harrismetalsmith Posted October 13, 2010 Share Posted October 13, 2010 For TIG welding, do you prefer a footpedal or fingertip control? I realize that a fingertip setup may be good for odd reach places, but for your day to day tig welding what do you like? I do artistic architectural work, I would especialy like to hear from smith's doing similar work. Thanks, Matt Quote Link to comment Share on other sites More sharing options...
Fosterob Posted October 13, 2010 Share Posted October 13, 2010 I was a tig welder for quite a few years specializing in alum and stainless. Always used foot pedal but for some pipe work in the field a hand control is the only thing you can use. There are a few different designs of them so if you do go that route try them all first before buying. I think though for almost all work done in a shop foot control is the only way to go. Rob Quote Link to comment Share on other sites More sharing options...
David E. Posted October 13, 2010 Share Posted October 13, 2010 The other man's grass is always greener,or you always want what you don't have. My TIG is an old one with a shunt transformer and no foot control. It does me fine.I always want more control coming to the end of a weld on ali,a bit hard with a simple on/off, but, I don't do enough to warrant buying a new one. Quote Link to comment Share on other sites More sharing options...
arftist Posted October 13, 2010 Share Posted October 13, 2010 Thats it exactly. In the shop, especialy bench work, the foot petal is the best. In the feild, you can't beat a finger switch. Ladders, stairs, awkward positions etc. Using a foot petal in the feild, I have had to use my knee, my butt, or the worst of all, have someone else run the petal. Given only one choice, I would use a finger switch. Quote Link to comment Share on other sites More sharing options...
Fosterob Posted October 14, 2010 Share Posted October 14, 2010 You will need to know your machine and how to use it. You can use the foot pedal as an on-off switch if you set the max power on the machine to your welding power. Then all you do in an odd position is stomp the pedal to the floor and if lucky you can back off at the end. That way the arc wont start untill you want it to. Not to be done regularly but you should know how. Also handy sometimes to use the foot pedal with stick rod but again not often. As arftist says fingertip for the field is best but you also should be able to weld without a pedal or fingrtip control. Set machine to welding amperage and weld, like dave e does. That is how to weld thinwall stainless tube with purge gas inside so the weld looks the same on the inside as outside, no filler rod either. You must know how to do all of the above. hope this helps. Rob Quote Link to comment Share on other sites More sharing options...
harrismetalsmith Posted October 14, 2010 Author Share Posted October 14, 2010 Thanks for the comments all. I have a weldcraft crafter series torch. I have been welding with no control, but it has been tough. To do it right seems like I am constantly resetting the amperage. I am planning on getting a foot pedal, but I was hesitating, because you can get a finger controled torch for about the samecost as a pedal. I will plan on getting a finger control to run off my Trailblazer 302. My tig machine is a Miller XMT 350 mpa. Mutiprocess unit. Has anyone tried the metal built tig pedals off ebay instead of the cluncky Miller ones? Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted October 14, 2010 Share Posted October 14, 2010 I have a Linde UCC-305 and run a foot pedal. The smallest foot pedal I have seen was a Lincoln, it was about the size of a large wallet. Could easily slip it under your arm if you were in a in a difficult area. Using a foot pedal with stick is nice, really helps being able to control the amperage on some items. Quote Link to comment Share on other sites More sharing options...
SGropp Posted October 14, 2010 Share Posted October 14, 2010 I too run a Miller XMT 350 power source with a CK watercooled torch with a built in thumb control. The torch is cooled with a Milller Coolmate. I used to use a Esab gas cooled torch with an aftermarket thumb control that attached to the torch handle with velcro straps, but it was awkward, because it was bigger and sometimes slid out of position. The watercooled torch is much lighter , with a more flexible lead that is covered with a soft leather sheath. I am not a welder per say , but a blacksmith doing artistic work. The thumb control lets me work all over a large complex piece from the best position. Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted October 16, 2010 Share Posted October 16, 2010 I started out doing Ti with a foot pedal(plasma arc). Then 18 yrs doing aluminum(piece work)with a start(micro) switch. Now using a Miller 330 AB/P with a Miller foot pedal and a start switch. Try thin wall alum tubing at 200+ amps without any amp control. Ken. Quote Link to comment Share on other sites More sharing options...
monstermetal Posted October 16, 2010 Share Posted October 16, 2010 I use both and have to say I prefer a foot control unless in the field.... Miller makes several different pedals but I dont know about the one you mentioned How do you like your XMT 350? I have a XMT 304 and a XMT 456 but dont use either one to tig with, I have a Maxstar 200 DX I use for field work and a 300 sq wave Lincoln in the shop Quote Link to comment Share on other sites More sharing options...
