Ed_Steinkirchner Posted December 20, 2015 Posted December 20, 2015 Well this has been a project that Ive been wanting to do for quite a while now and I'm glad to say it is finally finished. Its inspired from the pictures of a few compact DePew helve hammers i saw pictures of as well as the Hawkeye helve and a few others, as well as some of my own ideas. I was originally going to build a spare tire hammer but couldn't wrangle up the parts, so i looked around the shop at what i had and what space i had to work with. I still intend to build the tire hammer at some point and there are a few parts that i purposely avoided using in this build in order to save them for that project. but the most important parts here were constructed from mostly barstock. The hammer head was build of 1'' square welded into a heavier block, the helve arm from 1/2''x1 1/2'' and 1''x1/2'' bar welded into an I beam configuration, the large curved supports on the top and bottom are 1'' square and round bent cold in the bottle jack press, the treadle is of 1/2'' square, the lifting linkage is of mostly 1/2'' round, the eccentric crank is 1'' square bar welded to a heavy 1'' shaft sprocket hub from the tractor supply store, and the anvil itself (the top face at least) is of 1'' square and round alternating to leave a ''v'' for welding into a solid plate on which to mount the dies. The other main pieces are the 3/4 horsepower electric motor with a 1 1/2'' v belt pully, the 13'' spoked pulley on the other side of the eccentric shaft (set in ball bearings), the trailor spring on top, and of course the cones that make up the anvil and base of the machine. Now the cones are what inspired this all in the first place, they are two steel shells that originally lined with ceramic and were part of a coal seperation unit called a cyclone, i got them where i used to work. The cones are relatively thin though at around 1/8'' thick which made reinforcements necessary at the anvil end. The flange was torched off of the "point" and a slice of 6" OD pipe tacked into place, then pieces of 1'' bar were cut to fit the round pipe ID a,d tacked into place, finally small pieces of 1/2'' square bare were welded under the ring to spread the impact load more evenly around the cone. A few final things to note: the dies are removable and interchangeable as long as nearly the same weight is maintained (so as not to affect the tuning), the spacing of the dies is adjustable by moving the bolt in the spring shackle into a higher/lower hole, the crank offset is also adjustable by moving the crank bolt into one of three holes(1 1/2'' offset, 2 1/2'' offset, and 3 1/2'' offset) though the machine is tuned at 2 1/2'' offset (5'' throw overall) and the motor isn't quite strong enough to run it at the widest offset, and the smallest offset is really there for planishing and optional sheetmetal work. And for those who are wondering, the "Clutch" is just the motor itself being mounted on the treadle so that when depressed the motor moves down slightly which tightens the belt and engages the hammer. Quote
Ed Steinkirchner Posted December 20, 2015 Posted December 20, 2015 Also it appears that i accidentally posted that in the account i made when i thought i lost my account name ages ago... back when i didnt know how to work a computer. i guess this computer saved the login info and i never told it otherwise! so long story short, this is my post, sorry about that Quote
jeremy k Posted December 20, 2015 Posted December 20, 2015 Ed - How does it work on hot metal - does it exceed your desires? Quote
FlyingXS Posted December 23, 2015 Posted December 23, 2015 That has a fantastic ol skool look to it. What are some of the parts made from?? Quote
otto Posted December 27, 2015 Posted December 27, 2015 That looks great. I have been thinking of building something that size. How does it work on 1/4" stock? I mostly do knives and small stuff and have been looking at hydrolic presses but think the speed of a power hammer would be better. Quote
Ethan the blacksmith Posted December 28, 2015 Posted December 28, 2015 one of the better homemade power hammers I have seen. Quote
Robby Cicco Posted February 16, 2016 Posted February 16, 2016 Yes, I second mofokaye's request for video. Let's see this baby in action. She's beautiful. Quote
Stormcrow Posted February 17, 2016 Posted February 17, 2016 Looks like it would fall in the category of the Depew hammer design, unless my brain is too tired to remember correctly. I dig it! Quote
eseemann Posted May 29, 2016 Posted May 29, 2016 Ed, How do you figure out how much of a counterweight to use on the eccentric? It does look like a winner. Quote
Ed_Steinkirchner Posted November 4, 2017 Author Posted November 4, 2017 Sorry for not responding to any of the above questions, but my old phone wouldn't let me view ifi soon after posting this and my laptop had a real hatred for the forum as well and would let me make posts but not replies. Ive since gotten new of both and am able to post here once again! As a response to some of the above questions: It worked as it was on smal stock (up to about 3/4 square) but hit too lightly and would cause edges to mushroom. I haven't had much time to redesign it but ive upped the power to a 3/4hp motor, added a jackshaft to reduce the sleed and move the motor off the treadle, using instead an idler pulley on the treadle to act as the clutch. The original motor would bog down on the longest throw of the crank. It still needs more weight, a concrete pad poured under it to bolt to, a heavier flywheel, and a DuPont style spring assembly instead of the leaf spring. Quote
