Donal Harris Posted March 17, 2021 Share Posted March 17, 2021 I purchased this SCABA swage block a few years ago. Rather than wait on a new shipment, I purchased this one even though the two halves of the mold were misaligned. How can I clean it up? Someone told me a Dremel tool but that would take way to many bits. I tried an angle grinder, but that was difficult to control. Quote Link to comment Share on other sites More sharing options...
pnut Posted March 17, 2021 Share Posted March 17, 2021 I used a Dremel tool with a barrel sander after a diamond burr. It works pretty good for seams but not for taking off large amounts of material. Pnut Quote Link to comment Share on other sites More sharing options...
BartW Posted March 17, 2021 Share Posted March 17, 2021 I'd use a straight grinder with a 1/4' carbide burr. Usually cleans things right up. Sanding drums with ceramics are also goods. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 17, 2021 Share Posted March 17, 2021 I'd put a contact wheel smaller than the curve I was working on my belt sander and use a coarse belt to start with. Quote Link to comment Share on other sites More sharing options...
Donal Harris Posted March 17, 2021 Author Share Posted March 17, 2021 Once I have built it, that is what I will do. Quote Link to comment Share on other sites More sharing options...
rustyanchor Posted March 18, 2021 Share Posted March 18, 2021 Die grinder with a burr, small sanding drum on a drill, file, I would try the angle grinder again, with a 36 grit flap wheel sanding disk and a very light touch. A Dremel would work, but would use lots of little sanding drums, you could use the carbide burrs if you have them. Good luck Quote Link to comment Share on other sites More sharing options...
Latticino Posted March 18, 2021 Share Posted March 18, 2021 You guys are good, I think I just used files on mine after roughing with a 60 grit flap wheel on the 4.5" grinder... Took a long time and I got quite frustrated with the poor quality casting. Quote Link to comment Share on other sites More sharing options...
Ed Steinkirchner Posted May 7, 2021 Share Posted May 7, 2021 Now I feel like a neanderthal! I had mine cast from a pattern I made years ago and cleaned everything up by chipping off flash with chisels (cast iron chisels really nicely) and finishing with coarse files then finer files and a die grinder for the bowl depressions Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted May 7, 2021 Share Posted May 7, 2021 If it was me, a milling machine. Chuck up a boring bar in the quill, set the bit for the right diameter, and down it goes. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 7, 2021 Share Posted May 7, 2021 Wouldn't a Neanderthal have beaten the flashing off with a rock, Ed? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Donal Harris Posted May 8, 2021 Author Share Posted May 8, 2021 I spoke with one of the SCABA directors. He told me to bring it by and he would swap it out for a much cleaner one. Quote Link to comment Share on other sites More sharing options...
