azmike
Everything posted by azmike
  1. Welcome and hello---you will find this place to be of great help, with great people. I have many great memories of greenfield village (from back in the 50's). azmike
  2. Rick, thanks for showing----those are all very nice...love the style.
  3. azmike replied to sfDuck's topic in Problem Solving
    So, where can i get one of those (i really need it and will never use it)?
  4. "Close your eyes and tell me what you see" Always wear your safety glasses.................
  5. Jimi---nice work---and welcome. azmike
  6. Tom, glad to see your stepping up and forging ahead---old coil springs should work fine, but if it were me i would uncoil them full length and work one end and use the other to hold on to (i have as yet to make a "good" pair of tongs)---there is something about them (and me) that just doesn't come together quite right as yet---take care --azmike
  7. Tom, welcome. you will find that the knifemaking community (here and other sites) is top shelf. hope to "see" you for the friday nite chat -- azmike
  8. I use coffee cans and poke a hole in the bottom end-slide it on a 6" pegboard hanger and hang them from a piece of pegboard-----works good for smaller stuff and is large enough to store lots of stuff.
  9. Glenn, I will do that when i get the key words and such set up (may give me somthing to do at work tonite). thanks, mike
  10. pete46--the bush blade is 1060.
  11. this link should take you to some pics that my friend Todd (Forginhill) took last weekend. hope you enjoy----azmike Picasa Web Albums - mike
  12. here are the only 2 pics i've got of my first forged bowie style. OAL is 11 7/8", blade is 6 5/8' made from an old harrow disc. the handle is bloodwood with ironwood and copper screen spacers--the S guard is wrought. the sheath is mesquite bark wood with leather spacer and bloodwood bead. this was made for a friend at work, and is really my first "commission"----he was very pleased and for that, so was I. thanks for looking........mike
  13. Noob--always knock the scale off the blade and the anvil before you hmmer--if not you can drive the scale in deep and spend to many hours filing to get it cleaned up. I still use an angle grinder (4 1/2") sometimes in the very rough state of the blade, and find that the 60/80 grit flap wheels work for me. from there its files and sandcloth and time. azmike
  14. Tom, good start. forging in the bevel would require a flat faced hammer to help reduce frustrations (hard to remove dents), and then a good file or grinder (i still do the file thing). I have been taking the edge down thinner as i get better at this and have had very few problems as yet, as long as i normalize several times during the process. taking a hardened edge down from 1/16" to sharp without powertools, is difficult and time consuming for me, so the closer it is the better i like it. i've already resolved myself to the fact i will experience warped and/or cracked blades but i'm willing to live with that. please take any and all i say with a grain of salt, as i am by no means as knowledgable or talanted as many (most) who post here. azmike
  15. Pascalou, thats very nice--i like it. azmike
  16. Saiga308, welcome--I used to live there in Springfield (8+yrs), and the daughter and grandkids still do--beautiful country. take care and good luck with your new adventure. azmike
  17. Jonny, welcome from another arizona desert rat--saw the post of your knife and if your just starting making blades--you must have some blacksmith in your blood. again-welcome azmike just re-rread and my mistake on your post of a knife----it was just a reply (the years do make it hard sometimes----hahaha) azmike
  18. these are a couple i did this summer/fall--the first is forged 1084 with ironwood slabs and brass pins. the second one was forged by Forgin Hill and finished by me--L6 blade and ironwood handle. the third (weird) one was made for the sister-in-law for harvesting herbs, 1084 with a 2" cutting edge-approx 6" OAL. azmike
  19. You all may know and use some fashion of this--but if not, its just a tip from a newbie that it works for. I don't have a belt sander and found this is one way to work on the finish. I have a block of the dense, black, closed cell foam insulation (armaflex), about 2" wide x3" high x 4" long-cut it dead center on the 2" about half way thru and full length. just take your sand cloth/paper (sized to fit the full length/depth of your cut-when folded in half) slip it in with the abrasive sides facing and slide in the blade. hold the block and slide the blade / hold the blade and slide the block - edge up or down, changing grits as you go --- just like your using a saw. give it a try--azmike
  20. Jens, i really like that one. i have gotten a few that stuck and held (3 out of many tries), but i have not gotten that color.....what coins did you use and did you use any special etching solution? i have a blade in the works (need much more skill/practice/experience before i go too far with it (a large dagger/arkansas toothpick)--But--i have a real nice piece of osage orange for the handle-and with some black horn mixed in that color would be killer. thanks--azmike
  21. azmike replied to stryder's topic in Knife Making
    Ralph--i don't try to weld every time, maybe i should -- but, like i said, i have so much else to learn that its not a big deal for now. JPH- the saw blade was a Starrett and i did in fact get a blade made from the result---for right handed work, as the saw blade steel is on the left side--and for fear of having a de-lamination, it looks more like a wide straight razor----but it works in the kitchen. thanks, mike
  22. azmike replied to stryder's topic in Knife Making
    I'm near the end of my first year learning to forge, and to date, i've gotten one "weld" (med. carbon/recip. hacksaw blade) to take. i just figure that if it doesn't work today---maybe next time...there is so much more to learn and i can always improve at the anvil. thanks, i guess i need to "search" the forums here and see what else i don't know. mike
