Hobart Meltdown
  I am asking this for a friend and my own curiosity, it is not mine.  This is a Hobart Beta-Mig 251 that he said started smoking, and he took the cover off to find this.  I know I should ask on a welding forum but this is my only social media, I tried Welding Web once and never went back.  Any idea?  Could build up of dirt cause this?  Are those cooling fins?  He says it still works.  I told him to quit since it was smoking.c1_20240518_09232043.thumb.jpeg.7372abd9fcf9dc7dafeabdfc84f73726.jpeg
Tell him to give the whole thing a good cleaning and then run it and see what smokes, if it does still smoke. (at his own risk!) It almost looks to me like some of the insulation on those wires is pretty crispy, but it might just be soot? Hard to tell from the photo. Definitely be ready to shut it off quick when testing it out!
  In your opinion, could it be fixed/replaced or is the whole unit shot?  I was wondering if they were cooling fins, not him.  The only reason I asked is he said it still worked.  It is in Nebraska and I am in NC.  What would you speculate caused it?  This is just curiosity on my part.
Hi Scott, It looks like a build up of dirt around the transformer. I have been welding since I was a kid and own 3 miller and three lincoln welders. At least once a year I remove the tin and blow out the accumulated dirt even more frequently if the shop has a lot of dust and dirt from grinding. Also  the welder needs to be located where it can get good airflow so it cools properly. THe most important factor is the rated duty-cycle, for example it may say 60% at 200 amps. That means that in 10 minutes you can weld for 6 minutes and let it idle and cool for 4 minutes. As to wether it is usable I would definatly clean and inspect it carefully as it looks like sme damage has been done perhaps have an electrician check it. Since I can't get my hands on it I would urge the owner to proceed with caution particularily if he is not knowledgeable with electricity.
  Thanks, Direwolf, I will pass that along.  He's a former co-worker and has access to electricians from work.  It was my curiosity that caused me to ask.  I don't know how that much dirt could build up.
  I just thought of it but I've had a AC tombstone for 20+ years and never blew it out.
  I will do it tomorrow.
Hi Scott, I've taken a few apart that I thought would be filthy inside to find them clean as a whistle and some that were a mess. I guess it all depends on the shop  conditions and type of work. Also as you know the welders have fans that continually blow air through the machine to cool the transformers and bridge rectifier circuit if it is a dc machine, so over time a lot of air is moved through it. As I'm on the subject sometimes the fans quit working so while he is checking I would make sure the cooling fan is working too.  Those tombstones are tough, dependable welders. About 5 or 6 years ago I was at an estate sale across town mostly tools and logging gear so I bought some tools  there was an old tombston ac unit there. I just looked at it as I walked past and the fellow running the sale barked at me "hey buddy I saw you look at that welder, gimmie 20 bucks and I'll throw it in yer truck" Well I gave him a 20 and he loaded it. It was filthy on the outside and the fan didn't work so I took the tin off and found to my surprise that the inside was clean as could be. I had to remove the fan and take it apart and clean it and it then worked and the welder worked great.
Looks like the separators got smoked likely due to overuse. The previous duty cycle is probably reduced now. I had a miller 150 that started to smell like burned varnish and decided to upgrade to an airco 250. It's a far cry from the new Lincolns we're using at work, wish I could justify getting a new unit, so sweet.
  • 2 weeks later...
If thats a hobby welder what did he weld for 6 min straight or more to melt it i have to ask i'd say he can find the part somewhere with a little luck.Lol i better check my 25 yr old mig cause i havn't cleaned it ever .The hobarts are good machines that couldn't of happened at once it must of been breaking down over some time i think anyway.
  Lol, I'll ask him.  I'm reminded of once I went to lunch break at a job and I flung the liner over an I-beam fixture as I was leaving and it hit the trigger lock and it ran for 15 minutes all over the floor....
  I still forgot to blow my lincoln out....:rolleyes:   I here they are indestructable tho.
  • 2 weeks later...
Was it arcing or just spooling,lol the best i ever seen was a guy go to listen if his gas was on by placing the nozzle next to his ear.When he pulled the trigger he drove .045 wire into his ear not nice lol lets say he was off work for a while.
  I bet he ran some wire out and held it sideways to his ear to check for gas the next time.  That wire both piled up and arced out, it was a mess.  It happened to others occassionally and I have a funny tale about a maintenance man getting tangled up in it one time I will tell you sometime.
Into his ear CANAL:o or just pierced it? I've always been able to hear the shielding gas wire or not, have I been using louder than usual wire welders or are the new guns really quite or what?
Ok, I don't know about the guy getting poked in the ear but the maintenance guy never got a scratch, just mad.  Wrecked his cushman scooter on the way out too.  Not a scratch.....
Ouch on the ear. Hopefully pierced the skin not the ear drum.
I did pierce my finger deeply with welding wire once. Dont really know How it did it but I was out of wire, snipped the inside part then went to pull the remaining wire out of the handle/liner with the same wire cutters I used to snip. Well it was a little tight and however I was holding it, the cutters dont work well to grab as they do to snip and the wire cut and the section held by the wire cutters got jammed through the meat of my finger. Hurt more pulling it out.
Dont use wire cutters to pull thin wire. Also wire cutters make the end they cut sharp.
Oh come ON Das, what kind of blacksmith uses the right tool for the job?
Well little by little, the one that gets bit by using the wrong one haha. Cant say how often the right tool is whatever is handy that might work.
Just so, make it work is the blacksmith way. :)
I've put the wire through the meat of my thumb using the wire to clean out the tip. Also, in the palm of my hand putting on an adaptor. Wire was sticking out of the drive rolls further than I expected. A guy at work unloaded a fresh spool he put on just before lunch. Laid the gun down on the trigger, wire had to travel about 4' before contact inside the tank. 44# .045 dual shield. It does make a mess.
Had a helper shut down a 211 Millermatic. Hi temp safety. He was welding some 2x4 box tubing continuously. I warned him before not to be laying his jacket on top of the welder, it blocks the vents. Fortunately, the welder still works fine.
Most folks don't know about the duty cycle. Manual we don't read no stinking manual.:wub:  RTFM (read the field manual) was drummed into my head so many years ago in the service and it has saved both me and equipment from harm. If it were mine I would give it a thorough cleaning and check all the wiring for any damage to the insulation. Then give it a couple of test runs, not to exceed the duty cycle. Then unplug it and check to see if it's getting hot.
Semper Paratus
  • 2 months later...
  Poor thing finally died a couple of days ago.  He said he will rob the copper out of it and use parts from it to make a cart for his new one.  I guess I forgot to say, he got it for nothing from a place we worked at.
  He said he would save "everything but the oink".
