July 23, 201511 yr I couldn't see where this had been posted before, maybe I didn't just miss it. Thought ya'll might like it. This kind of stuff just amazes me. Edited July 23, 201511 yr by norrin_radd
July 23, 201511 yr That's insane, I'd like to see what they ended up makin out of that piece of steel. I also can't help but wonder how long it too to get that thing up to forgin temps and what they used for fuel.
July 24, 201511 yr See, if you have a 5,000ton press you don't have to move fast. There were a number of large shafts in the opening shot probably blanking for one of those.Frosty The Lucky.
July 24, 201511 yr Have you all looked through what Scot forge has for forging here in America? www.scotforge.com (one of their Metallurgists sometimes posts here as he smiths at home too though with a measly 300#? Bradley hammer...or have you tooled *up* *again* PN?)
July 24, 201511 yr everybody aims for the biggest, will see if I can make the smallest useful forging press over the next month or so
July 24, 201511 yr everybody aims for the biggest, will see if I can make the smallest useful forging press over the next month or so Hmmmm. I thought I was the only one considering making a mechanical power hammer out of an old Singer treadle sewing machine.Frosty The Lucky.
July 24, 201511 yr Author Have you all looked through what Scot forge has for forging here in America? www.scotforge.com (one of their Metallurgists sometimes posts here as he smiths at home too though with a measly 300#? Bradley hammer...or have you tooled *up* *again* PN?)I didnt know anything like this existed anywhere but I checked out that site, pretty cool stuff. ThanksThere is a cool pic here:http://www.scotforge.com/Learning-Center/Metalworking-Alternatives
July 24, 201511 yr everybody aims for the biggest, will see if I can make the smallest useful forging press over the next month or so I tried building one using a scissor jack and a drill just to see if I could. It didn't work out too well. My welding at the time was crappy at best and my frame wasn't made from sutable material. Other than that an the fact at a cordless drill only has so much power I think it would've work wonders lol.
July 24, 201511 yr About 15 years ago one of the SOFA guys was building 2# powerhammer that would fit in the hardy hole and use the anvil as it's anvil. Also Ptree made a *working* powerhammer he mounted on his hat for a quad-state. They even heated a pin with a lighter and proved it would forge!
September 12, 201510 yr The largest press Scot Forge has in operation now is 5500 ton. They have a joint venture on going in New Castle Pa (North American Forgemasters) that is installing a 10,100 ton press that will be able to handle ingots on the order of 200,000 lbs. That press should be up and running by the end of the year. Heating times for large ingots vary by size, but a 30" diameter ingot will take around 24 hours. Larger ingots can take twice or three times as long. The fuel is natural gas fired box style furnaces, some easily as large as a two car garage. The Scot Forge website was significantly overhauled earlier this year and now is by far the best in the industry. With nothing more than that website I could teach an entire class on industrial open die forging.By the way Thomas, yes I do have a bigger Bradley than the 300, a 500) and thought it is in the shop I don't have the motor hooked to it yet.
September 12, 201510 yr Good Morning,The US Government built "the Fifty". It is now owned and used by Alcoa for aluminum and other material. I am posting the link with the history and the manufacturing process. Casting, Machining, Forging, Turning, 200 to 500 Ton pieces. What this means to me, the machine tools and the forges had to be made first, before the process was started. Absolutely AWESOME!!!https://www.asme.org/getmedia/22448cc7-1dd1-407d-83eb-f9c1183f4757/71-ALCOA-50000-ton-Hydraulic-Forging-Press.aspx There are now larger Presses in other parts of the world, I believe now up to 150,000 Ton.Please enjoy the story and accept it for what it is. It brings a little "Humble Pie" to our dinner plate.Neil
September 14, 201510 yr Cool video, quite impressive.I would have thought Thor's hammer would have been forged in Valhalla, go figure.
