Joshua R. D. Posted November 17, 2019 Share Posted November 17, 2019 No idea whether or not this is the proper place to put this but I was wanting an more in depth explanation as to whether or not the transition between the edge bevel and the secondary bevel will effect a blades cutting ability. I'm not talking about a ridiculous 20° edge and a 40° secondary. I'm talking about a much closer transition but one that's not quite as smooth as it could be. I suppose the better phrasing would be "is it possible for the secondary bevel to create drag or hinder the cut in any way" Quote Link to comment Share on other sites More sharing options...
bigfootnampa Posted November 17, 2019 Share Posted November 17, 2019 Yes. For my own blades I prefer to use the slack belt area of my grinder to make a slightly convex edge grind... thus I don’t really have a secondary bevel... but do enjoy the effects of one. This has the added advantage of creating a very smooth, slick cutting, transition that is easily repeated and good looking. If I do, in some clumsy way, end up with a rough looking transition... I will round it over a wee bit to make it look better and work better too! Mostly we are talking very subtle refinements here, of course, nothing that average users could detect... except for the appearance. Quote Link to comment Share on other sites More sharing options...
templehound Posted November 18, 2019 Share Posted November 18, 2019 Ridiculous 20, secondary 40....I am not certain what do you like to say/ask.... Mostly I grind blades down to a thickness of 0,20-0,30 mm so that they flex on my bare thumbnail. A blade that is ground so thin and sharpened with a primary bevel of 20 Degree , is not ridiculous at all. Well, that cuts like poison! Those 0,20-30mm can be easily stropped down to zero....rolled edge is the term, I guess. That is the old school and best edge You can get on a knife blade. Based on that, the "meat" behind the edge determines how strong Your edge will be.... So the secondary40 means the blade flanks?......please enlighten me Cheers Quote Link to comment Share on other sites More sharing options...
basher Posted November 18, 2019 Share Posted November 18, 2019 yes is the answer . the smoother the transition the easier the blade will pass through material. Quote Link to comment Share on other sites More sharing options...
Anachronist58 Posted November 18, 2019 Share Posted November 18, 2019 I hope that the OP comes back to respond - I too, am curious about the geometry he is describing. Smoothness of transition certainly reduces the forces neccessary to travel through the cut........ If the thickness behind the cutting edge encourages spreading or separation of the cut material, the spreading and shearing forces work together to accelerate the cutting action. Robert Taylor Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted November 18, 2019 Share Posted November 18, 2019 Forty degrees is a bit steep, much closer to an Axe than a knife Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 18, 2019 Share Posted November 18, 2019 Also depends on the type of cutting the blade is designed to do---which is why razors, knives and axes all have a differing geometry. (And a skinning knife and a "camp knife" will even have differing geometries.) Quote Link to comment Share on other sites More sharing options...
pnut Posted November 18, 2019 Share Posted November 18, 2019 There's a pretty comprehensive PDF regarding sharpening and edge angles. If you look through the topics in this section you'll find it. Pnut Quote Link to comment Share on other sites More sharing options...
templehound Posted November 19, 2019 Share Posted November 19, 2019 11 hours ago, Steve Sells said: Forty degrees is a bit steep, much closer to an Axe than a knife Thats what I thought. 19 hours ago, basher said: yes is the answer . Quote so the answer is definitely not" Yes" ....that aint a smooth transition...pretty coarse wedge Quote Link to comment Share on other sites More sharing options...
basher Posted November 19, 2019 Share Posted November 19, 2019 yes is to the question:- "is it possible for the secondary bevel to create drag or hinder the cut in any way" definite yes! Quote Link to comment Share on other sites More sharing options...
pnut Posted November 19, 2019 Share Posted November 19, 2019 On 11/17/2019 at 2:45 PM, Kurokubi said: "is it possible for the secondary bevel to create drag or hinder the cut in any way" Yes, 100% the steeper the angle the more effort required and friction to overcome to push it through something. Pnut Quote Link to comment Share on other sites More sharing options...
