste Wax
I've had good results with Johnson's. I try to have the work not hot enough for it to smoke much, & only apply it outdoors. Petroleum products, you know... I also regularly use it cold on anvil & tools to reduce rust.
Good deal buying borax
K-mart has 4# for $4. In the laundry isle.
campfire Blowpipe/poker/blowker
Would something like a calla lily work? Cut one end with a hacksaw at a 45 on the diamond, then forge out?
What Preparations Should Be Made For Setting Up a Hammer-in
Might be a good idea to consult with your local fire marshal or similar authority in advance. Get their input on safety protocols. Some places put a ban on certain types of fires at certain times of year.
Broad Axe
Try putting the phrase "broad axe " in parentheses. It works.
- How to forge a bird?
Hugh McDonald Steel Rolling Mill
Steve is quite right about the diameters. It is better if they are the same! That CD sounds like I might need to get it...
Round-jaw bolt tongs
Take a nice fat piece of steel, get it up to yellow, lay it at a 45 on one of the edges on your anvil, then pound on it 'till it's a swege.
Hardening a Rail-Road Spike
Here's the old spec most of the knife sites misquote: http://www.worldclas...ikes/spikes.pdf Note it stated minimum rather than maximum carbon content, and that content depended on smelting process. The current ASTM spec lists 3 "grades" of spike. The beefiest of the three is identical to A36. How old are your spikes?
The upper roller is longer so that the lower one can clear the pillow blocks. :)
I hate to be the one to break this to ye, John, but the "decahydrate" in "sodium borate decahydrate" means it is not anhydrous. So too the "10 H2O" listed in the MSDS supplied by your vendor's link. http://www.cqconcepts.com/inc/inc_print_sodiumborate.html
Brick chisel for hot cut?
thingmaker3 replied to Elemental Metal Creations's topic in Hot Cuts, Anvil devils, metal cutting on the anvil.The brick chisel does make an adequate top tool. In years past, when I first got my 50# anvil doorstop, I quickly learned the brick chisel is not stable in the hardie hole. So, no, it don't work as a bottom tool.
Making Springs?
"Spring steel" is any steel good for making springs. 5160 and 4140 are good choices. Pretty much any low alloy steel with 35 to 75 points of carbon will work. Plain carbon steels with 70 to 95 points carbon will work. I've read that the 300 series stainless can work. It's a higher yield strength you're after in a spring.
heat treat titanium
I have never played with Ti. But... From the ASM's Metals Handbook, Volume 2, 8th Edition: "It has been shown that Ti-6 Al4 V sheet should be cooled to 1000F from a solution treating temperature of 1700 F in no more than 1.5 sec to develop maximum strength after aging, and that the delay from the time this material is removed from the furnace until it is water quenched should be limited to about 2 sec." Recommended solution treatment for bars from the same source is 1650 to 1750 F for 0.5 to 1 hour. For sheet, 1650 to 1725 for 5 to 20 minutes. Whether a knife would be more like a bar or more like a sheet, I cannot say.
That actually IS scientific, Nathan. It's just a matter of qualitative versus quantitative. Alloying elements other than carbon and boron have no effect on how hard the steel can get. They do change the amount of time you have to get there. Also, just because one can get 55Rc at 0.30% carbon (or 60Rc at 0.40%) does not mean one will get it. Regarding diffusion rates, (whales migrate, carbon diffuses) "Fast" and "slow" don't have any numbers attached to them. Nobody has defined "medium" yet in this thread. Look up "Fick's Second Law of Diffusion" using your favorite search engine. The diffusion coefficient of carbon in iron is dependent on concentration. Complicated stuff! Not the kind of thing about which we should be tossing absolute statements. One thing we can indeed state empirically about diffusion rates: plenty of smiths throughout history have welded steel to iron to make serviceable tools.
I need some advice.
Phil has a good point. I can get 5160 drops from a local spring shop for $0.75 per pound. That's only a quarter more per pound than my local junk yard charges for mystery steel.
Riveting problem - different metals / finishes - help!
Galvy prior to assembly & masking tape to keep paint off the rivets?
My candle holder
Have you looked at the ingredients listed on the side of that box? It would be healthier for you to eat the candles! I like the candle holder design. Nice curves.
4150 as quenched hardness and heat treating?
4140 as-quenched Jominy sample (quenched from 1550F) is 60 Rc at 1/4" from end. 50Rc at 1/2" from end. (per ASM's Atlas.) 4160 should be at least as good.
Introductory metalurgy
They said to me "Question authority!" I said in response "who are you to tell me what to do?" Read as much about metallurgy as you can. Compare. Contrast. Decide what writing makes sense and what is just babble. And most important of all: EXPERIMENT FOR YOURSELF!! :D
Coal -> Coke. Am I getting this right?
Coke is to coal as charcoal is to wood, or as whiskey is to beer. :)
Making a hammer eye drift ~ Brian Brazeal
Creep occurs at constant high temperature. Punches or chisels subjected to brief heats would not be susceptable to creep. ;)
how to make damascus
Before I welded up my first billet, a seasoned old fellow told me "if you can weld a stack of hacksaw blades together, you can do anything!" So I dutifully worked at getting a pair of hacksaw blades forge welded together. Took me a few tries. Then I welded up another pair - fewer tries to get this right. Then I worked at welding the two pair into a stack of four. THEN I found out I was supposed to weld a whole stack at once. So my advise is: weld a whole stack at once.
making a twister...
A complicated 1:1 gear ratio would be a little worse than just going without gears. A bit of energy is lost in the gears (turned into heat and noise). Add some more gears and something to turn the switch off? You do the same amount of work, but over a longer period of time. You therefore exert less force and power. Four jaw chucks hold pretty well, depending on the individual chuck. They're basically a fancy vice. I hope your project turns out well. It certainly sounds interesting. You might also want to search for the twister Ric Furrer made. Others here have posted about self made twisters as well.
