SilverDeck Posted September 11, 2014 Share Posted September 11, 2014 I came across this rail anvil this past July at a local garage sale and ended up bringing it home for $10. I was really impressed by the amount of work and talent that went in to transforming it from an ordinary section of rail into the finished piece. It's almost a piece of machinist's folk art. Anyway, I just completed the process of getting it cleaned up and wanted to post some before and after pics. When I got it, the anvil had been coated with multiple coats (and colors) of paint; all of which was peeling and flaking. I decided to remove the paint but leave the rest of the metal patina intact instead of scrubbing/brushing it down to bright metal. The paint came off with a chemical strip and gentle wire brushing. Any residual stripper was removed and neutralized by a wipe down with mineral spirits. Then the piece was coated with light application to tung oil followed by Renaissance wax to protect the steel surfaces. For some reason the lighting in the "after" pics caused the metal surfaces to look a little more "orange" than they are in real life, but I think you'll get the general idea. Before clean-up: After clean-up: The only identifying marking of any kind that I can find on the anvil is this small little "X" that was ground in on the side below the cutting table. It appears to be very intentionally done and perhaps was the maker's "signature" to identify his work. Quote Link to comment Share on other sites More sharing options...
jacobd Posted September 11, 2014 Share Posted September 11, 2014 That's impressive Quote Link to comment Share on other sites More sharing options...
Black Frog Posted September 11, 2014 Share Posted September 11, 2014 Cool stuff! what does it end up weighing? Quote Link to comment Share on other sites More sharing options...
SilverDeck Posted September 11, 2014 Author Share Posted September 11, 2014 I need to throw it on a bathroom scale and find out. I think it's about 20 lbs or so. They removed a lot of steel during the shaping process. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted September 11, 2014 Share Posted September 11, 2014 Might have been a trade school project. Quote Link to comment Share on other sites More sharing options...
Geoff Keyes Posted September 11, 2014 Share Posted September 11, 2014 It looks like the top of a bigger anvil, grafted on a piece of rail or H beam. Geoff Quote Link to comment Share on other sites More sharing options...
ausfire Posted September 11, 2014 Share Posted September 11, 2014 I agree with geoff. It looks just too good to be a rail anvil. A bit of cut and shut with a broken anvil and an I-beam perhaps.Anyway, a very smart piece of 'anvilry'. It would find a place in my shop. Quote Link to comment Share on other sites More sharing options...
SilverDeck Posted September 11, 2014 Author Share Posted September 11, 2014 No "grafts" or trickery here, honest! Just a VERY talented fabricator who put lots of time and skill into this rail anvil. I'll post some pics of the underside tomorrow so you can see all of the metal removal that took place to produce this piece. The face is only about 2" wide and the whole thing is about 16" long from horn to heel. Honest to goodness it is all carved out of a single piece of rail using the "stock removal" method. Quote Link to comment Share on other sites More sharing options...
windancer Posted September 12, 2014 Share Posted September 12, 2014 $10?????Want to double your money? I'll even throw in a bottle of Jack Black....GREAT find!Dave Quote Link to comment Share on other sites More sharing options...
mike-hr Posted September 12, 2014 Share Posted September 12, 2014 Really nice. It's not art, but surpasses craft. I'll bet, whomever made it, could fix a potato digging machine, whatever was broke, better than it was manufactured, and in time to keep harvesting tomorrow morning. I hope to be close to that person someday. Hey, we can all hope for something, right? Quote Link to comment Share on other sites More sharing options...
ausfire Posted September 12, 2014 Share Posted September 12, 2014 No "grafts" or trickery here, honest! Just a VERY talented fabricator who ...OK. I can only say that whoever made this could have made his fortune producing more. A very professional piece. One wonders, with such skill, what marvellous things he made on it. Quote Link to comment Share on other sites More sharing options...
Randy Bill Posted September 12, 2014 Share Posted September 12, 2014 Do you think your piece had any heat treating and what does the rebound seem like? Quote Link to comment Share on other sites More sharing options...
