All Activity
- Today
why did my angle grinder stop working
Nobody Special replied to GhostTownForge's topic in Grinders, Sanders, etc
Took mine apart enough to pull the brushes this morning. No bueno. One was reasonably okay, maybe worn down between a third and a half. The other was around a quarter inch shorter, the wear was slanted, and there was a chip missing out of the shorter side. Gotta take it apart some more to get a look at the commutator. That thing is buried in there more than I thought. Turns out nobody local carries bloody carbon brushes either, so I'm ordering a variety pack and making Jeff Bezos a little richer. -
TommyVee replied to Mark Ling's topic in Blacksmithing, General Discussion
Spent today making a stand for the new 100lb double-horn Holland anvil that arrived yesterday. Got it most of the way, still have to make the brackets to hold the anvil itself and clean up the welds with an angle grinder. - Yesterday
Protect the bottom of your foundry
Frosty replied to Florida Man Metals's topic in Smelting, Melting, Foundry, and Casting
I believe the foundry is the facility rather than a single piece of equipment though I'll be happy to learn differently. English is such a slippery thing you just never know for sure. One of our club members is a professional bronze caster and pours over a sand box or outdoors on dry dirt. He conducts the yearly iron pour at Art on Fire event and that's all on the ground. Until a couple years ago I demoed blacksmithing about 50' from the cupola and iron pour. Frosty The Lucky. -
Perhaps, you two should cut back on the chilly consumption. Now all three of us have passed gas
The Athens Forge, a member of the Alabama Forge council, will meet Saturday April 27, at 9AM. This will be an "Open Forge" day. Any member of the AFC, can come and work on a private project. Bring your tools and material, forges, anvils, and vices are available. You might want to try a pair of the Grilling Tongs Steve Alford demoed last month. Non members are invited to come and watch, and ask questions. There is a lot of smithing knowledge within the group. Visitors are always welcome. More information its available at www.alaforge.org You might want to mark the next meeting May 25, Travis Fleming will be demonstrating how to make a pair of tongs to hold a railroad spike for safe and secure forging.
Welcome aboard from 7500' in SE Wyoming. Glad to have you. I agree with Frosty about adding your general location. This is a world wide forum and we don't know if you are in Kansas, Lapland, or Tierra del Fuego. I can't say what the artifact/machine is but I can try to deduce its function a bit. The round part is clearly designed to hold some sort of liquid. As Frosty points our there is a filling port with a threaded, square head. It is designed to rotate on the axle between the upright, locked position and the lower position shown in the first photo. What is puzzling to me is that whatever liquid is in it would not fully pour out in the lowered position, only down to the level of the bottom of the rectangular hole. Maybe in use it was mounted in a different position than the upright one it is in now. The heavy collar to hold it in a closed position indicates to me that it was designed to remain in that position securely. Other than that I can't imagine more. I hope that you find someone who recognizes it. If you find out please post the result here. I would like my curiosity itch scratched. GNM
Trenton or Hay Budden?
Goods replied to Ridgeway Forge Studio's topic in Anvils, Swage Blocks, and Mandrels
Hourglass shape would indicate Hay Budden… I’ve not heard of Peter Wright’s having a depression on the underside. -
Ridgeway Forge Studio replied to Ridgeway Forge Studio's topic in Anvils, Swage Blocks, and Mandrels
The indentation on the bottom is hourglass shaped - The squat, round horn and the long thin heel make me think it might be a later model hay budden, but I am unsure. I don't think it is a Peter Wright - not the right handling holes or the right feet. -
When you say foundry it sounds like you're talking about the melter rather than the shop. No? Frosty The Lucky. -
I’d say Trenton based one the caplet indentation (if I’m seeing it correctly) in the bottom and what looks like the remains of a Trenton diamond stamp on the side. Keep it fun, David -
Welcome aboard Den, glad to have you. If you'll put your general location in the header you'll have a much better chance of meeting up with members within visiting distance. Branding plate? Do you mean like a label or data badge? I think that is highly unlikely, the body is looks to be intended to hold a liquid, That appears to be a level or fill plug and if it were to stamp labels, etc. it wouldn't need the big reservoir or body in general. It would probably have a vertical press and compound lever if it were for stamping labels, tags, badges, etc. IVI isn't a Roman Numeral. You might try one of the vintage tools or machinery sites. I'll be interested in what you find out. Frosty The Lucky.
