Pattern welded felling axe
I wanted to share a recent project that I have been working on, I have been trying to make a wolf's tooth pattern axe and this was my first attempt which was a disaster on the side of the pattern but it still turned out to be a nice axe. This axe was wrapped and welded with a body of mild steel and an edge of 1095 and 15n20 with a central core of 1084 giving the edge about 32 layers. The head is 8 1/4 inches long and the edge is a little over 6 inches, with the weight of the whole axe sitting at about 4 pounds. The handle is hickory and measures 35 1/2 inches long. All comments are welcome thanks for looking.
Oh also I did take photos step by step on the forging of this axe head so if anyone is interested in seeing the process I can post that in a separate thread.
1385664_674309749260241_784392850_n_zps2
1377499_674309482593601_917420167_n_zps0
735625_674309365926946_729799980_o_zpsab
that is a very pretty axe.  did you forge weld in a layered piece to achieve the edge pattern?  i'm unclear on that.
notice the term "bit", that means inserted a chunk of PW
  • 3 weeks later...
I always love when an axe head that pretty is complemented by a handle of equal beauty. Nice job sir.
  • 2 months later...
I would really like to see the pics of how this axe was made! Great job, this would be the envy of anyone I go to the woods with.
A handsom axe, I particularly like the side view with the valleys of Damascus.
I agree on posting the in process pics. and clarity on how you achieved the edge pattern.
Very nice!
  • 1 month later...
I like the look of that very much!
Yes, please post pics of your process. :)
  • 2 weeks later...
  • 2 months later...
Gorgeous tip! I would very much like to see the step by step of how this beauty was made! ESPECIALLY that tip!
That "tip" is properly called a welded "bit" Benton. He just made a deeper one from a nicely contrasting pattern welded piece and ground it to expose the patter.
You may have heard of a "double bitted Axe"?  You probably know the Eye, how about the Poll?
Yessir! The back end of an ax. Like a hammer poll, etc. Although most ax polls can't be hammered with unless specified, correct? For they'll damage the eye or split the eye?
Thanks Frosty! I need to work on my ax nomenclature a bit. =/
Don't sweat it Benton, nobody is born knowing this stuff. It's all a life long learning curve, I learn something every day, from anyone I read, I'm a big old knowledge sponge.
I'm REALLY looking forward to learning what you can do with a little practice and help from the gang. I surfed around your blog a bit and see plenty of promise. Forge on little Brother.
Thanks for the kind words and for checking out my blog, Frosty! I try to soak up as much knowledge  as possible!