SilverDeck Posted September 12, 2014 Author Share Posted September 12, 2014 Here are a couple of shots of the underside of the face, horn, and heel. You can see some of the grind and file marks that were left behind as metal was removed and shaped. I'm guessing that the rail anvil did not receive any special heat treating based on the way that metal has moved around on the edges of the face from blows. I have not yet done a ball bearing test on it, but would expect the results to be marginal. The face has a lot of chisel marks in it and somebody must have used it for a chopping block. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 12, 2014 Share Posted September 12, 2014 There is an entire chapter in The Complete Modern Blacksmiths on how to make anvils from RR rail including heat treat of them.What I would point out is that the web should have extended under the cutting plate in my opinion. I like the real thin heel as there are a number of tasks I need that sort of heel for and have to use a bridge instead. Quote Link to comment Share on other sites More sharing options...
Ironmike Posted September 12, 2014 Share Posted September 12, 2014 Can you give us some dimensions, that will tell me what size rail they used. I have collected several over the years, But that one is very nice (super find) I will have to post some of mine if I can figure how to post pics? Ironmike Quote Link to comment Share on other sites More sharing options...
SilverDeck Posted September 12, 2014 Author Share Posted September 12, 2014 Ironmike: Attached are some dimensioned photos. I'm guessing that it may be made out of a section of 136 lb (136 lbs per yard of length) rail but perhaps you can confirm this speculation. 2014 07 30 Rail anvil dimensions.pdf Quote Link to comment Share on other sites More sharing options...
Randy Bill Posted September 12, 2014 Share Posted September 12, 2014 And thank you for preserving that beautiful patina for future generations to enjoy. Quote Link to comment Share on other sites More sharing options...
Direwolf Posted September 12, 2014 Share Posted September 12, 2014 Hi Copilot, nice anvil,good find! Here are a few pics of a couple that I found over the years. Someone spent quite a bit of time to machine and grind them to shape. I have seen others also, I sometimes wonder if someone commercially produced these? One of my neighbor farmers that I work for has one that he too found at a garage sale. They are good steel and great for small work or pleasant to just look at! Quote Link to comment Share on other sites More sharing options...
SilverDeck Posted September 12, 2014 Author Share Posted September 12, 2014 Hi Copilot, nice anvil,good find! Here are a few pics of a couple that I found over the years. Someone spent quite a bit of time to machine and grind them to shape. I have seen others also, I sometimes wonder if someone commercially produced these? One of my neighbor farmers that I work for has one that he too found at a garage sale. They are good steel and great for small work or pleasant to just look at! Those are some beauties, too. Love the one with the hardie and pritchel holes. Quote Link to comment Share on other sites More sharing options...
Judson Yaggy Posted September 13, 2014 Share Posted September 13, 2014 Looks like a high school shop class project from back when they had real shop classes. Quote Link to comment Share on other sites More sharing options...
Randy Bill Posted September 13, 2014 Share Posted September 13, 2014 The three look very much by the same hand. Quote Link to comment Share on other sites More sharing options...
Ironmike Posted September 13, 2014 Share Posted September 13, 2014 Boy it's uncanny the similiarity between Copilots And Direwolfs, They do look that way Randy Bill Ironmike Quote Link to comment Share on other sites More sharing options...
njanvilman Posted September 13, 2014 Share Posted September 13, 2014 Scan from 1900 Montgomery & Co., NY, NY catalog page of anvils they handled. These rail anvils were called "Hill's Solid Steel Anvils, and depending on the size were either $1, $2, or $3. Also note that Fisher anvils were selling for about $0.10/ lb. Quote Link to comment Share on other sites More sharing options...
njanvilman Posted September 13, 2014 Share Posted September 13, 2014 I believe that this company from the above post Montgomery & Co. became Montgomery Ward at some point. They carried everything from anvils to gears to machines. Interesting to just go through the catalog and see how much they carried, and the variety. Quote Link to comment Share on other sites More sharing options...
Rainbows Posted September 13, 2014 Share Posted September 13, 2014 Is the step ornamental or has the maker welding a toolseel plate on top? Quote Link to comment Share on other sites More sharing options...
