Everything posted by M. Demetrius
I used to be a file ... tanto
Some old knives have file remnants left in the blade to show they were made of high carbon metal, rather than softer iron. If it were up to me, I'd say leave them.
Making Roman Hobnails
For hobnails, hardening isn't really desirable. They'll outlast the leather in the shoes, no matter what (except for the ones that disappear because they weren't clinched properly--which requires softer metal. I'd think and ash bucket to drop them in might be the way to go, but hey, what do I know? Let 'em be soft, says I. The cones are still harder than dirt, y'know.
Good steel for gooseneck holdowns?
I found the spline end of a truck driveshaft lying by the road. It has the spline, some kind of housing, a 1 ft length of driveshaft and the U-joint with its mount. Are any parts of that higher quality steel? The spline is about 3" in diameter, which makes me think of a dumptruck or something.
Javelins
Seems like a lot to draw out for the shaft, but you're probably doing it the right way. Do you have a power hammer?
Javelins
OK< next dumb pilum question. For those with a flat tang, do you fold back and forge weld the metal to get more material there, or do you draw out the entire shaft from thicker stock. Seems like there's only those two ways to go, and both involve some significant work...I've put down the pilum project for quite a while, but it's floating back up to the top of the list. I think the most likely way I'll attempt next is to draw a point about 3" long, turn it back onto itself and attempt to forge weld it. Then, when I make that trapezoidal tang, there should be from twice as much metal at the large end to a single thickness at the point. Am I overthinking this? If you flatten, say, a 3/8" square bar out to 1 1/4" wide at the large end of the tang, it's really thin there, and not much thicker as you work up to the full thickness at the end of the collet. Many pila I made way back when (small bottle propane torch: yikes!) were very weak at that point. How do the big boys do it?
Javelins
Very nice work. When you made that collet for the "regular" pilum, did you start with a cut piece of square tubing and stretch it into the pyramidal shape? Do you do Roman somewhere? I'm in the Tenth Fretensis HQ in Houston, TX
Heading nails
At least you didn't have to light the fire in the forge for that...
Javelins
Thanks Ferrarivs. I don't mind the hole so much, because I suspect it would save a few minutes at the forge, and the people making the originals had thousands to make when they geared up. Thousands of few minutes saved makes a few days saved. Might save a slave smith a flogging, and that's always good.
Thanks for the good info. Should I put this hobnail bit in another thread? I don't want to be a hijacker. Here's a sketch of the hobnails. I plan to scale them down to 1/4" diameter and height from the artist's 5/16". Seems like the heading tool could be made by drilling a bar into its end, maybe 3/16" diameter and depth, then heating that drilled end and forcing a "right shaped" 1/4" punch into the hole. That should widen and deepen it enough to do the task. I guess I'd need to figure out how to harden the tool, probably just after it cooled down to red with a quick quench in water? Which would be less fatiguing over a run of a hundred or two nails--a direct straight punch type, or a handled tool type? Obviously the plain punch would be easier to make...but wood handled tools have advantages, too, once made.
Contacting Orange Steel
Whew! When I saw the title, the first thought that came to mind was, "Don't ever contact orange steel! It will burn the heck out of you before you realize it!" I feel a little better now.
I have a question about a "special nail". Specifically conical headed hobnails, like would be found on Roman military boots. The diameter of the cone end should be about 1/4" to 5/16". The height of the cone ought to be at least a quarter inch. The shaft of the nail (not important if it's flat or round) has to be about 1/2", so it can go through a couple of layers of sole leather and still have enough to clinch over. It takes about a hundred to make a pair of boots. Being basically a bonehead, and a beginner, I can't figure out how to make these. Anybody got a good idea? (heck, even a mediocre idea would help...) The only thing I've though of so far is to make a conical tool to hammer down over the really hot metal of the nail. IOW, knock the longer-than-usual head end into the cone shape, using a conical socket. Does that make any sense? Sounds like a torch would be a better heat source than the forge for something that small. Then I guess I could use a thin piece of mild steel stock, form the point, set in a header, heat, put the cone on top and smack it a time or two to form the head. Am I thinking right for a change?
