That's a fantastic looking knife! What did you do for heat treating?
When I want a finish like that I do the exact same thing as you did but I finish it off with scotch brite. I found it gives a more even scratch pattern.
Nice looking anvil whatever it is I think the price was fair. If that were my anvil all I would do with that hardy hole is leave it alone. I would take a plate if steel maybe 3" square and cut the square hole in it. Just set that over the hardy before you put the tool in. I don't know how well that would work but it might be worth a try. That's just me tho.
Just seems like there are to many hammer marks on the base to be cast iron like a Trenton and the feet are a little different then mine. I could be wrong tho, just my best guess really.
I'm no expert but it doesn't quite look right to be a Trenton and it appears to be forged steel? Someone correct me if I'm wrong, still learning. Nice anvil no matter what it is. Safe to say its no ASO either.
Thanks Zengineer, I put a lot of time into this knife.
Private Entrance, I have some powdered pigment that I want to try out some time. From what I hear, powders are the best for epoxy unless your using epoxy dye of course.
Thanks for the compliments. I sold this one for $350
Loneforge, I have been tempted to try dyeing the epoxy. I was thinking about glueing my scales on and then using a tooth brush to get the epoxy out of the file work then filling it with the dyed epoxy. That way you know there won't be an adhesion issue. For the mosaics I have made I just used straight epoxy with no color. If you look real close you can tell its not black but from a couple feet away you can't tell.
I filed it into the spine then I used cold blueing to make it black. When I glued the handle slabs on I made sure that the file work got filled with epoxy. After the glue was dry I sanded the handle level with the spine to reveal the file work.
Bocote is a fairly stable wood. I would just give it a nice oil finish if stabilizing is out of the question for you. With any natural wood handles its always best to wash them by hand and not submerge them into water.
Nice looking knives man! I've always like the look of a file knife. Did that farriers rasp harden up well? My dad has one and I was thinking of making a knife with it.
Thanks you guys, it means a lot to me. I have 16 more ordered so I will be a busy man for a while. I can't wait for spring to get here so I can fire up the forge again! In the future I want to forge all of my knives so next summer I am going to forge a bunch of blades and finish thin during the winter.
Do you guys know if heat treating outside in the winter would be a major problem? I have a bunch of blades made from 1084 that I need to heat treat.
Gabriel, I completed my first knife on march 22nd 2012. I'm new to knife making but a lot of the skill my dad tought me from building guitars really helped me in knife making.
Thanks for the compliments everyone.
Oh for sure it can have carbon, you just never know how much. It just depends on what they used to make it. The chances of it being very high are slim tho.
I'm no expert in heat treating but wouldn't welding three bars of wrought iron to one bar of medium carbon leave you with a piece of steel with very low carbon because of the carbon migration?
