Everything posted by MOONY
Coal in Sydney
ye i looked in to them it might be the only thing to get Pacific Carbon ,Thanks Pill but i do get good coking coal a make coke out of it i put it around the fire wet it cokes up as the day runs on, but it is a bit dirty you get a bit of clinders moony
forging titanium
ye the titamium i forge was eazy it forged like mild steel only softer and yes dont try to forge it to cold alawys keep it hoter the 900 c a bit lower but to move it best over 900 i made a flower from a lump 2'' round 2'' long moony
Lock
How do YOU make curtain rings?
hi all i made curtain ring in my home for our widows the rod is 1'' solid bar long enough to coverthe window with 2.1/2 ''forged steel balls on the end the large rings are 1/2 bar in to a ring 3'' inside diamitor i made a turning mandrel with a crank handle i made like it was a coil spring enough to make 8 in one batch heat the small rings i found old coil spring from roller door i cut with 1mm vip cut disc then close on to large ring it all looks a reet over the window also made small brackets to hold it all up i made good browny points with darling lololol
Stone cold to white hot in under 50 hammer blows
Hi all, yes, didbrookforge he got it. It's not hard to do just good hammer control good on you, light your fire of life and enjoy moony
How to silence a power hammer
with a anyang an many other air hammers there is no real exhaust out let tha anyang exaust under the fly wheel so no place to put a pipe massey under the frame some of the other fabricated hammers blow out a small pipe these you might be able to duct but its the smak that is the trouble with noise notso much the air you can build asound proof room to have the hammer if that one way to shut it up lolol
DO NOT TURN IT ON WILL BE THE BEST
Get " HAMMERED " at MOONY'S
well it all went great, there was 17 of us there hammering away i had no camera to take pictures i hope others have picture to post i have been crook with a fever from Tuesday , it is now friday and i am starting to feel bit better not sure what i had but i got crook well i hope some pictures come up moony
Lindsay & Andrew playing with Chullora steam hammer
well only 2 days an we all get hammered
Preparing to install my Massey 3cwt
hello to all yes jim has it about right i used timbers under my 7cwt massey but i not have nexty worries there are a few insulator pads the jame walker stuff i have information on and it looks a good product and to have 2 concrete foundation is another idea the first is a think base slb with the pad on top then anothe concrete block pour on top this block is the full main block and then in the pit where the anvil is set u put mor pads under tyhe anvil then put the hammer frame on top all bolted down with the tee head bolts in the tube set up and you should not have ground vibration travel theres a bit more to keep the side walls of the top slab block away from the sides of the hole but i not going in to full details moony
hi all well only 13 days till ge all get hammered again things still on track and happening i been blind the lastfew day got a welding flash and bits of grinding sparks in the eyes ooooooo no goood
look forward too us all getting together hammering away only a few more weeks see you all Friday or the day you arrive moony
its all happening and only a few more weeks till it is get hammered things here are progressing with a reorganizing and sorting hope too see you all here moony
Signals to the striker
there are many differant signal each smith might have a little different for another, as long as your helper understands the signal you give ,then it all good just, don't miss the flatter head and hit the handle or the smith MIGHT chase you around with a hot settt lolol or look out
- Lithgow Ironfest 2013
lolo, to find u brain or pick it lololo we are all mad , obnly i think you might be more madder than I but thats debatable , well the swing crane works a treat and the furnace near the big press is there but i not built a crane over it yet and i hope to take the old steamy down to front gate this week coming i am doing some re adjusting things around in the work shop but same sort of set up with large forge table and othere bits look forward to all attending get hammered
URI HOFI returning to the USA October 9-20, 2013
well i would love to get over, but australia is a bit fare for a few day but its good to see mr Hofi is still teaching one day he might get over to australia we love to have him here moony ps ,have a nice day on the 11 of October, and have a beer with me its my birthday ,
Well hi to all it not long now, i got a swing crane next to the 7cwt to hold heavy bits. the 1000 toner press has dies and a furnace near it and i am hopefully putting a swing crane next to the 1000 toner so large bits can come out of the furnace an forge under the 1000- toner and the old steam hammer is going down front gate , so its all on, don't forget the new dates for get hammered are 18 19 20 october 2013, the 18th is for the early one to get here and ready so look forward to a good safe weekend Moon
where would I find information on taking on an apprentice ?
hello Basher we have not met up yet my name is Glenn moon i am in Australia i have had many apprentices in Blacksmithing over the year but i live here also i am part time college teacher in industrial Blacksmithing i believe that the college is Hereforshire has formal classes if you talk with them they might be able to help you aslo good to see you smelting iron i have been smelting iron for about 17years but its a funn thing no money in it just for laughs to make wootz cakes from the iron well if you ever over here you be most welcome in my workshop i have a 7CWT massey and a few anyang and a few hydraulic presses hope one day to get back over to uk moony
hello to all - well only a few months till get hammered and we all should have great time i have the dies in the 1000 toner and a furnace set up next to it to forge some largish bits lolol
Big 50, Thought this was worth posting...
WELL I SHOULD HAVE READ MORE SORRY, usa has not got it i thought it was in usa go the germans lolol
well its great to the the old girl still got it in her, and they re fit it , it make my 1000 tonner look like a toy, and i thought my baby was great , but if they ever decide to scrap it i make an offer but my generator will have a heart attack trying to run that babies motors good to see that SOME U S A COMPANYS HAVE STILL GOT THE BRAINS TO KEEP GOING
Welcome to the Brisbane Blacksmith Group. ABAQld
hi all this is glenn moon get hammered it held at ,my work in braidwood nsw on last weekend in october each year let me know if you are interested in attending email [email protected] bring your own camping gear and favourite hammer and gloves and safety gear cheers
i hope to have my old steamy down at the front gate this year
