Once again, I didn’t get a chance to fire up the forge this evening. However, I did get into the shop and made something for the linkage on the treadle hammer. I’ve been playing around with this idea in my head for a while, so I’m pleased that it seems to work fairly well.
As noted before, unhooking the chain that connects the arm to the treadle lets the hammer swing up and out of the way, giving me the clearance needed for hand hammering. Pulling the head down and re-connecting the chain lets me switch back to treadle hammering. Being able to switch back and forth easily is one of the greatest things about this rig, so I wanted to make the process a little bit easier.
The solution is this adjustable linkage, shown here in the unlatched position:
And here it is closed:
So basically, all you have to do is pull down the head, pull down the lever to shorten the distance between the ends of the two chains, and hook the ends of the lever to keep the thing together. To lengthen the linkage, reverse. The lever is made from about three feet of garage door torsion spring, straightened, normalized, and bent cold. If this proof-of-concept works well, I’ll forge a nicer looking one from another section (although I think it was either Frosty or ThomasPowers who said there’s nothing so permanent as a temporary solution).