Shade 3 flip up clip on lens for forge work
I was told for torch welding (and presumably forge welding) that green shade 4 is safe, too. Were they telling me rightly? That's what I bought, on the recommendation of the welding supply guy. I wear glasses, and these safety/color glasses fit on just fine over my glasses. It's hard to see at night working at the forge, though, because once I look away from the fire, everything is very dim. Should I light the area more with regular light to overcome this? I also have a full face shield in 4. In some ways, especially when it's hot weather (Texas) that is nicer, because I can be shielded and then bare face for a breeze with just one little adjustment.
Safety glasses for forging...
You could just get a yard or two of cotton flannel from the fabric store or WalMart, and tear it to the size you need. Flannel is available in all kinds of colors and prints to suit your liking, is machine washable, and doesn't cost much. It's pretty absorbent, too. Woven fabric like flannel will tear in a straight line along the weave, so it's pretty easy to get a square. If you want to get really uptown, you can put a narrow hem in the outer edges. Or just serge or zigzag stitch over the edges, to help prevent unraveling. Beware, they may call you a Pirate, matey! Arrr.
New Spear
I bought what they said was a "spud wrench" at a junk store. It looked like about a 1 1/4 inch open ended wrench with a marlinspike at the end of the handle. I cut it, drew part of it into a spike, bent it over, and boing! a stump bick. Got the spike red, and hammered it down into the stump. Smoked like crazy for a while. When it stopped, I gave it a couple more hits to set it and it seems fairly secure for the time being. My daughter said, "Why did you need to make a handle for a stump? Where are you going to carry it?" Sigh.
Javelins
Thanks, Dave. It's exactly like a miniature socketed pilum. These are Late Republic/Principate era javelins. I think they got simpler under Augustus and beyond, leaving out the central shaft. But you gotta love the look of these, don't you? Sleek. So the metal gradually thickens as it approaches the shaft? That would be easier and a couple of heats less than having to make that trapezoid first. I don't really see it's being easy to eliminate that gap where the two figures merge. There will probably be a hole or space of one kind or another at the upper end of the cone. Is that normative? Are you with a group in UK? I'm hooked up with Terry Nix's Leg XF in Texas.
Spear
That's almost identical to the javelins I need to make (but bigger, of course), there's a thread by that title in this same topic series. Could you lend any advice there? I've had spear sockets begin to spiral, or go off line, and just frowned and kept on with it. I have been told there is a solution for the problem, and that they can be straightened...but they work fine without an absolutely straight seam. That's not what the guy on the other side of the shield would be looking at anyway, I reckon.
Spear Head
All you say there, ironrosefarms, is pretty close. The weighted pila had what we think to be a lead ball just behind the metal rod tip, which could make them weigh three or four pounds (some had two weights!). Imagine a 4 lb thrown spear hitting you on about a 1mm square point. Lots of energy focus, that. The spear points you started the thread with would be used mostly by Auxillia, not so much by the legionaries. Auxillia being non-citizens until late in the Empire, the government didn't want to give them the most effective throwing spears...for obvious reasons. Most cultures in that day fought with spears or spears and shields, so the training curve was flatter. There were probably 20 kinds of designs for Roman spear points (hasta was a fighting or sometimes a throwing spear from 5 to 7 ft long overall; lancea was a longer-shafted cavalry spear, or lance). Javelins other than pila (plural of pilum) just looked like shorter spears, with various designs. There. Free, unsolicited history lessons. For some good pictures of all sorts of Roman equipment, go here: Legio XX--The Twentieth Legion
Javelins
I plan to make a few Roman javelins (not the pilum type this time) which look like socketed spear points with a "long neck" in between the socket and the point. Some had leaf-shaped points, some had pyramidal points. Example here I've never done this process before, so tell me if I'm thinking the right way. I'm starting from about 8" of 1/2" mild steel square stock. 1. taper the butt into a trapezoid, large end out, flatten some, then thin it into a socket by using a fuller and hammer. 2. draw out the "neck" 3a. shape the leaf point into a rough, flattened "right shape", then forge to cutting edges and point. 3b. or, draw the distal end into a 4-sided pyramid for that type point 4. Shape the socket around the newly installed stump bick to fit the shaft. I'm using 3' x 3/4" hardwood dowel, so the open end has to be smaller than 3/4" by a little, to allow for fitting the wood 5. drill and put a pin to hold the socket on. Sound right? Should I aim in a different direction or order? Should I start at the pointy end first?
