Steve Sells
Administrators
    9,162
Everything posted by Steve Sells
  1. very nice, you are giving me ideas about my 4 burner....
  2. as many know, this isn't the first time I screwed up a name and most likely wont be the last The point is one can go ahead and try, but it was stated he did not want to risk losing his motor, anytime we do things to a motor that it was not designed for, we take the risk of failure. Many times a cheap dinmmer lasts many years on a motor, my local IBA has a dimmer on a old Vac motor. it is still working fine. But most will fail.
  3. its like telling a kid to look for traffic before crossing the street, they tell ya they never look, and never been hit by a car, they are fine... its kinda the same thing, just less painful if they are wrong. :cool:
  4. cool give it a try and report back sounds like fun !
  5. I am not sure there is a steel with 12% Mn. but a sanmai as you propose can and is made with mild outer portions.
  6. I don't see much of anything at that link, except a request for adding to it. Also Wiki is not a primary reference for anything. When anyone 2 through 120 yrs old can post with out any credentials, or verification of fact. Its a nice place to get fast info, but without backup of real knowledge and verifiable facts, its just a chalkboard most anyone can write on. so to your second link: Even tho I would take the side of a metallurgist over a dictionary, at least Websters is a credible source :)
  7. I have a fairly simple explanation of the process, and well as colors at my website at How to make Damascus Blades
  8. not a good idea, VFD's are made to have speed played with, many TEFC are not. you will most likely fry your motor. but what do I know:D
  9. Dish sponge. the lime green looks great. Every one has seen the flat hard "bricks" that are dried sponge. add the resin and press between 2x4's and it comes out great.
  10. plywood or 2x12 under the current stand ?
  11. well Woody, she never got removed from my list, from the last time, but thanks for the update.
  12. Welcome to I Forge Iron, Since you had missed the chat room, May I point out that there is also a dedicated knife chat on Friday night, 10pm to 11pm Eastern time. Also tutorials on many subjects are partly available in the Blue Print section, I say part because some are not accessible due to a quirk that arose in the software when updates were made a while ago. It is being worked on. Also Tuesday nights also starting at 10PM eastern there are 2 or 3 new blue prints presented every week. IFI is a happening place. Glad to have another bladesmith on board.
  13. The poor girl is in her early 60's. Yesterday afternoon, she seems to have had a mini stroke, except the Hospital doctors cant find a thing wrong with her, Other than she has little if any memory left. It is like a light switch was flipped. She has had seizures for many years now, goes catatonic for a while then slowly regains control. but this time was a small hit to the head from one of the kids playing, afterward, she didn't recognize anyone. I was over to their house today, and tho she knows her daughter and son in law now, she walked into me, and got very scared. But I can understand seeing me surprised her, even tho I have known her for years. at present she is very helpless.
  14. Funny you said that Highlander, because My first college degree was in Programming. I worked as a construction laborer, but by the time I finished the assoc degree, I found I preferred working with the electricians. Which is still my mainstay of work. I only use computers as tools now, and don't program much if at all.
  15. simply I hammered/rolled wrought Iron into flats a little thinner than 1/8 inch thick, stacked them up. I added 0.30 thick15n20, pure.03 Nickel, and a little high carbon 1095 Shim stock .025 in between these layers. So it started W,C,W,Ni,W,C,W,C,W,15,W or close to that for the layering. these shims are very thin, so basically its mainly just wrought iron, but the other metals give some dark bands, or lighter bands. The client wanted the hardware for this blade to look like branches of trees. rather than the cut wood effect. MY first thought was simple wrought iron, but I decided to add some shim stock to add depth of color. To add in this illusion, I plan to carve the bar when its still 2x over size, with my dremel tool cutter, then finish hammering to shape, Like when doing a ladder pattern but running the length rather than across, and not parallel, but intersecting like with natural tree bark. Revealing colors as well as textures with the acid bath. Will post when I finish, there is noting to really see until then with this pattern welded stuff. maybe its over kill, but I push to come up with my various pattern welded patterns. and not every thing is a blade edge. there are many other uses for damascus.
  16. just an observation, as I am not your teacher, but if I were... I would give you some real steels like some1084FG or O-1 maybe, and tell you stop practicing, and start producing blades for sale. but your not my student, so I wont say a thing. :rolleyes:
  17. the thing is, I can't just do a billet start-to-finish all at once. I need to let a billet cool before I can cut and grind faces clean, and fold/weld again, so while I let one billet anneal, I do work on another one, so its not all wasted time, and I do large pieces first, so IF this happens, I can use this "sword guard scrap" as a pommel (as in this case) and make more for the guard later. but being out of plain simple 1095 series I am waiting on more so I can do more billets of the 1095/L6 for a very impatient client waiting on a very large billet, but its nice to have projects to bounce to and from, as when I get a JAM on something, I can move to the other while I think of how to fix a cold shunt or what ever.
  18. But he aint, as usual he came in LAST
  19. Welcome, there are a few blade makers here. On Friday night's we host a Knife Chat from 10 to 11pm Eastern time, here at IFI, its part teaching, part sharing format., and as always 24/7 the general chat room is open, and most the time active. as IFI has a world wide membership.
  20. I think this make 3 blades finished now ? nice Chef knife, but most sushi blades I have seen are flat bottom, not arched.
  21. knee mail is on its way, Hard to hear about heart attacks at 41, we like to think it can't happen to us. He was lucky to get to hospital rather than having to wait for your return also. God was watching him.
  22. there is at least one person assigned that title still forging here in the States, from his service in the US Army, he is on the Yahoo Blacksmiths list.
  23. wow, There is nothing else I can say, but this system insists I use more than 3 letters in a reply. :D
  24. A+ for that one. I really like it, I am sure any deploying Soldier will as well.