Chad J. replied to Mark Ling's topic in Blacksmithing, General Discussion
Thanks Frosty, I once had another smith over and she commented that she could get months of projects out of my rejects on the floor. For the hook, I didn't, I just went down. Most of the hooks I made in the past didn't fit well, a little too big on the hook, so they didn't turn much. What I think I may play with now is putting a tight s bend in the hook to keep it from twisting. Maybe I'll do one tonight and see how it looks and do the offset upward hook. Might as well pay with the designs, Father's Day is coming up and what Dad didn't like hanging tools nice and neat on pegboard. -
Steel from old garage door springs
yt12 replied to Ronin66's topic in Blacksmithing, General Discussion
had i only known------ive bored this board with my auction finds, but, anyhoo-----you may want to check your local on-line auctions-----they range the gambit -----i have had good luck with one that usually handles personal/household items, but often has odd-ball industrial items. most auctions have an opening bid of $1 ----whether a 2 dollar screwdriver or a $ 20,000 forklift-----some items generating huge interest-----some zero. have ended up with half a dozen car spring sets ....all brand new all for a buck----did pay up $3 for a set of 4 springs with all the air shock hook-up------would have sent ya these door springs, but they moved on down the line...... -
Frosty replied to Ridgeway Forge Studio's topic in Anvils, Swage Blocks, and Mandrels
Trentons tend to have longer horns but it's not too short to be one. Try a web search for images, I'd link what I just skimmed through but it's several pages and too much bandwidth when anybody can search it. It could be a Peter Wright too, there are a couple anvils listed in the images that clearly have the name stamped in their sides. A couple on Iforge for that matter. Frosty The Lucky. -
Frosty replied to Mark Ling's topic in Blacksmithing, General Discussion
Good job Chad, a clear floor and bench gives you so much MORE room to lay stuff down! While drying off after this morning's shower I saw the snow blocking the man door on my closed up for winter shop looks clear enough to shovel my way in. Cleaning it though . . . <sigh> Nice peg board hooks, did you put an upwards curve on the peg so it's locked in when there's weight on the hook? It doesn't take much but it really stabilizes the hook. Not taking much time to turn out things like simple hooks really improves them. When I'm just warming up right after I open the shop in spring I make leaf coat hooks, in part because I use them as a forge product #1 for beginners. When I get my self back up to speed I spend about 7 minutes from cutting the stock to brushing and waxing the finished hook. I start with 3/8" sq. hot rolled, twist the shank, draw the hook, leaf, vein the leaf, counter punch the screw holes, brush hard and apply my Trewax finish at a temp that makes it smoke so it comes out black. Later I may use a leaf die so the veins stand proud but I'm not so crazy about the dies I've come up with. Surprisingly it's more work than drawing and veining by hand. Anyway, in spring it takes me 15+ minutes to make a leaf hook and they're okay. Later when I'm cranking them in 7mins. or so they start coming out looking and working well. I think I have a peg board in the shop maybe I'll have to clean a path and make some hooks. Do your hooks want to turn sideways in use? Commercial peg board hooks have multiple pegs and or a spread bar to keep them facing straight. Turning has always been my issue with making peg board hooks. It's not insurmountable but it is unsatisfying having to add chachkas to keep them straight. An old acquaintance made little snake pegs that looked like they were slithering down the wall, neck and head raising into hooks. As I recall he said he spent 10+ minutes on them. Frosty The Lucky. -
Uh HUH and the English book replied, "Go figure." That doesn't add up to a good joke either does it. Sorry. Frosty The Lucky.
JHCC replied to Mark Ling's topic in Blacksmithing, General Discussion
Yesterday I found; the floor to my shop, a counter top, a pan that I had used to hold water next to the belt grinder, the stand that the pan stood on, my tablesaw, a place to put my snow blower, several half finished knives, my first attempt at a towel hanger, and space to set the coffin bookshelf back up so I can finish it now that it's warm again. I also rearranged my tool peg board so I can actually hang tools on it and made a quick hook for it. It used to take me hours, maybe exaggerated, to make a single hook for the peg board, yesterday the one I knocked out quick as a reward to myself for cleaning took maybe 5 minutes and looked much better. Still just as proud of the early ones. -
Ridgeway Forge Studio started following Trenton or Hay Budden?
Rusty, crusty and pitted- I’ve had this anvil since I bought it from the antique mall 8 months ago, finally mounting it. it is 180 lbs (approx) and seems to be in good shape other than the rust and pitting. is it a Hay Budden or a Trenton? Any marking has long since disappeared…
Ridgeway Forge Studio replied to Mark Ling's topic in Blacksmithing, General Discussion
Finally finished the new stand for my 12 ton hydraulic press. I mounted the power pack and tank below the H frame to save space and keep things cleaner. One step towards cleaning up my shop! -
DenM started following Is this an iron plate making tool?
This looks like it may be some kind of branding plate maker, or maybe not. If anyone knows what this item was used for, I’d love to find out.
DenM joined the community
lary replied to GhostTownForge's topic in Grinders, Sanders, etc
I've had a couple of the cheaper angle grinders start cutting out at the switch. There the type that have a plastic switch that slide to a locking position. Sometimes on sale at Harbor Freight for $9.95. I've had the best experience with the 15 amp paddle switch 4 1/2 inch grinders from Dewalt. I'm not talking about the name brand angle grinders when it comes to the slide type switch.
