100 gallon tank
Ross G.
Good Morning,
The simplest way to slow down/stop the Propane bottle from freezing is to buy a t-fitting and hook up another bottle. The freezing is a function of the quantity of gas you are drawing off the surface of the liquid propane. Two tanks = twice the surface area = half of the draw per tank. The bigger the jet size, the more draw. The bigger the forge size, the more fuel you need to make it hot.
If you use refractory on the inside of the forge, when the inside gets yellow, you can turn the gas pressure down a titch.
Neil
