19,404 -
Everything posted by JHCC
Well, I do know one person (my brother, actually; one of the least handy people I know) who did precisely that (well, to be fair, he had held a wrench before, but had never done anything more mechanically complicated than changing a tire). To his credit, he did his research, took his time, invested in (or borrowed) the right tools, listened the advice of competent mechanics (shade tree and otherwise), and did exactly what he was supposed to do without trying to make it up as he went along. It worked out pretty well. However, that was essentially following a set of instructions that didn't have nearly as many variables and judgment calls as repairing an anvil would. Getting back to the original question, though, I second what other folks have said above about the challenges of fixing this particular anvil. I'd like to throw out another option: if you got it for free, why not sell it, take the proceeds plus what you would have spent on welding and grinding, and invest in an anvil that doesn't have so many problems?
Recomendations from the experienced please.
JHCC replied to Binesman's topic in Anvils, Swage Blocks, and Mandrels
Sounds good. -
Theoretically, soaking the wood in a borax solution makes it more fire resistant, but it's time, trouble, and expense invested with no meaningful return. Anything hot that falls on it will not be there long enough to start a fire, and a few scorch marks here or there won't make a difference. That said (and this is a bit off-topic, but bear with me), it is very much worth your while to prevent hot things dropping or flying through the air. Scorch marks on you or your son are much more a problem than they are on an anvil stand. Investing in some basic quality tongs is probably one of the best things you can do right now: they will allow you to hold your workpieces securely, comfortably, and (most importantly) safely. -
I have an old pair of gasfitter's pliers that are perfect for holding my touchmark. Put a ring on the reins, and it's like it's one solid tool.
Comes so easily to me, really.
Well, you and I are the same age, so it'll be easy for us to bait each other.
Or as we say in my line of work, "Not asking is the same as a No."
My sophomore year in college, my roommate had a direct-dial connection to the computer at National Institute of Mental Health (where he'd worked the previous summer). That was cutting edge in those days!
Ryan, one little tip about quoting: if you click "Quote" at the bottom of a comment, it will quote the entire comment, as you see. However, if you're only replying to one little bit of the comment, you can highlight that bit and a little "Quote this" box will appear. If you click that, it will put a quote in the reply field of just that highlighted piece. Thus, for your last comment in reply to Daswulf's "do you have access to a welder?", you could highlight those words, click the box, and get this: This makes it a lot easier to see what you're replying to, and it also helps our members who are still using dial-up internet and can't wait around for big chunks of quote to load. (The same thing goes for photos, by the way: it's good to resize them so that they don't overwhelm a comment thread.) Thanks.
Okay, good. I missed that detail; thanks. Think seriously about replacing the blocks with either a wood or metal stand. Cinder blocks don't do well under repeated shocks, and you do NOT want your anvil to suddenly be dropping down on your toes!
If you can find a #2 hammer for a couple of bucks at a flea market, that's going to do just fine for now. Remember: accuracy first, power second! If you're watching Trenton Tye's YouTube channel, you've probably seen his recent videos about using chunks of junkyard steel as anvils. If not, definitely worth checking out; certainly better than cinder blocks (if only in terms of durability). One thing, though: here on IFI, when we say "ASO" or "Anvil-Shaped Object", we generally mean something that looks like an anvil, but doesn't work like one (for example, one of those cast iron monstrosities from Harbor Freight), but when Mr. Tye says "ASO", he means something that works like an anvil, but doesn't look like one. Here on IFI, we would usually call that an "improvised anvil" or a "block anvil".
Please help to identify the anvil.
JHCC replied to Nick Safonov's topic in Anvils, Swage Blocks, and Mandrels
In the third photo of your last post, I think I can make out " - - I T A G E", which would be the tail end of "ARMITAGE". That would be additional confirmation that this is a Mousehole anvil, and if you can puzzle out what initials come before "ARMITAGE", that can also help narrow the date range down further. -
As @Everything Mac notes in his Beginner's Guide to buying anvils, there were literally hundreds of anvil manufacturers in England, so while this has the general overall lines of a Mousehole, it was probably made by someone else who trained there. You'll probably never be able to figure out exactly who, unless you discover some other markings that you overlooked earlier. If it doesn't actually say Mousehole, it probably isn't a Mousehole. That said, the presence of the pritchell hole indicates that it was probably made after about 1835. -
We're certainly generating reams of speculations....
Hold down the Alt key and type "156" on your number pad, thus: £.
Might just be oiled, but if it is painted, check it over before you hand over your cash! A layer of paint could well be concealing hidden flaws, and frankly, it looks from the photos like there might be a crack in the face, running back from the saddle. If you haven't already, read @Everything Mac's Anvils: A beginner buyers guide; the section on testing is #3.
Little giant foundations, vibration question.
JHCC replied to Antoine M.'s topic in Power Hammers, Treadle Hammers, Olivers
The hammer floated? -
That strikes me as one of those things that's theoretically possible, but probably not very feasible. A forge is designed to generate very localized, very high heat, while an oven is designed to distribute a medium-high heat all around what you're cooking. Any sacrifices you make to one of those functions to accommodate the other is going to have a negative effect on what the original function is supposed to do. Better to make two separate constructions. There is one thing that springs to mind, however, and that is to design your pizza oven in such a way that there is storage space underneath for your forge.
Welcome to IFI, @Antoine M. Glad to have you. You might want to head over to the Introduce Yourself page and let us know who you are, but be sure to READ THIS FIRST! Regarding your question, I don't have any experience with this myself, but if you search the forum*, there are many good threads about power hammer foundations that should get you headed in the right direction. *Don't use the forum's own search feature, which isn't very good. If you do a web search (with Google or the like) and include "iforgeiron.com" as one of your search terms, you'll probably find what you're looking for. -
Sell it, and buy steel and fuel.
Actually, there IS something to tear apart: How on earth did you fit one FOOT of firebrick cement inside a four INCH by eight INCH coffee can?!??! (M), look at the JABOD threads in the solid fuels section of the forum. @Charles R. Stevens started it with his "Just a box of dirt" thread, and I followed up with my own picture-heavy construction thread. There are a few others worth looking at, too.
True, but their autocorrect isn't!
A friend of mine made some amazing typo/autocorrect errors a couple of weeks ago that were (inadvertently, one hopes) extremely raunchy and thus cannot be repeated here. Suffice it to say that they were made even more amusing by the fact that he's a priest!
There aren't that many jigs in classic rock (unless you're talking about Styx's "Renegade", in which case the jig is up).