harrismetalsmith Posted October 16, 2010 Author Share Posted October 16, 2010 I use both and have to say I prefer a foot control unless in the field.... Miller makes several different pedals but I dont know about the one you mentioned How do you like your XMT 350? I have a XMT 304 and a XMT 456 but dont use either one to tig with, I have a Maxstar 200 DX I use for field work and a 300 sq wave Lincoln in the shop I think I will definitely add a foot pedal ASAP. I have limited tig experience, that seems to be the way to go for the best control. I love the XMT 350 mpa, it is the first machine that I've had that had pulse capability. It is a handful at first on the programing side. That's also the reason I went with it, I wanted to be able to program the starts, wire speed, amperage, etc. But the Miller rep came out and helped alot. I just added the dual mpa feeder, I'm running steel on one side, and a push pull Aluma Pro on the other. That is really nice. I have it mounted on a little boom arm abouv my main fab area. I had to add a secong mig machine, and I didn't have a tig, so the extra money to get a 400 amp inverter tig included seemed worth it. It doesn't do ac on the tig but oh well. The pulse mig is so sweet I don't need it. I don't do thin alum. So, I like it alot. Quote Link to comment Share on other sites More sharing options...
monstermetal Posted October 16, 2010 Share Posted October 16, 2010 Sounds like a sweet set up..... I think its wise to get a foot control first but someday if you come across one Id snag a finger control too if you can... it can be a real bugger to try and run the foot control with your knee on a ladder (something I have tried to do) you get the most natural and I think most fluid control with a pedal though, its defiantly what I would pick if I only could have one....... Quote Link to comment Share on other sites More sharing options...
HWHII Posted October 16, 2010 Share Posted October 16, 2010 I have both and each has it purpose. I have a Miller Syncrowave 250, 304 XMT and a 302 Trailblazer which I have used a hand remote on for field work. The remote is a Miller with the rheostat that runs at a right angle to the handle. I have also used remotes that run parallel to the handle, and a slide which I liked alot. My favorite though is a Miller Dynasty with a simple rocker on and off and a machine that you can program with a ramp up current a pulsing mode and then ramp down. I wish I could afford that machine but it was sure nice to use. I have seen a lot of people who struggle with the hand remote. It is a bit difficult to learn to use if you are not very cordinated or have not done alot of TIG welding. Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 16, 2010 Share Posted October 16, 2010 It just depends. If I'm on a stool at a bench I like a foot pedal but if I'm crawling around the inside of a tank the finger control is better and lastly if I don't have to adjust in action I don't. Get used to what you have, just like anything else. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
phatdaddy Posted October 28, 2010 Share Posted October 28, 2010 I like the foot control if I have a stool to sit on. I use a "dry rig" when tigging stainless and carbon steel. I usually set the machine a little colder when welding intricate pieces. Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted October 28, 2010 Share Posted October 28, 2010 Son thats what the control is about. Foot or finger depending on your rig shouldn't have to turn it down just less pedal or finger. I use 040 on low range. 062 on second range.3/32 on 3rd and 1/8+ on high. the dry rig is a backup I need the wet one over 200 amps. Savesa little on the gas also. Ken. Quote Link to comment Share on other sites More sharing options...
phatdaddy Posted October 28, 2010 Share Posted October 28, 2010 When your poor, you go with what you got. Quote Link to comment Share on other sites More sharing options...
Bryce Masuk Posted November 6, 2010 Share Posted November 6, 2010 profax makes a good pedal for a decent price the genuine miller ones are pretty overpriced hand control works best for me but I am used to scratch start Quote Link to comment Share on other sites More sharing options...
JeremyP Posted November 7, 2010 Share Posted November 7, 2010 When I started out with tig I used a foot pedal for everything but most of my work is aluminum stair repairs and railing so I got the finger control for my feild work. Now I use the finger for everything. For me I rarely get any work where I get to just sit there and weld, It's usually a larger piece that I gotta walk around. I find the finger control much more versatile and easier when switching positions around the piece and I dont have to drag the foot pedal with me. Quote Link to comment Share on other sites More sharing options...
Hillbillysmith Posted November 21, 2010 Share Posted November 21, 2010 I've used both and in my opintion as a professional Welder, I would smash a finger control with a hammer. They are a PITA to use especially for just every day to day use. I know there are certain applications where a finger control is needed but I despise them personally. Quote Link to comment Share on other sites More sharing options...
Paulie welder Posted September 16, 2021 Share Posted September 16, 2021 I'm on the edge want to try a wireless foot pedal. Been welding 42 yrs. Specializing and stainless pipe boilermaker cyanide bromine chlorine all the really nice stuff we didn't even have a finger control for heat it was air-cooled torch got turned the knob to turn on the gas and scratch start you would have to set your machine at whatever heat range you're going to want and you're on your own and the foot pedal is wonderful but I've got a spot where the cable has to be just in the right place for it to react so I really do want to try a wireless and see how it goes Miller trailblazer 302 Quote Link to comment Share on other sites More sharing options...
bubba682 Posted September 19, 2021 Share Posted September 19, 2021 I usually only use a remote for xray work and thats a a dial remote, finger and pedals get on my nerves there just pains in the butt especially in tight places. Quote Link to comment Share on other sites More sharing options...
bluerooster Posted November 6, 2021 Share Posted November 6, 2021 I used a welder with a pedal once. Didn't much care for it. I guess I could get used to it if I used it more. But I grew up using an old transformer rig with no remote option for amperage. It did have a on/off foot switch for HF though. Quote Link to comment Share on other sites More sharing options...
