steveh
Everything posted by steveh
  1. steveh replied to gerald's topic in Everything Else
    you cant go from dock to hawk! so the new word is sock...footwear
  2. steveh replied to gerald's topic in Everything Else
    rook...a bird or chess piece
  3. steveh replied to gerald's topic in Everything Else
    seer...a wise man gifted with powers of divination
  4. i would think it depends on the size of the opening,but it will always be there.
  5. i started with a london pattern peter wright,then i got my double horn vaughan.i dont believe you would regret going the two horn route,i have found mine to be a great tool and wouldnt buy anything else.
  6. try holding it between your legs...
  7. cast steel are one piece anvils not to be mistaken with cast iron ones which should have a steel faceplate attached to be of much use.
  8. you only have one chance to make a first impression!
  9. thankyou Mr Hofi for the reply and the math lesson,have a good day,Steve.
  10. Mr Hofi,what is the length of 1in sq. you start out with?thanks Steve.
  11. here in British Columbia there is a huge demand for nurses.
  12. mess with the bull,you get the horn!!
  13. i just bet you are excited.i am trying to be patient waiting for mine to come.
  14. they are made to be used left or right handed.bend about 1.5 in.down 90 degrees then you make the hook on the left or right side,i use my scrolling tongs.i hope it is clear to you.
  15. they are called 3 way bench last,because they sit 3 different ways.
  16. pot of gold...
  17. i just picked up a 1985 3/4 ton Ford with a 1 ton rear end and flatdeck.she needs a little TLC,but there is good rubber all around.now i dont have to cut my steel in short lengths to put in my trunk.
  18. steveh replied to Sabre's topic in Solid Fuel Forges
    you are more than welcome Sabre,you have got yourself set up pretty good,glad to help.Steve.
  19. Mr Hofi,am I safe to assume that your hammer weights are in kilos?
  20. side draft chimney
  21. i just use my given name,Steve Hansl Blacksmithing,mostly because i was sure nobody else was using it for when i registered the name as a business.
  22. line and sinker...
  23. it is one of the nicest ones i have seen!
  24. fuller a piece of pipe down,then cut it off.i cant put into words how to attach the handle to the snuffer bell but my friend made them to swing back and forth with a little pinned hinge.
  25. hey Chris,are you going to do the test with your Nazel and Little Giant?
