Everything posted by Dragons lair
Old Automobile Needs Assist
Grant, I was beginning to think I was the only one removing studs by welding a nut on. Actually i prefer 1in flatbar as long as possible. drill one end weld then tap other with a hammer. Locals here are amazed. Ken
Swordman needs smith
He did say "to fit a standard blade"
Barbecue fork turned....
Yance, I just looked on their site where and what have you heard. Been spending a lot of time on my consulting job. Usually around evenings and weekend afternoons. Ken
Killed acid soldering flux
Beware yellow snow and run from that yellow deposit. Zink and cad are TOXIC Ken
Argon Flow for TIG welding
cami, Try this one. Aluminum 40ft flat bed outside in a 20+mph wind. Lay on your side curled around the weld. Welding about level with your belt buckle. Milspec no less. Ken.
Yance is that the result of the computer crash at work. Nice save my friend. Ken
Bamboo kiridashi
Matthew, For the benifit of a few of us old folks what is it for? By the way welcome to the forge. As to selling I do not think is allowed in tailgating section.Best check with Glenn. Ken
Engineers Black Book
The machinery handbook is also great. I have 2 from the 30s-40s from my dad. Big one is about 2000 pages. Ken
I found this anvil, what do you guys think?
Most if not all the forge welded anvils I have seen have what appears to be a crack where they were welded toghter. Some are really visable some you have to look real hard. ichudov I don't know where in IL you are but I visit Joilet area every Sept. (mom in laws bday) in 4 yrs I only found 2 anvils both crap both over $3lb I now have (4) enough. If you are within 60 or so miles of there I may have time to visit. Ken
Fe-Wood I always set the fan about waist hight and angle up to my head. Welded actual Tons of aluminum that way in centeral FL. 17yrs of piecework. Ken
flat bar ring roller suggestions
rolling 3/8 x 5 to 2 ft dia is beyond hand power. Will need a power roll with atleast 3" rollers. very pricey. Check flebay under fabricating equip. Had a 3 hp chain drive 36" with 2" rolls at my last job it wouldn't come close. Ken
Charlotte, You caught me. Must be the oldtimers acting up again. Ken
Welding table
What is excessive heating? 30-60+ welds on 1/2 by 4 flat bar. sometimes torching out a piece. Sometimes heating to bend or streighten. Best way to warp a welding table is tacking things to it. Ken
Pros and cons of Anvil repairs
Weight marks 0 3 0 equals 84lbs. Most likley an old english anvil. Post pictures for better answers. Ken
Your trusty supplier makes money selling gas. For about 40 yrs I set mine at 20cfm indoors 30 and up outdoors both for mig and tig. Ken
Welding table
I built 3 5x5 tables with 3/4 inch tops set on a 5 inch channel frame with a cross brace. They were used to build 500lb guards for earth movers and 750lb robotic tables. No warp or sag after 5 yrs. The 1 1/2 in aluminum one was used for aircraft turbine parts. Flat after 10 yrs. Ken
465lb anvil
Viper if you can pick up a 465lb anvil may the forge be with you. I hate moving a 150 on a stump. Ken
Answering New Members Questions
Unfourtunatly most of the younger generation has been raised to demand/expect the answer/information to be given right now.My own included(EX wife raised them). We older 62+ folks had to learn from the school of hard knocks. Yoda had it right "Do or not Do, there is no try". Ken
Your leather apron?
Leather bib been using the same one for 30+yrs finaly wore a hole in it. HMMM patch or replace? Ken
centaur forge anvils
Rob-o you don't say where in SC. In the past yr I have gotten 2 H-Bs a 142lb in greenville and a 88lb at the Chesnee flea market. $310 total price. Don't be in a big hurry. Have found 2 vulcans 2 mouseholes 2 hay buddens and a trenton within 100 miles of Asheville. Ken
Victor Gauges - Repair myself or take to Welding Supply Pace for Repair?
Musent touch it. When in doubt send it out. I don't even try it with argon regs. Ken
Weld cast iron and mild steel
Not all rotors have studs in them. I have a few of them. Ken
A question on Punches & Chisels
Try any small welding/machine/or fab in tour area. usually have small drops and they should be able to tell you what it is. Ken
I dislike drilling holes.
Better? Probably. Easier? Not. Lets see 1" sq bar. Layout and center punch takes the same time. Light the forge,forge already lit. Heat bar, punch/drift hole.streighten/adjust hole. OR install drill bit,turn on,drill press,drill 6 perfectly streight holes in the same time True its not traditional, True there is material loss, However for me its easier and quicker. Ken
Welding table
#1 would be a cast iron acorn table. #2 would be 1 1/2in thick aluminum plate. Don't have either in my shop but have used both. Need creative clamps for the alum but NO spatter sticking and NO warping no matter how hot you weld. Have warped a 5X5ft 5/8 top welding 500lb brush guards. Hope those days are past. Ken
