Everything posted by wpearson
Radial blade blowers
https://www.google.com/search?q=%22bouncy+castle%22+fan?&es_sm=93&tbm=isch&tbo=u&source=univ&sa=X&ei=59D2U5TrOof7iwKT9oCoBg&ved=0CCkQsAQ&biw=1366&bih=643
Something between an angle grinder and a drill, need ID
quite old has no plastic.
Draft not strong enough?
http://www.iforgeiron.com/page/index.html/_/blueprints/uri-hofi-series/bp1048-side-draft-chimney-r175
custom made anvil help
No need to call google has it. GRADES OF STEEL We produce more than 300 standard types of steel in a range of quality levels. In addition, we make more than 450 customized alloy steel grades such as the ones shown below. The Practical Data for Metallurgists handbook has more information for you – go to the “physical constants – grades of steel” page to learn more. Carburizing Steel Grades 4120 5120 8620/8720 4720 4320 3310/3311 CBS-600* CBS-50 Nil* - See more at: http://timkensteel.com/what-we-make/high-performance-steel/grades-of-steel#sthash.R3hNXcWW.dpuf RESTRICTED HARDENABILITY STEELS Chemical Composition Ranges SAE No. C Mn Si Ni Cr Mo 15B21RH(1) .17/.22 .80/1.10 .15/.35 ............. ............. ............. 15B35RH(1) .33/.38 .80/1.10 .15/.35 ............. ............. ............. 3310RH .08/.13 .40/.60 .15/.35 3.25/3.75 1.40/1.75 ............. 4027RH .25/.30 .70/.90 .15/.35 ............. ............. .20/.30 4118RH .18/.23 .70/.90 .15/.35 ............. .40/.60 .08/.15 4120RH .18/.23 .90/1.20 .15/.35 ............. .40/.60 .13/.20 4130RH .28/.33 .40/.60 .15/.35 ............. .80/1.10 .15/.25 4140RH .38/.43 .75/1.00 .15/.35 ............. .80/1.10 .15/.25 4145RH .43/.48 .75/1.00 .15/.35 ............. .80/1.10 .15/.25 4161RH .56/.64 .75/1.00 .15/.35 ............. .70/.90 .25/.35 4320RH .17/.22 .45/.65 .15/.35 1.65/2.00 .40/.60 .20/.30 4620RH .17/.22 .45/.65 .15/.35 1.65/2.00 ............. .20/.30 4820RH .18/.23 .50/.70 .15/.35 3.25/3.75 ............. .20/.30 50B40RH(1) .38/.43 .75/1.00 .15/.35 ............. .40/.60 ............. 5130RH .28/.33 .70/.90 .15/.35 ............. .80/1.10 ............. 5140RH .38/.43 .70/.90 .15/.35 ............. .70/.90 ............. 5160RH .56/.64 .75/1.00 .15/.35 ............. .70/.90 ............. 8620RH .18/.23 .70/.90 .15/.35 .40/.70 .40/.60 .15/.25 8622RH .20/.25 .70/.90 .15/.35 .40/.70 .40/.60 .15/.25 8720RH .18/.23 .70/.90 .15/.35 .40/.70 .40/.60 .20/.30 8822RH .20/.25 .75/1.00 .15/.35 .40/.70 .40/.60 .30/.40 9310RH .08/.13 .45/.65 .15/.35 3.00/3.50 1.00/1.40 .08/.15 Unless specified: Cu 5 .35 max, Ni 5 .25 max, Cr 5 .20 max, Mo 5 .06 max (1) B 5 .0005 /.003
Throwing 'hawk vs. non-throwing 'hawk, featuring Mike Deibert
I would not want to meet some 4'6" dude carrying that in a dark alley.
Need Help
Start by reading he pinned threads here http://www.iforgeiron.com/forum/6-blacksmithing-general-discussion/
- found in the scrapyard
Home build induction heater
can you use 1mm ceramic paper ?
About to get a Diamondback 2 burner forge, need to figure out what to put it on
old gas grill cart ?
Straight Razor
Tire iron?
Value??
"A guy I work with recently asked me if I want to buy his anvil. He has it sitting on his porch on a stump as a decoration."
- Odd Marking on my Wright Anvil
- press power
If you never visited Shorpy
downdraft
- How to best search IFI?
Hydraulic Cylinder Source?
Parker Tie Rod Hydraulic Cylinders are available in a range of bore sizes for medium and heavy duty service. Each series offers a range of mounting options, superior performance, and durability. Use the comparison chart and click below on any of the products for more information. Series Bore Stroke Range** Max Pressure Type 2HX 2" - 8" Up to 72" 3000 psi Heavy Duty, Electrohydraulic 3H 7" - 8" Up to 120" 3000 psi Heavy Duty 3H Large Bore 10" - 20"* Up to 120" 3000 psi Heavy Duty, Large Bore 3L 1" - 8" Up to 120" 1000 psi Medium Duty HMI 25- 200mm Up to 3048mm 3000 psi Heavy Duty, Metric ISO 6020/2 VH 2-1/2" - 8" Up to 72" 3000 psi Heavy Duty Wave Scale 1/2" - 8" Up to 100" 3000 psi LDT *Consut catalog for pressure rating limits, e.g. mounting specific pressure limitations **Consult factory for longer stroke sizes
- Electrical resitance heating
- Identifying a Peter Wright Anvil - Opinions?
Anyone ever see or use one of these?
sales pitch here
Gas pipe fittings that are made the USA
Google has options on the first page wes
Bouncy castle blowers
like this '?do=embed' frameborder='0' data-embedContent>>
New frosty "T" burner! What causes flame outs?
flares get hot replace when burned out wes
Controlling hair dryer
make one '?do=embed' frameborder='0' data-embedContent>> '?do=embed' frameborder='0' data-embedContent>>
touch mark / logo question
These were found using the IForgeIron search engine.
