Glenn Posted March 26, 2017 Share Posted March 26, 2017 A blacksmith can and will use most anything available to their advantage. He will recognize the advantage and put it to use in his shop. And it is ok to borrow from another craft or industry as they have already invented the wheel so to speak. You just put it to use in another way. We always need new tools, or ways of doing things. What items have you put to use in your shop? To measure a curved object, use a plastic sewing tape measure which is very flexible and follows the curves very well. Read the measurement directly on the tape. You can use a piece of solder to do the same thing. Quote Link to comment Share on other sites More sharing options...
SLAG Posted March 26, 2017 Share Posted March 26, 2017 Or florists wire. (it is a very small diameter wire). or extra long pipe cleaners. SLAG. Quote Link to comment Share on other sites More sharing options...
gote Posted March 27, 2017 Share Posted March 27, 2017 I use a portable adjustable stand intended for miter saws to support long stock when I need to have the hands free. I use an old vac to blow my smoke out. My slake tub is intended for masonry. I use a funny kitchen tong Intended to grap whatnots to pick coals that may have fallen to the floor. I use a kitchen gas burner intended for glazing puddings to start my fire - The flame reaches further down than a match. Quote Link to comment Share on other sites More sharing options...
Glenn Posted March 27, 2017 Author Share Posted March 27, 2017 Most folks have an adjustable height rest, or third hand, in their shop or close by. They call it an auto jack stand. Cribbing may help get it to the right height. For taller projects use a transmission jack stand. Need a micro adjustment? Use a bottle jack on cribbing, an auto hydraulic floor jack, or engine hoist. And if a fellow had a screw type house jack handy , , , Quote Link to comment Share on other sites More sharing options...
gote Posted March 27, 2017 Share Posted March 27, 2017 You asked for cross-over Glenn. This is a carpentry item used in a blacksmith shop. And I forgot. I use a discarded aluminium frying pan with the "edges" cut off to protect the anvil when chiseling. The handle is handy. Quote Link to comment Share on other sites More sharing options...
JHCC Posted March 27, 2017 Share Posted March 27, 2017 13 minutes ago, gote said: I use a discarded aluminium frying pan with the "edges" cut off to protect the anvil when chiseling. The handle is handy. That's a nifty idea. Must remember that on the next thrift shop visit. Quote Link to comment Share on other sites More sharing options...
gote Posted April 13, 2017 Share Posted April 13, 2017 And I use a little stainless gardening "hand showel" intended for potting compost in the forge. It is perfect the way I run the relatively small forge. I always have the fire covered so the short handle is no disadvantage. Quote Link to comment Share on other sites More sharing options...
ausfire Posted April 13, 2017 Share Posted April 13, 2017 For doing twists in square bar I always use one of those thread-cutting tools. They give equal weight on each side which avoids bending, and they are adjustable to suit the size of the stock. I have a bunch of them to suit the work, from the little 6 inch guy up to the 3 footer. Quote Link to comment Share on other sites More sharing options...
seldom (dick renker) Posted April 26, 2017 Share Posted April 26, 2017 i use a little jewelry hammer for detailing some of my work. it has cross hatching and lines Quote Link to comment Share on other sites More sharing options...
metalmangeler Posted April 26, 2017 Share Posted April 26, 2017 I remember maybe 30 years ago I was in a small local horseshoe forging competion, I had a tent stake I was using as a bob punch for my clips. One of the other guys thought it was some specialty tool with the hook there to protect my hand if I lacked enough control to keep from hitting my hand. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted April 26, 2017 Share Posted April 26, 2017 CV joint from a car as a hardie dishing tool.. Quote Link to comment Share on other sites More sharing options...
Mtnstream Posted April 26, 2017 Share Posted April 26, 2017 I made a couple of carpentry marking knives and find I use them for marking mild steel more than wood. They scribe a thin and precise line in the metal. I also use my professional grade tempering oven (toaster oven) to cook mini pizzas. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 29, 2017 Share Posted April 29, 2017 On 4/26/2017 at 8:36 AM, jlpservicesinc said: CV joint from a car as a hardie dishing tool.. Thought I was the only one to use them. Quote Link to comment Share on other sites More sharing options...
rthibeau Posted April 29, 2017 Share Posted April 29, 2017 make your stock stands (3rd hands, jack type support) adjustable by using pipe for the stem....one piece sleeves into the larger to slide the adjustment up or down. The outer pipe has a hole drilled into one side, a nut welded to the hole and a "T' handle welded to the bolt fitting the nut ... this locks the inner pipe in place..... could use an eye bolt just need enough to give torque to lock the pipes in place. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 30, 2017 Share Posted April 30, 2017 Trailer hitch ball's as domed anvil hardies. Quote Link to comment Share on other sites More sharing options...
