BlasterJoe Posted March 17, 2018 Share Posted March 17, 2018 Don’t do what I did! I was bending some spring steel for a fuller around the horn of my anvil and it shot off and hit me. I was squatting in front making sure my bend was even and where I wanted it. I should have been off to the side or using my vise so it was secure. Stupid! Please make sure you stay out of the line of fire and always keep stuff secure. Hot metal hurts Quote Link to comment Share on other sites More sharing options...
JHCC Posted March 17, 2018 Share Posted March 17, 2018 Ouch! Thanks(?) for the object lesson! Quote Link to comment Share on other sites More sharing options...
Daswulf Posted March 18, 2018 Share Posted March 18, 2018 Yeah, Ouch! While there is always the risk of the freak occurance of injury, it's always best to minimize that with safe practices. Quote Link to comment Share on other sites More sharing options...
JustAnotherViking Posted March 18, 2018 Share Posted March 18, 2018 Ouch. Hope you were at least wearing eye protection. Doesn't help your neck, but could have been much worse. Quote Link to comment Share on other sites More sharing options...
DavidF Posted March 18, 2018 Share Posted March 18, 2018 Ouch! Get feeling better. I bet you moved like you were a teenager again when that hit your skin! Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 18, 2018 Share Posted March 18, 2018 AYE YI YI! You got both front and back of your neck! How'd you manage that one Joe? Have you seen the doctor? Aloe gel will help but a little silvadine will make a huge difference. While I cringe at the thought of that much burn on all that tender skin I can't help but be thankful it wasn't so much worse. Once you get to feeling better I'd appreciate a better description of what you were doing when it got away from you. Get well fast Joe. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Smoggy Posted March 18, 2018 Share Posted March 18, 2018 That's nasty, but it could so easily have been worse hope it heals speedily. Thanks for posting as warning to others. And yes Frosty I was originally duped into thinking the first pic was the back of Joe's neck too! I think from the description Joe was crouched down, which means he was effecively forging the metal at face height, had he been stool up, it would likely of glanced of his apron if he had not been sprite enough to side step it, Difficult to be quick on your feet when you're bent over contorted! Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted March 18, 2018 Share Posted March 18, 2018 Ouch. I had a similar experience recently. not fun. Raw egg white can really help with burns. Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 18, 2018 Share Posted March 18, 2018 Thanks Smoggy, a closer look and it's obvious which way his ear is facing. My bad I should've looked closer before replying. Can I blame it on empathy making me cringing mightily? That looks like it HURTS! I've never heard of using egg white to treat a burn Tubalcain. I'm assuming you treat 1st. degree only this way. Id be pretty concerned with egg white making an effective auger to grow bacteria in an open wound like broken blisters. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
BlasterJoe Posted March 18, 2018 Author Share Posted March 18, 2018 Frosty. First picture was first day second was second. It’s healing up well. It’s peeling like a tattoo. Did a little burn gel first day then neosporin. As to the way it happened I was making a spring fuller. I had the piece that goes in the hardie forged in and needed the large hoop on the back. Both ends were cold and the middle was hot. I was bending the hoop around the horn of my anvil. For some reason I squatted down in front while holding onto the cold ends and started bending. It cooled quickly and I thought I could get that last little bit done before reheat. (Always the wrong thing). I forced the bend and it popped off the taper of the anvil and I saw it coming, through my head back and it got me. The pictures look different because I had to shave that night to get the smell of burned hair off my face. It sucked shaving. Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 18, 2018 Share Posted March 18, 2018 Oh man, famous last words, "Just a LITTLE more." Those might even be more famous than "watch this." Glad it wasn't worse, I've been burned too many times for one boy. I be very VERY careful anymore. I stopped putting a larger spring bend on spring fullers than necessary to the size of the work. Same with using spring steel. I kept getting into trouble making a large bend so I stopped, I'm a less trouble is better kind of guy. I discovered just using 1/2" rd. stock worked well for spring tools, when they warp out of shape I just heat them and true them back up. We're back into the easier is better thing. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Kevin Olson Posted April 6, 2019 Share Posted April 6, 2019 Got lucky today. Was doing a quick 10 second angle grinder wire brush on this holding it my hand with no gloves and it slipped. Just a grazing blow. But when it bit me I thought "you bone head , why did you not put gloves on per your saftey protocol, or better yet, put it in your vise" I was expecting to see alot worse. Think saftey even on a 10 second job!! Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 6, 2019 Share Posted April 6, 2019 You got my vote for bone head move of the hour Kevin! Getting a glove caught by a wire wheel is maybe worse than losing meat, a right angle grinder can literally climb your clothing AND remove meat till it's too tangled to keep spinning. I'm really glad it isn't worse but SHEESH MAN! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