Flint Striker
Mike said, "the original early Roman artifacts they actually are -" Mike, do you have any pictures of Roman strikers from the 1st Cent BC to 1st Cent AD? If I'm going to go to the trouble to make some, might as well get them in the right neighborhood. Size is important, too. Most of the ones I've seen pix of that claim to be Roman are a thick striking edge, but a folded in handle, that looks more or less like the letter B. Are those the real deal? Also, if you can't find good striking stones around, look in places like Panther Primitives for those "Indian arrowpoints". Many are made in Mexico in present times, and are clunky for real arrowpoints, but only cost a quarter or something like that. Make good sparks, and have sharp edges all around. pantherprimitives.com, pg 125 of their current catalog. Nice folks, too.
Flint Striker
Another (probably already mentioned) can is an empty shoe polish container. Anybody who uses them knows they close up plenty tight. A 3d nail makes about the right sized hole. I usually use old blue jeans (hey, that's about all I seem to have these days) for charcloth, and it works just fine. If you want to make a whole bunch, go to the paint store and buy a pint or quart empty metal paint can, and punch a 1/8" hole in the top. Be sure to pack the can pretty full of cloth, or you'll open it to find mostly cotton ashes. Heh. Done that...with people watching, too. Funny now, but not so much then. Any plant fiber cloth will work, but wool or any synthetics will not. If you're not sure, burn a little bit in a flame. If it smells like hair, don't use it. If it melts, it's not "natural", don't use it.
Blade beveling
That's a right large anvil, ApprenticeMan. Who's holding the blank in place for you, or how are you keeping it still while you sledge it??
Making Roman Armor
For a very good description of how "real" Roman armor looked, try here: Legio XX Scale Armor This website is well researched, and shows some photos of actual artifacts. Using the size of an average scale, a shirt would have somewhere in the neighborhood of 15000 scales, all punched and sewn down on a heavy, layered linen (or soft leather) shirt with fine wire. Might take all afternoon to make that, probably ought to bring a sandwich with you when you go out to the shop. If you're making the TV stage piece that they used in that series (which I really like, though there are a number of historical inaccuracies, as usual) then you will only need a couple of hundred scales. But be aware that Roman armor didn't really look like that. For ease of construction, have you considered using mild steel sheet, say 18 or 20 gauge, heating with a torch and brushing it with a bronze brush? It gives a very similar look, without the expense and extra weight of bronze. Good luck on that piece. Looks like fun.
Peen Radius...
Rule of thumb? Don't have it under the ball of the hammer during impact. (Heh. Couldn't resist...don't kill me)
Re-bar knife.
Did you split the rebar and insert the file frag in the opening to weld it?
Midrib spears/swords
How did that work out, Gobae? What about a hardy hole mounted spring swage for those of us who don't have helpers? That should work, I'd think for the midrib. I'll let you know once I get that tool made/welded. Working on it in stages now. While the ancients had the ability to forge weld, I rather suspect they didn't weld the mid rib on. More likely they just beat the edges of an iron billet thinner, and used either a swage or a special hammer/anvil for that purpose. This is based on partly speculation, and partly from seeing some of the small stump anvils they used (in photos from museums). Just mounted a small bick on a stump, and working on shaping a larger one for the socket end of javelins and spears...and other things, of course.
