angiolino Posted June 14, 2020 Share Posted June 14, 2020 Landscape Rock Mover hello, sorry if I am disturbing, for some time now I have been cleaning a ground, in doing this I have pulled out and undermined numerous heavy stones from the ground. I would like to collect them and use them to make dry stone walls. they are very heavy and bulky, I wondered, it is not by chance that you could advise me how to move them. I saw trolleys on the net, but I think they sink in the ground. I can't rent an earth moving machine, using the normal wheelbarrow is uncomfortable. if you could build a suitable trolley with suitable wheels by recycling materials or spending little money thanks to who will provide the right ideas and suggestions thanks Quote Link to comment Share on other sites More sharing options...
Chris C Posted June 14, 2020 Share Posted June 14, 2020 Those heavy duty two-wheelers look as if they'll do the job. If you have welding equipment, it would be fairly easy to make one. Quote Link to comment Share on other sites More sharing options...
angiolino Posted June 15, 2020 Author Share Posted June 15, 2020 my problem is finding the right wheels, perhaps of scooters or herm-sized tractors, then I have to make the lever of the bench to lift the rocks and stones from the ground and transport them where I should place them. thanks for your suggestions. Quote Link to comment Share on other sites More sharing options...
Marc1 Posted June 15, 2020 Share Posted June 15, 2020 You need solid rubber tyres like this one. Industrial type. Do a google search with "La casa delle ruote" Of course the right tool is a mini tractor like this Toro or Dingo with a grappler, but they don't come cheap. Quote Link to comment Share on other sites More sharing options...
Glenn Posted June 15, 2020 Share Posted June 15, 2020 How many rocks do you have to move? Are all rocks about the size you have shown? How far are you transporting them, and across what type ground? What do you have as a pulling source, men, animals, motorized such as small tractors etc? All these figure into the answers or suggestions you receive. Quote Link to comment Share on other sites More sharing options...
angiolino Posted June 15, 2020 Author Share Posted June 15, 2020 I only have a shovel a wheelbarrow a pickaxe as a tool, the smallest stones I moved easily with the wheelbarrow, the heavy ones from 30, 40 50, up to 100 kg I don't have help it's a job I do as a hobby, the mechanical shovel unfortunately, I cannot afford it, otherwise I would have to bring a club and crush the rocks and the big stones an epic effort. the countryside is open I cannot leave expensive equipment they would steal the land it is unattended abandoned the area is desolate. thanks anyway for the right suggestions, I have to adopt the ancient methods of the peasant grandparents, sweat fatigue elbow grease and ingenuity. thanks Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 15, 2020 Share Posted June 15, 2020 Stoneboat and rollers was how it used to be done; of course with 1 or more "horse power" or other draft animal. I have seen improvised ones made from leaf springs with a shaft through the loop on one end and a connection to drag it behind a vehicle. (I have never pulled a trailer with the trailer hitch on my pickup truck; but it has pulled a lot of stuff over the ground behind it!) Quote Link to comment Share on other sites More sharing options...
angiolino Posted June 16, 2020 Author Share Posted June 16, 2020 log-skidder-plate Pry bars? Rock sled? thanks for the right advice. I should use muscle and ingenuity and few agricultural tools. thanks Quote Link to comment Share on other sites More sharing options...
Glenn Posted June 16, 2020 Share Posted June 16, 2020 Do not forget that round things like pipe, or small trees, are you friend. They are roller bearings under your load and make it move much easier. Quote Link to comment Share on other sites More sharing options...
angiolino Posted June 16, 2020 Author Share Posted June 16, 2020 as the Egyptians moved the stones to the pyramids, the right intuition did not have crane excavators, forklifts, but the right ideas and brilliant intuitions. thanks Quote Link to comment Share on other sites More sharing options...
K.Corfe Posted July 16, 2020 Share Posted July 16, 2020 i know im late, but another alternative for the tires would be to remove the valve stems and fill them with expanding spray foam, it will be easier if you lossen the rubber on the rim and put it in through the sides, it will be messy, after it expands and sets cut away the excess and good to go. It makes a rough ride if used for any sort of trailer or ride on equipment, but its a good inexpensive never flat tire for wheel barrows and carts Quote Link to comment Share on other sites More sharing options...
arkie Posted July 16, 2020 Share Posted July 16, 2020 I have read numerous postings on other forums where folks tried to use the expanding foam in tires...after a while the foam simply starts breaking down and you have a flat tire full of crushed foam. Like others have posted here, solid is best for heavy loads. I suppose one could forge steel wheels......rough but sturdy. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 16, 2020 Share Posted July 16, 2020 Hmmm, lunar rover wheels perhaps? Metal and springy! Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 16, 2020 Share Posted July 16, 2020 I tried the tire foam intended to fill tires for the wheel barrow and it wouldn't support much weight nor did it last. I bought a solid tire with wheel for $12 +/-. I don't know if either is available in Italy though. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
angiolino Posted September 16, 2020 Author Share Posted September 16, 2020 thanks for the valuable suggestions Quote Link to comment Share on other sites More sharing options...
