Pass through cork screw
I did water quench it just for good measure. Aus It is a pity. I think it will be sturdy enough not hardened. I wouldn't go much thinner than an 1/8 inch round on the screw. I will let you know if we run into any problems as we use it. Rockstar, That's a good idea on the twists. its not the most comfortable right now so I might do that with this one.
- Card holder
- Pass through cork screw
Welcome Nevada Blacksmiths
I’m glad to finally see this. I recently have been doing demonstrations and helping teach beginner classes at the Historical Tonopah Mining park.
Show me your Bottle Openers!
- An axe and herb chopper
- Hand steel Hawk
Spring fuller
Thanks Thomas. This has quickly became my favorite tool. The same effect can be done with a striker and top and bottom fullers but this is much easier for a single man operation as my self. I have used it to draw out quills on feathers and even collapse pipe down for peppers and candle holders with lighter taps. Thomas, can you please show me your swing arm fuller or send me the link if you already put it out. It sounds interesting.
Feathers
Yup. Fullered the quill out and used a cross pien for the texture. I have a railroad spike tomahawk I made along time ago that I use to chop in the edge splits.
Feathers
Just finished the order for all 22. The client was very happy. I learned a lot through the process. By the end I was working 3 at once and got my time down to a half hour apiece. I didn’t make any money on it but it is for a good cause and good exposure. Forgot to pictures. The last one is my first one and last one. Big difference
Show me your blacksmith pets
This is little Bea. She’s 1 year yellow lab. She’s like my daughters. Comes in to watch me work and falls asleep. I must be a pretty rhythmic hammerer.
- New display
- First rounding hammer
Safety share
Frosty. First picture was first day second was second. It’s healing up well. It’s peeling like a tattoo. Did a little burn gel first day then neosporin. As to the way it happened I was making a spring fuller. I had the piece that goes in the hardie forged in and needed the large hoop on the back. Both ends were cold and the middle was hot. I was bending the hoop around the horn of my anvil. For some reason I squatted down in front while holding onto the cold ends and started bending. It cooled quickly and I thought I could get that last little bit done before reheat. (Always the wrong thing). I forced the bend and it popped off the taper of the anvil and I saw it coming, through my head back and it got me. The pictures look different because I had to shave that night to get the smell of burned hair off my face. It sucked shaving.
Safety share
Don’t do what I did! I was bending some spring steel for a fuller around the horn of my anvil and it shot off and hit me. I was squatting in front making sure my bend was even and where I wanted it. I should have been off to the side or using my vise so it was secure. Stupid! Please make sure you stay out of the line of fire and always keep stuff secure. Hot metal hurts
